Replacing seat belt buckle on 2015 double cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jr49, Jan 27, 2020.
  1. Jan 27, 2020 at 9:45 PM
    jr49
    jr49 [OP] Well-Known Member
    California
    2015 SR5 PreRunner Double Cab
    My front passenger seat belt buckle has been having issues. It won't let the seat belt tongue in without first pressing the release button all the way as you insert it. I got a quote from my local dealer to fix it, they first wanted a $149 diagnosis fee, which i declined and told them i know where the problem is. They quoted me $65 for the replacement buckle and $145 for the labor.
    I know that safety is first and I would usually steer towards having a professional handle this but I really think i can buy the replacement part for $40 and fix it myself. From the looks of it I'll need to remove the center console and just unscrew the bolt holding down the buckle to replace it. the only thing i haven't completely figured out is running the airbag cable/plug under the seat. not sure if i'll need to remove the seat to lock it into place where it currently latches.
    Any suggestions on going the DIY route? or should i steer clear and have a mechanic do it?
    EDIT: actually watching this vid I think i can just take out the whole seat and it may be easier than i was expecting. still would like some feedback from folks.
    https://www.youtube.com/watch?v=yEcowYsoW-c
    part: part no: 73230-AD021-B0
    https://parts.toyota.com/p/Toyota__/Seat-Belt-Receptacle-Right--Front/63338484/73230AD021B0.html
  2. Jan 27, 2020 at 10:40 PM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    I replaced my passenger buckle with a wrench and some skinned knuckles. Cheap part on Amazon, and I was in business. Indicator works and everything.
  3. Jan 28, 2020 at 12:15 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I’ve had the belts in/out of two Gen 1 trucks and several other vehicles over the years. This is definitely something you can do yourself. It’s easy-peasy.
    A couple of suggestions: (1) Use quality tools — the bolts can be tight, and you don’t want to screw stuff up. (2) Use a torque wrench to put the belts back on so you know they’re in to original specifications. It might surprise you that the bolts aren’t tighter than they are (something like 30-35 ft-lb IIRC).
  4. Jan 28, 2020 at 4:20 AM
    DG92071
    DG92071 Well-Known Member
    Unbolting the seat makes the job easier (14mm socket). The job can be done without unplugging anything from the seat. The wire harnesses attached to the seat are fairly long to allow the seat to slide backwards and forwards and that should give you enough room to easily get to that bolt for the seatbelt.
  5. Jan 28, 2020 at 11:07 AM
    jr49
    California
    Thanks for the suggestions. where can i find the specifications? ask service department i assume or can i find it online?
  6. Jan 28, 2020 at 11:11 AM
    4xdog
    Santa Fe, NM
    For sure it's online in the FSM that I believe is a sticky in this subforum. That'll be for the 2006 model year, I think, but the torque spec won't have changed.
    The inboard bolts are usually pretty easy as they're protected in the transmission tunnel. The outboard bolts, near the rocker panels, can be tricker on the older trucks 'cause that area is more susceptible to a bit of corrosion from road spray.
  7. Jan 28, 2020 at 11:56 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    For safety stuff I’d stick with oem parts only.
    2015WhiteOR likes this.
  8. Jan 28, 2020 at 12:17 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    That's what I was thinking.. Came in a toyota bag, matching part numbers. Seems legit!!
  9. Jan 28, 2020 at 12:47 PM
    jr49
    California
    awesome thanks. I don't see the specs for either the seat belt buckle bolt or the seats themselves on that thread. might be worth the few $s to get the specs from Toyota.
  10. Jan 28, 2020 at 3:35 PM
    Muddinfun
    Muddinfun Well-Known Member
    Here you are. I didn't post the actual seat removal process. Just be careful of the wires.
    TRDSport10, TnShooter and 4xdog like this.
  11. Jan 28, 2020 at 3:44 PM
    4xdog
    Santa Fe, NM
    To be honest, @jr49, either your searching isn't very good or you didn't really look. Perhaps it *would* be better for you to consider paying the dealer to do this.
  12. Jan 28, 2020 at 3:45 PM
    Muddinfun
    Since you have a SR5, I'm assuming you have the passenger side folding seat.
  13. Jan 28, 2020 at 4:00 PM
    jr49
    California
    Just blind apparently because i couldn't find that in the sticky thread. Thanks!
    4xdog[QUOTED] likes this.
  14. Jan 28, 2020 at 4:04 PM
    4xdog
    Santa Fe, NM
    It's a big table of contents, @jr49. But worth getting to know in detail!
    jr49[QUOTED][OP] likes this.
  15. Jan 29, 2020 at 10:55 AM
    Toy4me
    Tom
    NNJ
    Sorry, made a wrong assumption that it was aftermarket when you said cheap part on Amazon. With all the fake stuff out there I’m getting paranoid.
    abqnurse80[QUOTED] likes this.
  16. Jan 29, 2020 at 10:18 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    True that!!! I think I lucked out!! Can no longer find it on Amazon... In retrospect, I should have pulled the seat, my knuckles paid the price!!
  17. Jun 27, 2023 at 8:37 PM
    tacomonkey
    tacomonkey Well-Known Member
    My drivers side seat belt started doing this yesterday. When I went to insert the latch into the buckle, a spring was jammed in the slot. After removing the spring, I was able to insert the latch but I had to press the button in first. Seems to be secure but the seat belt warning light stays on and the warning chime comes on after driving for a minute or so. I guess the spring that popped out was part of the seat belt sensor, which failed. Ive owned many vehicles in my years and never had a seat buckle fail like this before. I am going to call the dealer to see if its possible it could be covered under warranty, I know its probably a long shot (its a safety issue though). I do see the OEM part online for $40-50. Not terrible. For those that have replaced the buckle, did you have to remove the seat from the vehicle? I have an extended cab, so I was hoping I could lean the seat back and swap the buckle.
  18. Aug 25, 2023 at 8:01 AM
    BaronVonChokey
    BaronVonChokey Member
    2015 Tacoma 4x4 OffRoad
    Happened to me this week, exactly the same way...
    What is a good place to order an OEM buckle replacement? I couldn't find one on Amazon
  19. Aug 25, 2023 at 8:11 AM
    4xdog
    Santa Fe, NM
    I avoid Amazon -- especially things sold by someone other than Amazon themselves -- for anything where originality is important. Amazon is littered with counterfeits.
    There are numerous references on here to legit Toyota dealers selling online with good service. McGeorge Toyota has done fine by me online over the years. Lately I've been using my local dealer (Lou Fusz in Saint Louis) who have started online parts selling using the Toyota portal. Their discounted prices to anybody online are better than my relationship of many years with the parts department has been able to get, so I use that now and pick up at the counter.
  20. Aug 25, 2023 at 11:33 AM
    tacomonkey
