Replacing timing cover seal.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dutton18, Jun 18, 2016.
  1. Jun 18, 2016 at 8:10 PM
    Dutton18
    Dutton18 [OP] New Member
    06 Toyota Tacoma TRD
    I found out today that I need to replace my timing cover seal. How hard is that to do? Looking for some advice
  2. Jun 19, 2016 at 5:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is it the seal for the crankshaft or is it the Gasket for the timing cover.
    Huge difference.
    Crank seal easy.
    Timing cover gasket lots more difficult.
    TomTwo likes this.
  3. Jun 19, 2016 at 8:44 AM
    Dutton18
    Toyota told me it was the timing cover seal. So I'm guessing that it's just the cover that goes over the timing chain. I'm not for sure
  4. Jun 20, 2016 at 1:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    TomTwo and GKrigger like this.
  5. Jun 20, 2016 at 11:26 PM
    arnee05
    arnee05 New Member
    I'm looking fix the timing cover leak on my 06 as well - first big project I've done on my Tacoma. With patience and perseverance it should be ok. Have found a wealth of info on here this far on how to do it. Can someone give me some tips on cleaning/maintenance of timing cover and preparation of mating surface itself before placing fipg and reconnecting? Torque sequence for timing cover bolts?
  6. Jun 21, 2016 at 2:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Check the link in my post above for Tacoma repairs. It may be a different year than yours, but the engine and most other things are the same...
  7. Jun 27, 2016 at 8:09 AM
    Dutton18
    I replaced the upper idler pulley and the belt and changed the oil. Now after I change that I have a knocking noise coming from my engine. I didn't do anything different when I was putting the belt back on that day from taking it off any ideals of what the problem could be ?? I've checked the oil and it's fine.
  8. Jun 27, 2016 at 2:15 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You didn't get something back together correctly.
    Lester Lugnut likes this.
  9. Jun 27, 2016 at 8:03 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    If you have a lot of miles on your truck, take a close look at the water pump while you have the front end of your engine tore down.
    TomTwo likes this.
  10. Jul 17, 2016 at 10:25 PM
    arnee05
    arnee05 New Member
    Do the valve cover gaskets need replacing when the valve cover is removed? I'm re-sealing the front timing cover on my '06 V6 tacoma
  11. Jul 18, 2016 at 4:31 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, I would.
    TomTwo likes this.
  12. Jul 19, 2016 at 2:13 PM
    arnee05
    arnee05 New Member
    Do any of the bolt threads on the front timing cover need liquid sealant applied to them after timing cover resealed? Some appeared to have sealant on them but that may have just been remnant from fipg placed around the actual thread hole?
  13. Jul 19, 2016 at 3:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No it doesn't need sealant around the bolt head.
  14. Jul 19, 2016 at 4:32 PM
    arnee05
    arnee05 New Member
    And prying off the timing cover? Should it be at tight/difficult as it seems? I triple checked all bolts removed and its still real sticky.
  15. Jul 19, 2016 at 8:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you remove the oil pan and sub pan? They bolt to the timing chain cover.
  16. Feb 4, 2019 at 8:22 AM
    Christiansosa
    Christiansosa Member
    2006 SR5 Tacoma TRD
    All-terrain tires
    I know is an old thread, but how much FIPG would I need to reseal the timing cover of my 06 V6 TRD?
  17. Feb 4, 2019 at 3:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    One tube should do it, but I would get two as if you start you have to finish or you have to start over.
    Better to have it and not need it than need it and not have it.
  18. Dec 27, 2020 at 7:06 AM
    billyray1234.
    billyray1234. Member
    Billy
    Tacoma trd sport
    leak timing cover.
    Hey Jim, I'm getting my timing cover leak taking care of by toy. Its a 2016 trd sport. 50,000 miles, what parts will they replace? Do they get a newcover or just reseal it.
  19. Dec 27, 2020 at 7:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I doubt you are getting a new cover. Probably just a reseal and a new crankshaft seal.
  20. Dec 30, 2020 at 5:58 AM
    billyray1234.
    Billy
    Tacoma trd sport
    leak timing cover.
    Hey Jimmy, when the cover is all sealed up how long should that dry before starting the engine??
