Replacing front struts,replace Strut Mount?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mush Mouse, Sep 17, 2015.
  1. Sep 17, 2015 at 11:43 AM
    Mush Mouse
    Mush Mouse [OP] Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I was going to replace the front struts/coil springs on my truck with new Bilstein 4600 and OEM coils and was going to have a Auto shop do the work. Was discussing with the owner about pricing and said to include new Strut mounts with the parts, are these a replacable item? or can you use the old ones because the Toyota OEM mounts are $61.79 a piece, Rockauto has Gabriel and Sachs brand around $25-$30 apiece. Was the owner just talking about replacing the Coil spring insulators or the complete Strut mount, I am not quite sure if the mount can be reused and just to purchase new Insulators and reuse the old Strut mount? I am supplying the parts to do the work. Heres the mount http://www.rockauto.com/catalog/moreinfo.php?pk=4257474&cc=1429084&jnid=511&jpid=3 heres the insulatorshttp://www.rockauto.com/catalog/moreinfo.php?pk=1028429&cc=1429084&jnid=510&jpid=0 and coil seathttp://www.rockauto.com/catalog/moreinfo.php?pk=1005778&cc=1429084&jnid=509&jpid=0 what is really necessary to replace these struts/coils.
  2. Sep 17, 2015 at 12:03 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    The stem buhings I would replace but the isolator is not needed unless you just want to.
  3. Sep 17, 2015 at 12:29 PM
    Mush Mouse
    mush
    2013 SR5
    thanx for the heads up info I found this http://parts.camelbacktoyota.com/pa...ber=4860935010&vehicleid=174984&siteid=214329 diagram of the front strut assembly its showing 1 stem bushing Item #5 and a top nut the Bilstein kit has a top nut no bushing so I am thinking of getting this Gabriel kithttp://www.rockauto.com/catalog/moreinfo.php?pk=4257474&cc=1429084&jnid=510&jpid=3 it looks to include the Stem bushing and insulator with all new hardware so nothing should be missing when they do the install although I am hoping its not just specific for use with GABRIEL struts??
  4. Sep 17, 2015 at 12:54 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I replaced my strut mounts with these when I put my Eibach 3"coils with Bilstein 5100 adjustables in the front
  5. Sep 17, 2015 at 12:56 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I had 200,000 miles on my truck when I took my spacer lift off and added this lift so it just depends on how many miles you have or what your strut mounts look like. It's nice to have new one's since you're in there anyways
  6. Sep 17, 2015 at 1:10 PM
    TACO TX
    Kelly
    Denison ,Texas
    You have a washer, bushing, top hat, bushing, washer, nut in that order. The shock will have its own nut b/c the shaft is larger on the 4600/5100's. The Gabriel doesn't have enough bushings and washers. You need 2 each for each side for a total of 4 bushings and 4 washers.
    MindFork likes this.
  7. Sep 17, 2015 at 1:21 PM
    Mush Mouse
    mush
    2013 SR5
    thanx again, it looks like the Wheelers stem bushings is what I will need and Insulator, and use the hardware on the original strut will suffice. I went to the Stealership for a estimate on replacement>>3 hours labor $413 and an alignment $90:eek: I went to American Tire Company where I get my tires he said $278 plus tax everything,but he was the dude that said to get the strut mount stuff so I got to get the necessary parts to do it so theres no hiccups:fingerscrossed:also the truck has 255k miles on the OE coils the original shit bag shocks Bilstein were changed at 77k miles to the Bilstein 4600s now they are wasted.
  8. Sep 17, 2015 at 1:59 PM
    53rdcard
    53rdcard Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    Not sure if blisteins have this or not, but i just changed my front struts and rear shocks last weekend, and went with complete assemblies for the struts, it has everything already together, all you have to do is put it on the truck, no spring compression or any of that. Other then one of the nuts that held on the strut on the left side being rusted to the point that it was pretty much rounded.
  9. Sep 17, 2015 at 2:02 PM
    TACO TX
    Kelly
    Denison ,Texas
    I just replaced all mine also, TRD coils were toast, leaf packs toast, as well. Had 4600's but went 5100's now. I used Moog non TRD constant rate 460# coils. Rides like a Cadillac!
  10. Sep 17, 2015 at 2:16 PM
    Mush Mouse
    mush
    2013 SR5
    any front end lift with using MOOG 81100 coils I just sent back my TRD spec 81104 for my truck after reading about a 2 inch lift to the front http://www.customtacos.com/forum/12...-spring-replacement-ride-height-question.html I want stock height
  11. Sep 17, 2015 at 2:36 PM
    TACO TX
    Kelly
    Denison ,Texas
    Idk, I set my 5100's to 1.25". May set higher due to old coils sagging.
  12. Sep 17, 2015 at 2:43 PM
    Mush Mouse
    mush
    2013 SR5
    OEM progressives left and right =$224 shipped, MOOG 81100=bout $50 pair:annoyed:aint digging what this dude said about the 81104
    Front strut and coil spring replacement ride height question...
    Are all the add a leaf kits basically the same? Will http://www.ebay.com/itm/ADD-A-LEAF-REAR-1-5-2-LIFT work[​IMG] good?
    Also came about a problem from the moog coil springs lifting the front. My cv boots are spewing grease now. I've seen tons of different responses new clamp, cv boot, or axle swap. I'm thinking I'll just drive it till the boot goes bad and replace the axle
  13. Sep 17, 2015 at 3:05 PM
    TACO TX
    Kelly
    Denison ,Texas
    You are not going to get enough lift out of a factory ride height coil to do damage to CV's. Short add a leafs are junk, ride crappy. Why lift the rear and not the front?
  14. Sep 17, 2015 at 3:14 PM
    Mush Mouse
    mush
    2013 SR5
  15. Oct 5, 2015 at 8:27 PM
    NM Lance
    NM Lance Well-Known Member
    I just bought the Bilstein 4600's, and they did not come with any of the stem bushings... man I am pissed!!! Why would they not include these with the struts? I didn't even think twice as to whether or not they would be included. After all, why wouldn't they be?
  16. Oct 5, 2015 at 8:43 PM
    TACO TX
    Kelly
    Denison ,Texas
    Mine are 194,000 miles old, just use the old ones.
  17. Oct 5, 2015 at 8:49 PM
    NM Lance
    Yeah, I will probably just give them a shot. I noticed you had posted a link above for new bushings, but I can't seem to find the right kit for the 4600's (I still have my original strut spring mounts). Oh well, I have about the same mileage you do, so I will just run what I have I guess.
  18. Oct 5, 2015 at 8:52 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Only have 128K on my truck and just added a Toytec AAL. I have that rake but I will get rid of that once I have my 32s
  19. Oct 6, 2015 at 6:22 AM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Do you have any pics of this set up with the moog 460's?
  20. Oct 6, 2015 at 7:09 AM
    TACO TX
    Kelly
    Denison ,Texas
