Replacing OEM halogen headlight bulbs to LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codemunky, May 21, 2023.
  1. May 21, 2023 at 7:20 PM
    codemunky
    codemunky [OP] Active Member
    GC
    Los Angeles, CA
    2018 Inferno Tacoma TRD Off Road
  2. May 21, 2023 at 7:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. May 21, 2023 at 7:21 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  4. May 21, 2023 at 7:32 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    ^This
    I have ran performance h11's, Hids, leds and currently h9's. The verdict is H9's are the best overall in the stock housing. The les look bright as hell and are really deceiving as they are not bright at distance but really light up the ground in front of the truck. Hid's were the best performing but these projectors are not built for them so you are still blinding everyone. Also the high white in the led's make driving on wet roads at night just miserable.
  5. May 21, 2023 at 7:34 PM
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    If you want LED replace the entire headlight assembly with one designed for LED. LED bulbs in halogen housings provide poor lighting for you and blind other drivers.
    TRDRed likes this.
  6. May 22, 2023 at 4:18 AM
    Firn
    Firn Well-Known Member
    White OR
    So good advice *above* on the H9s for effective upgrades.
    If you have the coin the 2020+ OEM full led headlights are the bomb
    TRDRed, Chew and musicisevil like this.
  7. May 22, 2023 at 8:53 AM
    davistld01
    davistld01 Well-Known Member
    Terry
    2019 White Tacoma SR5
    Same here. I replaced the stockers with H9's the first month of ownership...and after lots of bitching about the uselessness of the stock bulbs. The H9's work much better for sure.
    TRDRed and Chew like this.
  8. May 22, 2023 at 9:22 AM
    Tacospike
    Two Trucks
    and 6500k, ew
    TRDRed, musicisevil and Chew like this.
  9. May 22, 2023 at 9:28 AM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I put LED’s in my 2020 Tacoma, I think the 6500K and have been very happy with them and so far the snow buildup hasn’t been a problem, but I wax the headlights. I like the pattern of the lights and the brightness, even added LEDs to the high beams. I have never been flashed that my high beams are on when they aren’t.
    My4thTacoma and VaToy like this.
  10. May 22, 2023 at 10:11 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    Did you read the linked thread? You’ve decreased the performance of your head lamps with the bulb swap. It appears brighter, at the expense of distance down the road.
  11. May 22, 2023 at 11:32 AM
    NMBruce
    SW Colorado
    I did and I don’t see that. I like the LED bulbs and that is what matters to me.
    maybe some day if I get some extra money or someone gives me some aftermarket LED headlights, I will put them in, but on a fixed income, I will go with this.
  12. May 22, 2023 at 11:50 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    The best performing H9s are like $20 a set…
    eurowner, TRDRed, DuffyBank and 3 others like this.
  13. May 22, 2023 at 12:46 PM
    Firn
    White OR
    LOL, right!!! Cheaper than the cheapest LED (which you can GUARANTEE is crappy)
    This is the reason Crash put as much work (a LOT of work) into his testing. What people "feel" and truth are often very far apart, his testing proves that although many "feel" LED bulbs work better in actual measured testing they don't in any and every way that matters. At the end of the day most thing "road more bright, more better" but lighting the pavement in front of you doesn't help, its lighting that faintly visible thing WAAAAAAY out there that does. The stock halogens put way more than enough light onto the asphalt in front of the truck, what matters is giving the driver more reaction time, and that is distance projection.
    BSFord, cwdog, TRDRed and 4 others like this.
  14. May 22, 2023 at 12:55 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    After install, you will likely point the headlights at a wall and see funny boxes of light that extend above the level-line of light. Those boxes are normal effects of the "reflector assembly".
    The H9 will install in the H11 connector after you pull the green adapter.
  15. May 22, 2023 at 1:14 PM
    NMBruce
    SW Colorado
    replacement LED light housing, a full kit, I think the ones I looked at where $900+
  16. May 22, 2023 at 1:15 PM
    NMBruce
    SW Colorado
    what can I say, I like what I have and until I can afford a replacement headlight set, I am not changing
    VaToy likes this.
  17. May 22, 2023 at 1:23 PM
    twtaco$
    twtaco$ Well-Known Member
    I’d get the 30000 lumen just to be safe
  18. May 22, 2023 at 1:35 PM
    DuffyBank
    DuffyBank Well-Known Member
    The H9 is a halogen bulb, same as you have in the high beam reflector housing. The Phillips H9 out performs your LED without the blinding glare to incoming traffic. Yes $20 a pair.
    TRDRed, musicisevil and MikeyMcFly like this.
  19. May 22, 2023 at 11:42 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Also agree... H9s make a big difference. Have since switched to OEM full LEDs but before that I updated the low beams to H9s and was very happy with the improved lighting.
    Stuffing LEDs into halogen/projector headlights will likely lead to numerous issues. Been there, done that.
    My $.02
