Replacing Water Pump and Timing Belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000 Tacoma Black, Dec 11, 2019.
  1. Dec 11, 2019 at 10:11 AM
    2000 Tacoma Black
    2000 Tacoma Black [OP] Well-Known Member
    2022 Tacoma DC Off Road / 2000 Tacoma Prerunner
    how much should parts and labor run in Southen Cal for this?
    Last replaced in 2012 and I think it cost $600 or so. I realize takin in to account inflation, also I could be remembering wrong..
    I am being quoted $1100 otd
    for water pump, timing belt and 2 serpentine belts + labor
    I’ve got about 90k or so on the current water pump so this is preventive maintenance as I don’t think I’ve got any signs of leaking or failure
    Wasn’t recommendEd by the shop, but value cover replacement is every time I go for an oil change ;)
    GQ7227 likes this.
  2. Dec 11, 2019 at 10:28 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The parts for my timing belt/water pump/belts was about $250-$300. I got my parts from the aircabinman guy on Ebay. All OEM parts. He's pretty much the only exception to my "don't buy critical car parts from Ebay/Amazon" rule.
    I was quoted $900 parts/labor for a TB replacement like 5-6 years ago, which is why I did it myself.
    The DIY job really isn't that difficult, it's all just turning wrenches. It took me a solid weekend to do it, There is a sticky that has a bunch of idea for making a crank pulley tool, and the only "special" tool you need is a torque wrench for the crank pulley bolt. You can rent those for free from most auto parts stores.
  3. Dec 11, 2019 at 10:46 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yeah, if you don't want to do it yourself, $1100 is a pretty reasonable price. I was quoted in the $1800 range at a dealer in the Seattle area.
    Like @jbrandt says, it's not a hard job if you feel like you could do it yourself. There are some special tools needed, but even with those and the parts, you'll come in below the $1100 quote (and well below what I got at the dealer here).
    This article has a list of all the parts you'll need, a list of all the tools you'll need, and step-by-step instructions on how to do the job. Plan a couple days to do it, and take your time, and you should be just fine!
    • You can buy most of the parts you need in a kit on eBay. There are several of them, but I went for the 100% OEM parts kit from aircabinman.
    • The crank pulley bolt, which Toyota says is a single-use bolt given the 217 ft-lbs of torque it's under while in service. (90119-16006)
    • Two gallons of red coolant concentrate, to refill the radiator when it's reinstalled. (00272-1LLAC)
    • Six gallons of distilled water - again, for the radiator.
    Special tools:
  4. Dec 11, 2019 at 11:03 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    you need to roadtrip to my area of USA, i have a quote (Feb-'19) from an indie ToyoTech for $389 including ALL belts, lost coolant, parts and labor, but not sure if it includes water pump or anything other than changing the timing belt and other belts
    it just says to also inspect water pump bearing and seals
    2000 Tacoma Black[OP] likes this.
  5. Dec 11, 2019 at 2:29 PM
    2000 Tacoma Black
    Thanks guys
    I don’t really want to replace it until it starts leaking but also don’t want to be stranded so will probably do it this Saturday
    Will definitely use Aisin OEM parts - that was what was included in the $1100 figure
  6. Dec 11, 2019 at 2:30 PM
    2000 Tacoma Black
    Where is this
  7. Dec 11, 2019 at 2:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  8. Dec 14, 2019 at 5:22 PM
    2000 Tacoma Black
    Took it in the shop. They opened things up and told me that 2 camseals were leaking. Extra 80 bucks for 2 seals with labor. I guess after 300k miles, you have things like this even with the first gen engine.
  9. Dec 14, 2019 at 6:38 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I usually skip the cam seals first change but catch them the second *they are part of most kits* so you're just overdue. Most shops have huge collections of them though.
  10. Dec 14, 2019 at 6:47 PM
    2000 Tacoma Black
    you mean you catch them the second time changing the water pump / timing belt?
  11. Dec 14, 2019 at 7:18 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    yes. Most all vehicles I might work on.
  12. Jan 25, 2020 at 11:58 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Reviewing timing belt videos, came across this improvised tool instead of the Schley 64400 tool (which she even mentions) - For those looking to save a little, this could work as well.
    https://youtu.be/w638xpYv_0c?t=33
    CS_AR likes this.
