Replacing leaking transmission cooling lines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outofdodge, Dec 23, 2018.
  1. Dec 23, 2018 at 11:28 PM
    outofdodge
    outofdodge [OP] New Member
    2010 dual cab, long bed Tacoma
    Hello everyone,
    Just got my 2010 Tacoma back from the dealer for the frame treatment and leaf spring recall work.
    Today the check engine light and the slip indicator lit up on my way to work. Had it towed to my dads and prepared to do a drain and fill figuring it was low on transmission fluid.
    What I found was that it has been leaking from the coolant lines. I plan to talk to the dealer ship about this given I haven’t driven more then 200 miles since the work. But given the holidays and the all I would also like to prepare to just fix it myself and get the truck back on the road.
    I have searched the forums here for details on this and haven’t found quite what I need. What are the part numbers needed to replace the lines? Are there any fittings needed? If I do the brake line fix what fittings do I use?
    Thanks for your help in getting my Tacoma back on the road.
  2. Dec 24, 2018 at 5:29 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Dang they should not have reused those lines. They look like crap.
  3. Dec 24, 2018 at 5:43 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    And the ATF pan bolts. That underside needs a fluid film.
  4. Dec 24, 2018 at 8:40 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Are the connections loose?
    It's odd to see those lines rusted through.
  5. Dec 24, 2018 at 8:58 AM
    outofdodge
    Well had it towed to to the dealer for inspection. The lines are cracked at the fittings and they are certain it is unrelated to the work they did. $750 for the repair. I was polite but told them how absurd this seems to me. They will talk to their service manager about it. Not holding my breath, but I assured them I wasn't paying them $750 to do anything to my truck.
    So my original question remains. What lines and fittings do I need to replace the transmission cooling lines? Thanks for your help!
  6. Dec 24, 2018 at 9:03 AM
    outofdodge
    That was the first thing I put a wrench on when I got under there. They don't move at all. So seemed tight to me. And the entire underside of the truck is a horrendous rusty mess. Even after being descaled and treated it still looks like it was pulled out of the ocean. I love my truck but this has been a huge disappointment for me.
  7. Dec 24, 2018 at 9:54 AM
    fixnfly
    S.W.PA
    Lester Lugnut likes this.
  8. Dec 24, 2018 at 10:40 AM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Very common in cold climates
    Raylo likes this.
  9. Dec 24, 2018 at 10:41 AM
    Newfiebruh
    Tom
    unless your frame is cracked dont worry about cosmetic rust ;P. Anyways at the toyota in my town says that the leaking lines for transmission is super common, i have a 2010 aswell and mine is also leaking. I was going to replace the lines today but its christmas eve so it can wait. Dont worry about it man.
  10. Dec 24, 2018 at 10:48 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    with the right new lines and parts this looks like a doable DIY
  11. Dec 24, 2018 at 10:50 AM
    BillsSR5
    bill
    2014 SR5
    are you replacing all the lines? are there o ring gaskets that go inside the connection terminals?
  12. Dec 24, 2018 at 10:57 AM
    Newfiebruh
    Tom
    Just replacing the line thats leaking. If yours is the same line as mine its a low pressure line so it will only drip fluid over time anyways. As for the O rings, im not sure. Im going to put it up on the ramp and see what i need then buy it all in one shot. What the local guys in the tacoma group here were doing was just going to NAPA, getting some hose and clamping it on after taking all of the old line off. Where its a low pressure line it wont leak, and its fixed for like 15 bucks lol.
    BillsSR5[QUOTED] likes this.
  13. Dec 24, 2018 at 11:03 AM
    BillsSR5
    bill
    2014 SR5
    I would think using a liberal amount of PB blaster on those fittings and maybe a brake line type open end wrench would do it. maybe a little messy but looks doable. I would check with the parts dept see if the have those crushable o rings that need to get replaced to would suck to get it apart and find out u need them. I changed out a fuel filter on my 2004 taco with those type of high pressure lines and u have to use new washers in those connections or u get drip drip drip
    Newfiebruh[QUOTED] likes this.
  14. Dec 24, 2018 at 12:02 PM
    BillsSR5
    bill
    2014 SR5
  15. Dec 24, 2018 at 1:08 PM
    gearcruncher
    Canadain bumper technician
    I dont have any information in the above related link for cooling lines .I also beleive you have the 5 speed transmission , not the 4 speed
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    Cooling lines can be replaced in about an hour .
    Its just 5/16 steel line and regular couplings .
    20 bucks for new lines and 20 bucks for fresh couplings plus an hours labor and fluid .
    I dont think your couplings are OEM .
    You should be out the door for 200 bucks
  16. Dec 24, 2018 at 1:19 PM
    BillsSR5
    bill
    2014 SR5
    lambit likes this.
  17. Aug 4, 2019 at 2:07 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Bumping a little bit of an older thread because I had the same issue. Lower line part # is 32921-04100 and upper is #32922-04100. No additional fittings are needed. The nut at the trans end is already on the line and the forward end connects to a rubber line w/ a hose clamp. Discovered my lower line leaking yesterday when I went under to replace the hose clamp I have holding the drivers side cat heat shield in place as it was rattling again. $38 from the dealer vs $25 online but no shipping $ and they had it on hand so I’m fixed as of today. What a horror show of corrosion on all my lines though. Eventually I’m going to have to replace every line under the truck. Planning on replacing every trans line I can with just rubber line. I wonder how crazy of an idea it would be to just trash every bit of hard brake line, buy a spool of ss flex line and make my own from master cylinder all the way to the calipers.
  18. Aug 15, 2019 at 7:35 PM
    Torrencerodco
    Torrencerodco Well-Known Member
    2006 gold trd
    How hard are they to remove at the trans? Getting ready to do this job
  19. Aug 16, 2019 at 9:28 AM
    Toy4me
    Tom
    NNJ
    Depends how rusted. Mine was quite tight. I took a toothbrush sized wire brush and cleaned up the fitting as best as I could and sprayed it with penetrating fluid for a couple days prior. Use a line wrench on the 17mm line fitting. Spray the two line retaining clamps on the block too.
  20. Aug 16, 2019 at 9:34 AM
    Torrencerodco
    2006 gold trd
    ive been trying to get them off for a hour now. Prob have to take it to a shop. I’ve been spraying them for a month hoping it would help but nope
