Resetting "CHECK ENGINE" light
Discussion in '1st Gen. Tacomas (1995-2004)' started by MalibuFrank, Oct 27, 2014.
  1. Oct 27, 2014 at 11:30 AM
    MalibuFrank
    MalibuFrank [OP] New Member
    Frank
    Malibu
    2003 Tacoma
    Shell Trailer Hitch
    How do you do it?
    Thanks!
  2. Oct 27, 2014 at 11:57 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Remove your battery cables for a few minutes, is one way to do it, or just go get it cleared with a reader
  3. Oct 27, 2014 at 1:21 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Yep. Remove the ground cable from the battery, open and close the driver door ( interior light will deplete the remaining voltage lingering), put it back on and pray it doesn't come back on and if it does......it's something simple.
    raco.the.taco likes this.
  4. Oct 27, 2014 at 1:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    Personally I recommend using a code reader tool to clear the codes. When you disconnect the battery EVERYTHING loses it's memory, including the ECU which stores fuel data and idle information. Check the forum here and you will find no less than 2 dozen threads where people have problems getting the engine to start and idle after disconnecting the battery. Usually a parts store will clear a code for you for free with their code readers.
    Hamer95USA likes this.
  5. Oct 27, 2014 at 1:29 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Somehow I did mine with restarting the engine 3 times when I had the 02 sensor code.
    But now its not working.
  6. Oct 27, 2014 at 1:31 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    ^^^ This is the man to listen to.
  7. Oct 27, 2014 at 1:39 PM
    Matic
    Tricky Dick
    Easley, SC
    The a/f system will fix itself after about 15 mins. It doesn't take 2 days.
    It's recomended to do this after any minor/major engine mods anyway.
    And I have never heard of anyone having any trouble restarting after a disconnecting the battery to reset the ecu.
  8. Oct 27, 2014 at 1:40 PM
    Matic
    Tricky Dick
    Easley, SC
    Meh, sorry. Meant to quota Bama.
  9. Oct 27, 2014 at 1:41 PM
    bellassaiw10
    Currituck NC
    Ive never had problems starting my truck, doesn't mean it can't happen but I have a UG now so I just reset it like that. But if you can go get it cleared with a reader do that. Either way should be fine
  10. Oct 27, 2014 at 1:42 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I do. Every time. And I have a 2nd gen. Every single time I disconnect the battery to work on something electrical, after I reconnect and go to start it, it's like it is missing a cylinder or two. I drive it around my neighborhood block very slowly, then come home and restart it. Normally after driving around the block the second time, everything is clear and it's running good again.
  11. Oct 27, 2014 at 1:46 PM
    Matic
    Tricky Dick
    Easley, SC
    Never had a problem with my 2.7. Must have disconnected the battery atleast 15-20 times. Maybe its a 3.4 or 4.0 issue>?
  12. Oct 27, 2014 at 1:51 PM
    CD20H
    Ben
    North Texas
    Disconnecting the batter DOES clear the Fuel Trims that accumulate while driving causing hard starts and rough initial idle after a battery disconnect. But it is only temporary. Take short drive and the ECU will start calculating the trims again and get them close to where they were before you disconnected the battery. They are always changing.
  13. Oct 27, 2014 at 1:58 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You could address the cause of the check engine light instead of just resetting the ECU and hoping the issue magically goes away. I have a 2nd gen and it didn't misbehave at all when I changed the battery.
  14. Oct 27, 2014 at 6:00 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    but he said "second" gen tacomas not first gen like ours so the second gens must have more computerized crap that spazzes out.
    most codes should reset themselves given a few driving cycles as I understand it but if not then autozone can reset it for you when you ask them to check the code, then play dumb and tell em reset it and you will come back to buy the part in a day or two when you get paid lol.
    its well worth it to buy a code reader since they are cheap and come in very handy
  15. Oct 27, 2014 at 6:52 PM
    Marine.Doc
    Marine.Doc Well-Known Member
    central Alabama
    2015 SR5 Prerunner V6
    I googled 2012 camry check engine light and there are a few who recommend the same technique which I tried on my camry and it works. Don't know if it works on the Tacoma.
  16. Oct 30, 2014 at 6:52 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Another benefit of using a code reader is you can get some idea what caused the check light to begin with.
  17. Oct 30, 2014 at 8:44 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    You can pull the EFI fuse to reset the light.:notsure:
  18. Mar 13, 2015 at 9:20 AM
    PDXTac03
    PDXTac03 Member
    Portland OR
    2003 V6 4x4
    I recently pulled a few codes after the engine light came on, but didn't reset it at the auto parts store. Of the 4 codes, the one common recommendation was to just tighten the gas cap (4 EVAP codes). Since I'm in Oregon and not allowed to pump my own gas, it seemed logical that someone didn't tighten it.
    I tightened the cap after learning this, and the light didn't go off. Before I go looking into other potential problems, I'd like to know if the engine light should go off when the problem is remedied, or do I need to clear the codes in order for it to go off?
    Thanks....
  19. Mar 13, 2015 at 9:44 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    They have bluetooth/wifi code readers on Amazon/ebay for super cheap these days. If you have android (or someone's you can borrow) Torque is a great free app to pair with the code reader. They make iphone wifi apps too (iphone needs wifi because they lock out BT) but torque is better anyway.
    For less than $10 you can read and clear codes, view voltage readings on everything, temps, a/f ratios, all kinds of stuff.
    burntkat likes this.
  20. Mar 13, 2015 at 9:57 AM
    keakar
    karl
    louisiana
    agreed and make damn sure you write down the codes its giving, the reason is, if it comes on again you want to know if its the same code again or something different.
    if it gives you a second code for the same thing, then its a problem you need to fix.
    if the problem has already been fixed then after a few driving cycles it will usually (but not always) reset itself.
    what have you done recently to cause the CEL? have you messed with the throttle body? if so putting the vacuum lines in the wrong order will set off a CEL
