Reset low tire pressure warning?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fishnwiz, Jun 19, 2020.
  1. Jun 19, 2020 at 12:39 AM
    Fishnwiz
    Fishnwiz [OP] Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    Have a low TIRE pressure warning. The tires are all 34psi. The dash gauge all show a just the dash line. No pressure numbers. Is there some kind of reset for this? 2019 TRD
  2. Jun 19, 2020 at 12:44 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I think there's a button by the lever to pop the hood.
    Fishnwiz[OP] likes this.
  3. Jun 19, 2020 at 12:56 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
  4. Jun 19, 2020 at 1:14 AM
    Fishnwiz
    Bill
  5. Jun 19, 2020 at 1:33 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Yeah, no info on the dash could be serious. Warranty?
  6. Jun 19, 2020 at 1:42 AM
    bludweiaer
    pa
    you will need to drive it for awhile after reset, if it does not reset, dealer time... i took mine out after rim swap, not needed for me, been driving 40 yrs. without them..
    wilcam47, shakerhood and Chew like this.
  7. Jun 19, 2020 at 3:07 AM
    Fishnwiz
    Bill
    Yeah still under warranty
    wilcam47 likes this.
  8. Jun 19, 2020 at 7:44 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you first hop in the truck without driving it will just show those dashes and will do that also after pressing Reset. If after you drive for awhile it still shows those dashes then you need to visit the dealer.
  9. Jun 19, 2020 at 8:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    The reset button is so your truck can relearn the position of where the wheels are. If you are getting dashes for pressure and you are not getting the tpms light, it will probably work. What it means is that it knows the IDs, but doesn't know where they are. Sometimes you have to manually load the positions into the TPMS ECU. If the TPMS light is on, that means your sensors are not communicating with the ECU. On a new truck that you haven't replace the wheels, that could be a deeper issue.
  10. Jun 19, 2020 at 9:10 AM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    With that mindset you might as well remove your seat belts and air bags too. Just because you didn't need it before, doesn't mean it's not necessary now. Having TPMS sensors can be a pain, but they do prevent blowouts, accidents, improve gas mileage and prevent unnecessary costly tire replacements. Even if you check your tire pressure daily, you won't notice the nail in your tire quicker then the TPMS sensor will alert you to it.
  11. Jun 19, 2020 at 9:53 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    also, and I put this in another thread. if for whatever reason it doesn't know all the IDs like if one was replaced or you rotate in a 5th, when you press that button to reset it can freeze the system. if that is your case a tire shop will likely have a scanner and can tell you id numbers and where they are so it can be reprogrammed in techstream
  12. Jun 19, 2020 at 12:50 PM
    Sungod
    St Augustine
    Thanks Tacomaworld Karen!
    HighCountryTacoma likes this.
  13. Jun 19, 2020 at 12:55 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Usually the button will fix the issue. The manual gives you a rundown on the process for relearning the system, which involves going from ignition mode, to holding it down a certain length of time and driving x amount of time at x speed. Or you could have my issue and the dealer reprogrammed the sensors to the ones on your 3 month a year snow tire/wheel setup without telling you and when you ask them to reprogram it back to the stock wheels, they want to charge you...
  14. Jun 19, 2020 at 12:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  15. Jun 19, 2020 at 2:58 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    If its not going away, it could be an issue with the spare tire sensor. My mom's toyota highlander had a broken tire pressure sensor in her spare, she never got around to fixing it because it was not a huge priority. It would go away when we reset it w/ the button but it would come back after a few seconds.
