Replacing exhaust flanges
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAGCanada, Sep 1, 2024.
  1. Sep 1, 2024 at 2:57 PM
    JAGCanada
    JAGCanada [OP] Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I have a leak on the passenger side exhaust, downstream of the second Cat on that side. I have replaced the gasket and wire brushed the pipe. It still leaks. I think it is because the flange has rusted and the thinkmes isn't there any more. I have tried non-OEM gaskets too, same issue.
    I am leaning towards cutting out the existing flange and welding in a new one. The Cat is fine so I don't want to replace the entire assembly.
    Anyone have any experience welding in new flanges?
    View looking up
    View looking down from top. Not a lot of flange left on one side.
  2. Sep 2, 2024 at 4:14 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    That gasket doesn't look right
  3. Sep 2, 2024 at 5:22 PM
    Waasheem
    Waasheem
    2007 xrunner
  4. Sep 2, 2024 at 7:02 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Flange is bent, wrong gasket, should have the spring bolts on that joint.
  5. Sep 3, 2024 at 9:50 AM
    JAGCanada
    Canada
    I highlighted the joint that is leaking with a red rectangle below. The joint with the springs is the next joint down stream. The gasket I purchased was part number 90917-06083 which I beleive is the correct part number for that joint. Flange on the cat side of the joint has rusted a lot and is much thinner than it was originally.
  6. Sep 3, 2024 at 10:46 AM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    Before cutting....
    Like others have said...you need to ensure you two flanges are flat. Use a flat block a wood with coarse sandpaper stuck to it and go over each flange until you have clean metal all the way across. Then hit it with Scotch pad to smooth it out. Use the correct gasket and use some Walker Exhaust Sealing Compound (also called acousti/seal)...stuff works great on exhaust systems. Really helps to fill in any pits/crevices/etc.
  7. Sep 3, 2024 at 10:53 AM
    shmn
    Pacific NW
    BTW as for a sanding block I cut a piece 3/4" (or 1/2") thick plywood into a 12"x4.5" block and use a roll of sticky sandpaper like this. Handy for all sorts of sanding jobs where you need a flat, shiny surface. I have 4.5" blocks of various lengths for different job.
  8. Sep 3, 2024 at 11:39 AM
    1owner05
    1owner05 Well-Known Member
    Long Island
    05 black
    I welded mine all the way around. Looks terrible but it’s quiet again. Bought some time.
  9. Sep 3, 2024 at 11:48 AM
    TacoTuesday1
    FL
    Make sure it is installed properly.
    An exhaust shop (if the metal is good) or used is cheaper than new.
  10. Sep 3, 2024 at 11:56 AM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
  11. Sep 3, 2024 at 12:34 PM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    I just did the same thing using this gasket from NAPA https://www.napaonline.com/en/p/EXH31332
    worked fine, and my flanges look worse than yours.
    EDIT: disregard. I did the one on the upper end of the cat, so different part number.
  12. Sep 3, 2024 at 12:46 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I've used that stuff before. It doesn't work great. Your flanges would have to be almost mirror smooth and mated to each other for it to work.
  13. Sep 3, 2024 at 2:48 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Gotcha on the spring bolts, the gasket I got was like a steel wool circle that kinda squished between the flanges.
  14. Sep 4, 2024 at 4:45 PM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
  15. Sep 7, 2024 at 6:09 AM
    JAGCanada
    Canada
    I'm going to cut off the flange and weld in a new one(s). I've got some other exhaust work planned (needs a new muffler and the exhaust manifold is leaking) so when I do that work, I'll address the flanges.
    I found this video of a guy welding new flanges on his Tundra. Looks pretty straight forward.
    https://youtu.be/Rc8EzGsBAAQ?si=CCsT6A8EocAgITPP
