Replacing front wheel bearings. What seals to buy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by g8erh8er, Jan 6, 2019.
  1. Jan 6, 2019 at 7:31 PM
    g8erh8er
    g8erh8er [OP] Well-Known Member
    Land O Lakes, Fl
    2012 Tacoma DC 4x4 Sport
    I'm purchasing assembled front wheel bearing units for my 2012 4x4 Tacoma.
    Can someone tell me if I will need the following seals?
    Back of spindle: 90316-A0001 (Timken alternative 710573)
    Outside CV axle: 90304-A0001
  2. Jan 7, 2019 at 6:11 PM
    g8erh8er
    Land O Lakes, Fl
    Anybody?? Truck has 112k on the odometer. I'm guessing since these seals will be exposed during the install. I may as well replace them. Or have most who performed a wheel bearing replacement found there to be little need to replace these?
  3. Jan 7, 2019 at 6:34 PM
    badger
    badger Well-Known Member
    07 SR5
    many people do not replace the outer seal on the CV axle. I think that is short sighted. This seal is the first line of defense for water and dust getting into the bearing.
    Taco'09 likes this.
  4. Jan 7, 2019 at 7:11 PM
    g8erh8er
    Land O Lakes, Fl
  5. Jan 7, 2019 at 7:15 PM
    g8erh8er
    Land O Lakes, Fl
  6. Jan 7, 2019 at 7:23 PM
    g8erh8er
    Land O Lakes, Fl
    I think I see the issue. It looks like the Timken 710573 Amazon listing is using the wrong picture (it shows the 710477) seal.
  7. Jan 7, 2019 at 7:41 PM
    badger
    07 SR5
    I'm sorry, I don't have the part number handy, but when i did mine I could not find an aftermarket option for the seal. It was OEM only.
  8. Jan 7, 2019 at 7:45 PM
    g8erh8er
    Land O Lakes, Fl
    No worries - think I've got it figured out.
    Inner Seal (For outermost portion of CV) - 710573
    Outer Seal (For back of Hub) - 710477
    EDIT - I have this ass backwards
    Knuckle/Hub Seal - 710573
    Outer CV Seal - 90304-A0001 (no alternate P/N)
    The 710477 is a seal that actually is already installed on the hub assembly I believe.
  9. Jan 7, 2019 at 11:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    From my notes:
    90312-96001/710477 goes on the bearing assembly that gets pressed on the hub.
    90316-A0001/710573 for the outside seal that gets pressed on the knuckle.
    90301-A0005 is the o-ring that goes between bearing assembly and brake dust shield.
    43514-28010 grease caps.
    90119-A0167 flange bolts; can also use 90119-12369 which are not flanged.
    I don't see 90304-A0001 anywhere in my notes; web says it's outside seal for 2003-2005 4Runner and 98-07 Land Cruiser.
    I'm on my third set of front bearings. I say don't replace the outside seals (the ones on the knuckle) unless you have rust inside the knuckle. Just put some silicone on the rubber seals and you will be good to go. I replaced driver side but not the passenger side. Requires more work as you have to remove tie rod and sway bar in order to swing the knuckle around to press out the seal.
    wi_taco and Reggie4x4 like this.
  10. Jan 8, 2019 at 4:21 AM
    g8erh8er
    Land O Lakes, Fl
    Thank you. There’s hardly any mention of that o-ring in most of the wheel bearing threads I’ve read. Assume people just reuse?
    reallifedog likes this.
  11. Jan 8, 2019 at 4:45 AM
    badger
    07 SR5
    use a new oring. Seriously, seals are no place to cut a corner. If anything gets past them your bearing is toast.
  12. Jan 8, 2019 at 5:21 AM
    g8erh8er
    Land O Lakes, Fl
    I hear ya badger. So total parts list coming my way is as follows:
    2 - complete wheel hub assemblies
    2 - 710573 (knuckle seal)
    2 - 90304-A0001 (CV outer dust seal)
    2 - 90301-A0005 (O-ring)
    1 - ECGS Bushing
    1 - 90311-47027 (differential seal)
    lo2hi likes this.
  13. Sep 8, 2021 at 6:50 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Thanks guys, especially Chuy for the correct list and OP for starting this thread.
    I'm pressing together a wheel bearing assembly with a new NSK 54KWH01 bearing.
    710477 is pressed on to the bearing before hub.
    710573 is the outer seal behind the knuckle.
    90301-A09005 O-ring on the inside of bearing.
    90119-A0167 (4) bolts.
    I also verified this info on a Toyota parts website cross referenced to other sites.
    All these parts plus new hub were $120 shipped to my door. Slightly more than the $112 Dorman.
    lo2hi likes this.
  14. Sep 8, 2021 at 7:15 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    And much higher quality!
    Rob MacRuger[QUOTED] likes this.
  15. Nov 9, 2022 at 3:47 PM
    Mastiff37
    Mastiff37 Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    Reviving this. Can anyone point to a write-up or video on replacing these seals? I'll be doing my bearings shortly (from fully assembled units), but I'm still a little hazy on where all these seals and o-rings are.
  16. Nov 9, 2022 at 6:18 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    There's a seal between the back face of the hub & the outer face of the bearing- that's installed on the bearing before pressing in the hub, if you're buying assemblies, that's of no concern to you. That's what seals the outer side of the bearing from intrusion from the outside world.
    There's an O-ring on the inner side of the bearing, should be included with an assembly. This isn't a dynamic seal, it's just sealing the bearing outer surface inside the knuckle mounting bore so it doesn't rust in there.
    The inner seals are a pair. There's a seal on the outer CV joint, which generally comes with new axles. That's the 'only Toyota' seal, which is probably mostly because it rarely needs to be replaced. Then you have the knuckle seal (710573) which is installed on the backside of the knuckle. Those two are what seal the inner side of the (already sealed) bearing from the outside world.
  17. Nov 9, 2022 at 7:24 PM
    Mastiff37
    Tucson, AZ
    Thanks, that makes total sense. So, presumably the one people routinely replace when doing the bearings is the one on the back side of the knuckle, (knuckle seal, aka "outer", 710573)? I need to decide if this is worth the trouble too, since I think it makes the job a good bit tougher than just swapping the bearing assembly.
  18. Nov 10, 2022 at 8:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d at least buy them. When you pull the bearing assembly if you don’t see any signs of water intrusion, then don’t replace them. If however, you do see signs of water intrusion, you should replace the seals.
    Obviously, the best thing to do would be replace them. But we all have to make choices based on judgement sometime. As I said before, I chose not to replace one of mine the 2nd time around.
  19. Nov 10, 2022 at 8:33 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    ^^^ This 100%.
    My own 2 cents: Those seals are like, what, $10 each? So for $20 in parts and a few extra minutes of labor to install, is it worth not having to question whether the old ones are good or bad? Is $20 worth it to not have to tear it all apart later and do it again, or worse replacing another hub bearing? Just do it, you'll sleep easier at night.
  20. Nov 11, 2022 at 5:51 AM
    Mastiff37
    Tucson, AZ
    I ordered them, but is it really just a few extra minutes? I haven't looked in detail yet, but getting the axle ends out of the knuckle didn't sound like a few minute job. I'm not worried about the seal it itself.
