Resurface or Replace my Rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mkla213, Sep 26, 2017.
  1. Sep 26, 2017 at 11:47 PM
    mkla213
    mkla213 [OP] New Member
    2015 Tacoma DCSB TRD Sport
    Leather Clazzio Seat Covers Pop & Lock Tailgate Lock UN-107 Air Filter
    Hey all, I've been looking for some advice on whether I should replace or resurface my rotors, or should I just replace the pads and leave the rotors as is. My rotors look like there in great condition. No grooves or warping. I have about 27,000 miles on them. My pads are about to hit the 3mm mark. Any Suggestions?
  2. Sep 27, 2017 at 12:01 AM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    I think you'd be fine slapping a set of pads on and go another 27,000 miles
  3. Sep 27, 2017 at 12:05 AM
    mkla213
    Thanks. I was hoping for that was the case.
  4. Sep 27, 2017 at 12:15 AM
    510tacoguy
    510tacoguy Well-Known Member
    Eduardo
    2004 4 door tacoma
    Body lift suspension lift
    If there's no serious grooves and the truck doesn't shake when applying the brakes a pad slap should be fine
  5. Sep 27, 2017 at 12:20 AM
    mkla213
    Correct I don’t have any issues with braking. Thanks for the advice. The more info and advice leaning towards this option for my situation gives me more confidence. I’ll probably order tomorrow and post results in a week or two.
  6. Sep 27, 2017 at 6:12 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Be sure to do the proper pad break in.
    Clearwater Bill likes this.
  7. Sep 27, 2017 at 6:14 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    What is this proper pad break in you refer to???
    taco2010trd[QUOTED] likes this.
  8. Sep 27, 2017 at 6:16 AM
    taco2010trd
    Tampa, Florida
  9. Sep 27, 2017 at 6:19 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  10. Sep 27, 2017 at 6:19 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I went over 100k on my first set of brakes and am 90k on the second. Seems there may be a problem somewhere with yours at under 30k. Just throwing that out there as something to look into.:cheers:
  11. Sep 27, 2017 at 6:21 AM
    taco2010trd
    Tampa, Florida
    Yes
    From Tire Rack:
    Brake Pad & Rotor Bed-In Procedures
    (Lea en español)
    All brake pads must be bedded-in with the rotor they will be used against to maximize brake performance. The bedding-in process involves a gradual build up of heat in the rotors and pad compound. This process will lay down a thin layer of transfer film on to the rotor surface. Following the bed-in procedures provided by the manufacturer will assure a smooth, even layer of transfer film on the rotor and will minimize brake judder.
  12. Sep 27, 2017 at 6:22 AM
    taco2010trd
    Tampa, Florida
    Yes, 27k seems quite soon to replace pads.
  13. Sep 27, 2017 at 6:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Repad. Clean rotors with a scotch brite and brake kleen first. Lube all caliper motion points. Properly bed new pads.
    http://www.stoptech.com/technical-s...ions-and-procedures/stock-brake-system-bed-in
    Yes. In fact, folks rolling off dealer lot should do same. But it's too complex for the average buyer to do or dealer to teach.
    Agreed. 50-60k should be a minimum on front pads that are not abused and functioning properly.
  14. Sep 27, 2017 at 6:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Not sure why you need new brakes on a 2015
