Replacing upper and lower control arms - DIY
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZ00taco, Jan 21, 2018.
  1. Jan 21, 2018 at 9:42 AM
    AZ00taco
    AZ00taco [OP] Active Member
    2000 Prerunner Xtracab, TRD Offroad, V6, Auto, 140k miles
    Bed shell, Bilstein 4600's, tow hitch, AEM cold air induction, "Green" air filter, Gibson cat back SS exhaust.
    Have a bad lower control arm bushing so am thinking it's time to replace it. And do the uppers as well, they're all the same age and use so if one has gone, the others will soon follow. Installed new front/rear shocks last year. I can use a wrench. Watched a couple of ChrisFix's videos on replacing control arms and it looks like something I can do. Any advice about taking this on? And other "while you are in there's" to consider? Autozone Duralast any good or better products to use? Had the tie rods ends replaced last fall.
  2. Jan 21, 2018 at 9:51 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Check rockouto i dont like suspension parts from autozone to cheap IMO .
  3. Jan 21, 2018 at 9:58 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Rockauto sells the same trash as the parts stores. I think the OP would be better off with replacing the oem bushings. But it's not fun. This is a great video doing it on a 4runner.
    https://youtu.be/kmaZNBp1gZM
  4. Jan 21, 2018 at 10:06 AM
    AZ00taco
    On a Prerunner, does the steering rack need to be removed? Didn't show that in my manual (Haynes). I just downloaded the factory WSM so will study that too.
    I don't know if i want to replace the bushings, if i just replace the control arms, should I just buy OEM or is there a preferred aftermarket supplier?
  5. Jan 21, 2018 at 10:30 AM
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    I agree about rock auto. Every time I go on there to check a price it's cheaper until I get to check out and see the shipping charges.:eek: Not to mention the difficulties if you have to return it. Notozone and Leprechaun Automotive have there ups and downs; however, you can walk in and replace the part and I always try to get parts with the lifetime warranty.
  6. Jan 21, 2018 at 12:04 PM
    tony2018
    tony2018 Well-Known Member
    No, both control arms don't require the rack and pinion to be removed. The outer tie rods are bolted onto the knuckle/spindle
  7. Jan 21, 2018 at 12:13 PM
    tony2018
  8. Jan 21, 2018 at 12:13 PM
    AZ00taco
    Thanks, that's what it looked like to me when i looked at it but the WSM said to remove it. Going to check for a local machine shop that can do the bushings so I won't need new control arms.
