Replacing Headlight Assembly on a 2009
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robowader, Apr 6, 2017.
  1. Apr 6, 2017 at 12:45 PM
    Robowader
    Robowader [OP] Member
    Buda, Texas
    TRD Offroad Series
  2. Apr 6, 2017 at 12:52 PM
    cc350
    cc350 Retired Member
    The Depot lights are nice, good fit but I would recommend sealing around the lens before install. The Spyder lights are junk, bad fitment leak bad and the brackets are cheap as they get. I bought the Spyders, look great but just didn't seat in opening correctly and the mounting tabs were weak. Maybe they improved them but it's a risk. The Depots I run now have been great, I did seal them first and fitment was like OEM.
  3. Apr 6, 2017 at 12:59 PM
    Robowader
    Buda, Texas
    TRD Offroad Series
    can you provide a link to these ones you purchased?
  4. Apr 6, 2017 at 1:02 PM
    cc350
    I bought the same ones you posted links to.
  5. Apr 6, 2017 at 1:05 PM
    cc350
    I have gone through 4 sets of headlights and 3 grills due to deer. I bought an extra set of the Depot lights just in case another deer desides to remodel my front end again.
  6. Apr 6, 2017 at 1:14 PM
    Robowader
    Buda, Texas
    TRD Offroad Series
    cool, thanks.
  7. Apr 6, 2017 at 1:20 PM
    Robowader
    Buda, Texas
    TRD Offroad Series
    Are there any other brands that you would recommend that are better than what I posted?
  8. Apr 9, 2017 at 8:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Take a look at Toyota's OEM smoked TRD headlights that were available on the late model sports, a little more pricey.
    OEM 2005-2011 smoked headlights:
    These are available loaded with bulbs, and unloaded w/o bulbs, saving $60 off the set . These part numbers are for the unloaded housings.
    Right #81130-04173 http://stores.revolutionparts.com/toyotaparts.bochtoyotasouth.com/oe-toyota/8113004173
    Left #81170-04173 http://stores.revolutionparts.com/toyotaparts.bochtoyotasouth.com/oe-toyota/8117004173
    EDIT!!! These part numbers are for the pre-TSB lights! See my post further down for the updated post-TSB fixed versions.
  9. Apr 20, 2017 at 8:17 AM
    Robowader
    Buda, Texas
    TRD Offroad Series
    My headlights came in but I am having trouble getting them installed. Those little plastic clips have become brittle and break when I try to take them out or put them back in. In addition, there is a screw that I have to access from under the front tires that is causing problems. From a you tube I saw I have to take out the plastic liner in the roof of the wheel well to get to it. However, there are some plastic parts that extend out and I am afraid I am going to break them off.
    Does anyone have any suggestions? The only video I can find is this one.
    https://www.youtube.com/watch?v=G9r3feo_y8g&t=216s
    PLEASE HELP WITH SOME GUIDANCE
  10. Apr 20, 2017 at 9:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  11. Apr 24, 2017 at 6:39 AM
    Robowader
    Buda, Texas
    TRD Offroad Series
    I got it done and yes, I went through the wheel well to get to that one screw. Complete pain but I got it done. Thanks for all the advice.
  12. Apr 24, 2017 at 11:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Those old lights look like you hit them with a torch!
  13. Apr 24, 2017 at 11:51 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Great price, thanks!
    crashnburn80[QUOTED] likes this.
  14. Apr 25, 2017 at 12:09 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Depo or TYC are fantastic factory replacements. OE fit and durability.
  15. Oct 16, 2019 at 4:53 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    So I’m looking for the black headlights , I have a ‘07 TRD OFF ROAD. I don’t have daytime running lights on my truck , which year doesn’t have the daytime running lights but has the black “inlays” I guess you call them ? Just the ‘09 ? Or which year?
  16. Oct 16, 2019 at 6:47 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good thing you posted! Those previous part numbers I listed were incorrectly the pre-TSB models with the DRL melting issue, I’d suggest the post TSB lights with the fix, even though you don’t have the DRL function. The DRLs is just a feature on the truck to have the forward running lights run independently. The headlight assemblies are the same regardless of whether or not your truck has the DRL option. Search by part number for the lights, I’ve listed the parts below with the best pricing I’ve found.
    These are like the Pro lights, but came on select Sport models. These are the updated TSB version of the lights that do not have the melting DRL issue. TSB is available here.
    Right: 81110-04210
    Left: 81150-04210
  17. Oct 16, 2019 at 4:01 PM
    igno1tus
    I love the pictures Toyota shows , a sketch of the lights . So those will fit the years you have listed huh ? So those have DTR ?
    Thanks for the part numbers btw !
  18. Oct 16, 2019 at 4:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Those part numbers fit 05-11. The DRL is a function of your in-cab switch, not the headlight assembly.
  19. Oct 16, 2019 at 4:28 PM
    igno1tus
    But the assembly has the spots for DTR ? My truck doesn’t have the DTR stock , so there will be extra holes in the light assemblies ?
  20. Oct 16, 2019 at 4:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The DLR is the dual filament turn signal bulb. There is one bulb that is both the DLR and turn signal. If your truck does not have DLR the turn signal bulb does not remain constantly on.
