Reset my engine/transmission "learning"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thirdgentacoman, Mar 20, 2016.
  1. Mar 20, 2016 at 1:33 PM
    Thirdgentacoman
    Thirdgentacoman [OP] Well-Known Member
    How can I totally reset my engine / transmission learning my driving habits?
    I want to start back at square one. New transmission and insurance tracker program is done (saved 25%!) so now it's time to stop driving like a grandma.
    cryptolime likes this.
  2. Mar 20, 2016 at 2:04 PM
    mij
    mij Day work
    My guess is...................it will learn your new driving habits , good or bad.
  3. Mar 20, 2016 at 2:19 PM
    thors.hammer
    thors.hammer Well-Known Member
    Drive it like you stole it for the next 5000 miles.
    BRFab, Kolohe07, Jrome729 and 2 others like this.
  4. Mar 20, 2016 at 2:31 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Disconnect your battery
    LawTaco likes this.
  5. Mar 20, 2016 at 4:14 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Need Techstream or the like.
    Powertrain / Engine and ECT / Utility / Learning Value Reset,
    Powertrain / Engine and ECT / Utility / Fuel Density Learning Value Reset,
    etc.
  6. Mar 20, 2016 at 4:15 PM
    Thirdgentacoman
    If I don't have Techstream and therefore cannot reset it, will it continue learning? Or does my taco forever think I'm a 90 yr old grandma with saggy tits? (has 2.1k miles)
    Mscott2, davidstacoma and cryptolime like this.
  7. Mar 20, 2016 at 4:25 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    As long as those tits don't hold the brake pedal down, just start driving as you want to.
  8. Mar 20, 2016 at 4:25 PM
    splitbolt
    NW Arkansas
    Not sure...
    Have you tried asking the dealer?
    CluelessTaco likes this.
  9. Mar 20, 2016 at 4:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    mine has about the same miles and it thinks i am grandpa! work around for me long ago is drive in "S" mode all the time and i shift when i want it to shift............
  10. Mar 20, 2016 at 4:29 PM
    Thirdgentacoman
    These warlocks are quite saggy. Dealer always checks proper mat installation when reality is they should be checking tit sag.
  11. Mar 20, 2016 at 4:45 PM
    Ponchito
    Ponchito Well-Known Member
    Larry
    NorCal
    MGM DCSB OR 4x4
    You might try disconnecting the battery for 24 hours.
    That's what I did when I had a Infinity G35
  12. Mar 20, 2016 at 5:44 PM
    daddy_o
    Bossier City, La
    I may be wrong, but that will probably just erase all app info, door lock settings, contacts, etc. I think the only way to reset the transmission is with techstream.
    Lone_Wolf77 likes this.
  13. Mar 20, 2016 at 6:35 PM
    renau001
    renau001 Well-Known Member
    Repair manual implies that Techstream would be required as it has a step after replacing transmission fluid to reset the computer and techstream must be used for that.
    Fast1 likes this.
  14. Mar 20, 2016 at 6:42 PM
    Thirdgentacoman
    My service ticket doesn't explicitly say they reset the learning component, but they "cleared all data and disconnected battery" - I wonder if this is the same?
  15. Mar 20, 2016 at 7:24 PM
    renau001
    The should have, but probably no way to know for sure, but you can always ask the dealer. I personally would just drive it.
  16. Mar 20, 2016 at 7:29 PM
    Thirdgentacoman
    Ya that's my plan, just figured if I could reset it I might as well.
    Truck drives like a dream now tho, new transmission is so damn smooth.
  17. Mar 20, 2016 at 7:32 PM
    renau001
    Don't let anybody go and mess it up then :)
  18. Mar 21, 2016 at 3:58 AM
    TBayRay
    TBayRay Well-Known Member
    Ray
    2016 TRD offroad dub
    Took mine in this weekend for slugglish shifting, and downshifting...
    45min later they told me they reset it.
    Drive it like normal, he says.
  19. Mar 21, 2016 at 3:59 AM
    TBayRay
    Ray
    ....its gonna learn me out for the next 15-20mi
  20. Jul 27, 2017 at 2:03 PM
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    are these the only two things to change? whats the etc.? does that mean there are more steps to clear it?
