replacing spare tire hoist?
Discussion in '1st Gen. Tacomas (1995-2004)' started by micalbertl, Aug 3, 2016.
  1. Aug 3, 2016 at 12:03 PM
    micalbertl
    micalbertl [OP] Well-Known Member
    1996 Tacoma Sr5 Xtra Cab
    Long story short I was forced to cut down my spare tire and now need to replace the oem hoist so that I can clear up bed space. I have already ordered the oem part as I prefer its location over all the aftermarket ones I have seen. The question I have is how difficult it would be to lift the bed so that I can replace the part as the genius Toyota engineers made it so that the bolts are wedged between the frame and bed. Should I just take it to a shop where I can have it raised with a hoist? Is there a safe and relatively easy way to use a jack to lift the bed ( I have seen it done with a hi-lift jack however I do not have one)? Could a few regular gym going people lift the bed up by hand? I have a 96 with a short bed.
  2. Aug 3, 2016 at 12:14 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    I've taken off the beds of older model Toyota trucks, the early 1980's Hiluxes and the bed was easily handled by two guys. I can't see that a first gen truck is much different. Its pretty easy - 6 bolts and some snap together electrical connections for the lights. It might take an hour. Good chance to clean up the frame and get rid of some rust too.
    micalbertl[OP] likes this.
  3. Aug 3, 2016 at 12:19 PM
    micalbertl
    ^ Thanks a ton that makes me feel much better. I hadn't even thought about rust clean up. Ill pick up some sand paper:thumbsup:
    oldtoyotaguy likes this.
  4. Aug 3, 2016 at 12:34 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I heard there was a recall for the spare tire hoist from toyota.
  5. Aug 3, 2016 at 12:40 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    there sure is, but im not sure for what years. had my 2003 one replaced under recall
  6. Aug 3, 2016 at 12:48 PM
    micalbertl
    I searched and found a tsb but couldn't get the actual information on it other than it involving the "spare tire procedure". does anybody have more info?
  7. Aug 3, 2016 at 12:52 PM
    carofchoice
    Jeff
    Newton, IL
    Easiest way is to call a dealer and give your VIN. they will let you know if its covered or not.
  8. Aug 3, 2016 at 12:53 PM
    micalbertl
    I actually finally found a website that would give info without me paying. It is only for 2001-2004 thank you guys for giving me info though
