Replacing Fog Lamps with LED Pods?
Discussion in 'Lighting' started by n.gardner, Jan 3, 2015.
  1. Jan 3, 2015 at 7:59 PM
    n.gardner
    n.gardner [OP] Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    Looking to purchase aftermarket bumper for my Taco, ideally with fog light cutouts.
    My question is:
    Can I wire a set of pods to the stock fog lamp switch? Is the stock wiring a thick enough gauge? And does the stock fuse hold that kind of amperage?
    THANKS
  2. Jan 3, 2015 at 8:04 PM
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Yes you can. LED lamps will pull a lot less amps then the stock lamps.
  3. Jan 3, 2015 at 8:25 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    are the stock wires similar gauge to RIGID lamps?
    is it an easy solder?
  4. Jan 3, 2015 at 8:34 PM
    medic2230
    Murph
    Bama! Roll Tide
    If you wire it up through a relay it won't matter because you choose the size of the power wires. You can use the fog switch as the trigger for the relay.
  5. Jan 3, 2015 at 8:37 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Forgive me for my lack of electrical knowledge..
    Basically I can cut off the stock fogs off... solder pods to cut wires. drive truck ?
  6. Jan 3, 2015 at 9:45 PM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
  7. Jan 3, 2015 at 10:18 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
  8. Jan 3, 2015 at 10:52 PM
    Vanguard
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    That's ok...sometimes that's what us guys are for.
  9. Jan 3, 2015 at 10:57 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Rigid has a kit you can use to put on your truck message chad from tap auto parts on the forum here. He will hook you up. Or Benbacher will hook you up.
  10. Jan 4, 2015 at 10:07 AM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    http://www.rigidindustries.com/mounting-options/46509
    If this is what you're talking about, I'm not really looking for that.
    I am eliminating the factory bumper... Correct me if I am wrong.
  11. Jan 4, 2015 at 10:17 PM
    MGMTacolover55
    Orygun
    floor Mats
    My bad! I would recommend you check out rigid or Avec lighting on here. You can message a guy named mikevee for pricing.
  12. Jan 4, 2015 at 10:27 PM
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
  13. Jan 4, 2015 at 10:36 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I wired up my rigid duallys using the stock fog light wiring. I also replaced the stock fog light switch with an OTRATTW rocker. You need to order a rocker switch that has top and bottom independant leds to make the switch lighting work with the stock fog wiring because it uses a switched ground. The factory wiring is sufficient and will work good.
  14. Jan 4, 2015 at 11:02 PM
    Vanguard
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Do you still have the stock switch? I'll buy it from you if you aren't gonna use it.
  15. Jan 4, 2015 at 11:13 PM
    deeezy
    Dana
    Hawaii
    I need to go look for it and make sure i didn't ding it up when I took it out.
  16. Jan 5, 2015 at 12:07 AM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Do I need to replace the switch? I have no idea how this electrical shit works lol
  17. Jan 5, 2015 at 3:01 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
  18. Jan 5, 2015 at 7:43 AM
    deeezy
    Dana
    Hawaii
    Nope, you can just swap the rigid fogs out.
  19. Jan 5, 2015 at 7:09 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
  20. Apr 15, 2017 at 3:35 PM
    Tlharding5996
    Tlharding5996 New Member
    Tucker
    2007 Pre-Runner Access Cab
    Do any of y'all use the non-legal ones on the road? If so have you gotten pulled over or ticketed. I don't know if it's worth it cause I just want to light the road more. I don't go "off-road" all that much (maybe once a month). Worth it to try the non-road legal ones?
