Replacing Drum Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaCZman, Jan 3, 2021.
  1. Jan 3, 2021 at 3:16 PM
    TacomaCZman
    TacomaCZman [OP] Well-Known Member
    San Antonio, Texas
    2022 Tacoma SR5 Pre-Runner 3.5L 4x2
    LoadedTaco did an awesome video on replacing front rotors and pads. There doesn't seem to be any videos on replacing drum brakes, shoes, hardware etc.
    I have found several YouTube videos that are helpful, but would love to have access to someone on the forum for this.
  2. Jan 3, 2021 at 3:27 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I don't know where to find a good video other than youtube but if and when you decide to tackle these yourself, do yourself a favor and ONLY disassemble and redo one side at a time. That way, you have the other side for reference when you're reassembling.
  3. Jan 3, 2021 at 3:51 PM
    TacomaCZman
    San Antonio, Texas
    “ONLY disassemble and redo one side at a time.” Good advice.
  4. Jan 3, 2021 at 4:01 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    https://youtu.be/n2h_kzSmAgU
    Also while your there pull the boots back on the wheel cylinders and make sure they are dry inside, if fluid comes out they need to be replaced.
    BassAckwards and TnShooter like this.
  5. Jan 3, 2021 at 4:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    These diagrams should help.
    I stole the pics from @Jimmyh
    His link to the adjustment for the rear brakes is below.
    Remember to back the adjuster OFF before trying to remove the drum.
    Don’t have the parking brake set.
    Do 1 side at a time. Use the other side as a reference.
    Pop the plug out to back the adjuster off.
    Do the opposite of shown below to back the adjuster off.
    (I do this because the drum may have a lip worn into it after 100k + miles. This lip can catch on the shoes if you don’t back the adjuster off. The adjuster is self adjusting AFTER your initial adjustment.)
    The adjuster is circled below.
    You can also use this as a parts diagram / reference
    Once you are finished be sure to adjust the shoes.
    https://www.tacomaworld.com/threads/are-my-drums-out-of-round.567349/
  6. Jan 3, 2021 at 4:12 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There are threaded holes in the drums that will except a 6MM bolt but you need to do everything you can to make sure the drum is ready to come off PB blaster etc. even a torch to heat around the axle. When my 2011 was new I removed the drums and coated the flange with anti seize knowing one day I would have to get them off.
  7. Jan 3, 2021 at 4:15 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Good advice on backing off the adjuster to help removed the brake drums.
    TnShooter likes this.
