Resetting first gen abs light
Discussion in '1st Gen. Tacomas (1995-2004)' started by DanK83, Oct 10, 2019.
  1. Oct 10, 2019 at 3:55 PM
    DanK83
    DanK83 [OP] Well-Known Member
    Dan
    Maine
    2003 Tacoma SR5 V6 4X4
    So, I just replaced a bad abs sensor today but the light on the dash stays on. Can I reset it without a scan tool? Thanks for any help!
  2. Oct 10, 2019 at 3:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    pretty sure you need the OBDII scanner to do that.
    They cost like $20...
    DanK83[OP] likes this.
  3. Oct 10, 2019 at 5:46 PM
    J $
    J $ Active Member
    Jared
    04 Silver Taco 4x4, 3.4L V6, TRD Extracab
    If you live near Bellingham, Washington, we could meet up and you could borrow mine. That goes for anyone.
    indowaver likes this.
  4. Oct 10, 2019 at 6:06 PM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    If the problem is really fixed the light should go away on its own. It might take 30 miles or so of driving
  5. Oct 10, 2019 at 6:16 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Go to Toyotanation.com enter "How to reset ABS light" in search tab
  6. Oct 10, 2019 at 7:21 PM
    Glamisman
    Glamisman Well-Known Member
    or go to an O Reillys and get them to scan it and clear it...
  7. Oct 10, 2019 at 7:27 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Did you try disconnecting the battery?
  8. Oct 10, 2019 at 7:51 PM
    jbrandt
    Justin
    Good point. That should reset it too, as long as you leave it for several minutes.
    But just make sure you don't disconnect your battery a few days before you need to get it smogged. It clears all the emissions readiness codes, and won't pass smog (for Cali, anyway). Ask me how I know, lol...
  9. Oct 10, 2019 at 7:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Most ABS problems clear when the issue is resolved.
  10. Oct 11, 2019 at 9:14 AM
    DanK83
    Dan
    Maine
    I did, twice. I read an article online about unhooking the battery and depressing the brake pedal to drain the main computer of all electricity. Didn't work. Just ordered an OBD2 scanner on Amazon for $20.
  11. Oct 11, 2019 at 9:17 AM
    DanK83
    Dan
    Maine
    I'll try that. Only drove it 15-20 miles since replacement. Ordered obd2 scanner from Amazon for $20. Be handy to have in the future as well.
  12. Oct 11, 2019 at 9:30 AM
    jbrandt
    Justin
    How long did you have the battery disconnected?
    I've never heard anything about pressing the brake pedal, I don't see how that does anything.
    Did you get a blue tooth one or a wired OBD scanner?
  13. Oct 11, 2019 at 10:00 AM
    Black DOG Lila
    Virginia
    The ABS test and reset by brake pedal without OBDII diagnostics is detailed in Toyotanation.com search "ABS brake reset" on the site.
  14. Oct 11, 2019 at 10:30 AM
    jbrandt
    Justin
    Yeah, jumping the OBD socket and getting the codes, sure.
    I was talking about the OP saying he tried "unhooking the battery and depressing the brake pedal to drain the main computer of all electricity"
  15. Oct 11, 2019 at 11:00 AM
    Black DOG Lila
    Virginia
    Bless his heart
  16. Oct 12, 2019 at 9:57 AM
    DanK83
    Dan
    Maine
    I ordered the wired plug-in model. I only had battery unhooked a few minutes.
  17. Oct 12, 2019 at 10:01 AM
    DanK83
    Dan
    Maine
    I don't have an account on that site, Toyotanation . Com Do you have a link to tbe depressing of tbe brake pedal to reset tbe light? Thanks for all any and all help!!
  18. Oct 12, 2019 at 10:06 AM
    Black DOG Lila
    Virginia
    You don't need an act. I'm using Android TV box so no links.
  19. Oct 12, 2019 at 10:14 AM
    jbrandt
    Justin
    You can search the site without being a member, just like this one. Since you have (or will have) the OBD scanner, you don't need to do the brake pedal thing. That is a method in which you use a wire jumper to short out 2 leads on the OBD connector, then it flashes a code. But you should be able to pull the code directly from the OBD scanner you're getting.
    But if your light is still on after several (~30) miles of driving, the new sensor didn't fix the problem. The light should go out on its own if the fault is cleared.
  20. Oct 12, 2019 at 10:17 AM
    DanK83
    Dan
    Maine
    Okay, I did see a video on YouTube about using a wire to to connect or jump two ports
