Retrax Pro Mx with Rail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OkieYota, Jul 11, 2018.
  1. Jul 11, 2018 at 8:34 AM
    OkieYota
    OkieYota [OP] Unknown Member
    ‘18 TRD OR DCSB Cement
    None yet
    Hey guys I found out the retrax tonneau covers introduced a new rail system that uses the common T-Slot accessories.(* Edit* this is just the cover and slotted rails not the load bars shown here ) I guess these just came out about a month ago and if I can find a way to mount a cab high bed rack to it I think I’ll pull the trigger.
    They come with a matte black (and I believe textured ) finish , the top of the cover itself can hold 500lbs distributed evenly , and the salesman I was talking to said the rails can support 500lbs .
    I like the idea of a 3tier bed system keep valuables under the cover locked up.
    Heavy bags and weather resistant items on top of the cover.
    And long or permanent items on top of a rack .
    That said how much does a typical bed rack and RTT weigh ?
    Would 500lbs be enough to make a useable rack system?
    The salesman didn’t say if this was a static weight rating or dynamic but I would assume it’s dynamic .
    Oh and pricing is right under $2k
  2. Jul 11, 2018 at 8:45 AM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    What is the 2k price for? My pro cover alone was worth 1900 brand new. Is the racks included in the 2k?
  3. Jul 11, 2018 at 8:50 AM
    djolsen13
    djolsen13 Active Member
    Daniel
    Provo Utah
    Silver 2013 TRD Sport
    Bilstein 5100, Bed Bars, Prinsu Rack, Light bars (40", 30" and 2 pods). Tepui RTT
    An RTT could be anywhere from 100-250 pounds depending on what model and how big. So I'd say that, even for a small 2 person RTT, you'd be pushing the weight limit with just two people in it. Unless the Static Load weight rating is higher than 500lbs. Assuming the static is higher you should be completely fine with most any RTT.
  4. Jul 11, 2018 at 8:56 AM
    OkieYota
    None yet
    The salesman at real truck told me he could get me one for less than $2000 these are the same cover they just have a different optional rail now
  5. Jul 11, 2018 at 8:57 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    Post any more info if you find it later please. This sounds like exactly what I'm looking for.
  6. Jul 11, 2018 at 8:59 AM
    OkieYota
    None yet
    Yeah that’s what I’m afraid of me (200lbs) plus a RTT let’s just say another 200 lbs plus gear and a rack would be over the limit . I’ll call back these guys and see if they think static load would be higher
  7. Jul 11, 2018 at 9:03 AM
    strktly_bodysurf
    Oh so that's the cover price not the cover and racks together?
    Do they offer a rack that is at the full height of normal racks?
  8. Jul 11, 2018 at 9:34 AM
    OkieYota
    None yet
    Yes sorry if I confused anyone this is just a cover with optional rails, from what I understand they have 4 rail options now.
    regular rails, wide rails for (GM models), pocket stake cutout rails, and these rails which accept T-Slot style accessories.
    I dont think that they (Retrax) are offering any racks at the moment . you would have to add towers , tie downs, load bars, ect.. yourself from makers like thule, yakima, rhino, ect..
    I want to add a modified rack from CBI, RCI, KB VooDoo, Dissent, or any of the other bed rack venders on here
  9. Jul 11, 2018 at 9:39 AM
    OkieYota
    None yet
    How do I tag members on here? I want to see if any of these bed rack fabricators would want to modify one for me.
  10. Jul 11, 2018 at 1:12 PM
    OkieYota
    None yet
    Contacted Retrax they wouldn't give me a weight rating for the rails and said they wouldn't even recommend strapping 500 lbs to the top of the cover. Apparently there 500 lb rating is for even distributed weight parked.
    So pretty much a deadend for me.
  11. Sep 22, 2019 at 6:53 AM
    M2salmon
    M2salmon New Member
    2019 TRD OR LB
    500 lb is the rating for items placed directly on the blanket, not the load capacity of the rack rail system above the racks, no?
    Cavalry off-Road likes this.
  12. Sep 23, 2019 at 1:49 PM
    Clam04
    Clam04 Well-Known Member
    2018 TRD OR DCSB
    The 500lb rating for the retrax is for on top the panels when closed. It's pretty bogus, I found that even small loads on top they really start to deflect. The diamondback covers look a lot more robust.
  13. Sep 23, 2019 at 7:27 PM
    Cavalry off-Road
    Cavalry off-Road Well-Known Member
    Todd
    2019 Cavalry blue Tacoma TRD off-road
    M2 is 100% correct the weight limit is for things sitting directly on top of the slide / top —- the awesome thing about the new t- track system is it integrates the Yakima / thoule etc etc towers into it and those towers are resting on the top of the bed rails not the top of the slide, perfect for elevating your RTT or anything also above your bed and still keeping everything locked up & out of site
