Replacing Camburg Upper Uniball Arms, any suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greg617, Dec 16, 2015.
Replace bushings/bushing sleeves & uniball or entire upper arm
  1. Only replace bushings/bushing sleeves & get a new uniball from camburg
    7 vote(s)
    63.6%
  2. Purchase uniball upper control arm - Camburg ($699)
    0 vote(s)
    0.0%
  3. Purchase uniball upper control arm - Tough Country (around $470)
    2 vote(s)
    18.2%
  4. Purchase unball upper control arm - Total Chaos (around $700)
    2 vote(s)
    18.2%
  5. Replacement Camburg CA kit - $320
    0 vote(s)
    0.0%
  1. Dec 16, 2015 at 9:02 PM
    Greg617
    Greg617 [OP] Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    The Camburg upper arms on my truck are really rusty and require replacement soon. I can hear them rattling when I hit minor bumps, but only when the windows are down. I've need to get my truck inspected soon, and these rusty upper arms are going to be an issue. I've got somewhere around a 2.5 inch lift, so putting the originals on isn't an option. Any suggestions on what I should look into? WP_20151207_13_20_18_Pro.jpg
  2. Dec 16, 2015 at 9:04 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    What exactly is worn out ? Just the uniball ? If so there is no need to replace the whole arm just get the uniballs pressed out and replaced.
  3. Dec 16, 2015 at 9:21 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I wish it was just the uniball, those are covered by a lifetime warranty. The bushings are pretty rusted out as well. WP_20151207_13_20_32_Pro.jpg WP_20151207_13_21_08_Pro.jpg
  4. Dec 17, 2015 at 4:52 AM
    Mavrick
    Mavrick Well-Known Member
    2015 DCSBOR
    Yuk, I'd replace them but call Camburg and see if you can get a deal on another set and show them your pictures.
  5. Dec 17, 2015 at 6:53 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Poly bushings and the bushing sleeves are cheap just replace them. Do you have any good shops around you ? There is no need to spend $600 on new arms just replace the uniballs and bushings, they are consumable items that need to be replaced as they wear out.
  6. Dec 19, 2015 at 3:12 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I wish that I could just replace the bushings and uniball. However, the condition of the uniball socket is an issue as well. Replacing the uniball would probably not fix the problem. There would still be a slight gap around the uniball and the rattling would still occur.
  7. Dec 19, 2015 at 3:32 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
  8. Dec 19, 2015 at 3:52 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
  9. Dec 19, 2015 at 4:07 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    If you only have 2" of lift, you could go back to MOOG arms. The benefit is that they do not require much maintenance, which it looks like your existing ones lacked. It's mostly a matter of being able,to get the alignment back to spec. If you off-road a lot, I would definitely get the uni arms for strength and articulation, but ya gotta flush em out and lube em! They will last a pretty long time if you do.
  10. Dec 19, 2015 at 4:23 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    They just look dirty as hell. I don't see why they can't just be replaced. Just because the outside looks like hell doesn't mean the inside does. I've torn motors apart that looked like they got dragged through a herpes encrusted battlefield that looked brand new on the inside.
  11. Dec 19, 2015 at 4:32 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    Thanks for the input everyone! I am going to contact camburg again first thing monday and find out how much replacement parts would cost. I'll share my concerns with them that replacing the uniball will only fix half of the problem, since the CA uniball socket/attachment point it in rough shape also. A new uniball would probably still rattle around in the CA socket.
  12. Dec 19, 2015 at 9:48 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Where did you hear that? I thought uniballs were a wear item with these LCA's?
  13. Dec 19, 2015 at 9:52 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I heard that from the previous owner of the truck, and confirmed it by contacting camburg and sending them pictures.
  14. Dec 19, 2015 at 9:53 PM
    Iggy
    Northern CA
    Check out the build
    Well damn! I need to call them to get a replacement set as well.
  15. Dec 19, 2015 at 10:03 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    yeah, you absolutely should. I don't understand why the uniball is exposed, making it more susceptible to rust/wear. Camburg makes caps ($40 for a pair) but apparently they are not compatible with the uniball CAs.
  16. Dec 19, 2015 at 10:06 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I think thats why i needed to send pictures before i could get a straight answer. The guy i talked to said that every case is different, implying that not all uniballs are covered by their lifetime warranty.
  17. Dec 19, 2015 at 10:23 PM
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    Just keep the uniball clean. I swapped Camburg BJ arms for uniball 2 months ago. A few days in the mountains and I didn't wipe em off after. Should have. After getting around to washing truck today found this :eek:
    Just superficial, elbow grease got me this
    I always heard, but now I KNOW uniballs take a bit more cleaning/maintenance. Just wipe em down after harsh conditions and keep some tri flow handy.
    I got new bushings/sleeves with my new arms. Old ones have roughly 12k on em, in great shape. Yours for $25 shipped. I think they're $60 plus shipping from Camburg...
  18. Dec 19, 2015 at 10:24 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    I have followed that link, and in bold it states that "These do not fit uniball upper arms and can not be made to fit." Thats gonna be a problem.
    The video you posted was extremely useful, thank you for finding that and giving me hope that I may be able to fix these CAs and save myself some coin.
    T4RFTMFW likes this.
  19. Dec 19, 2015 at 10:26 PM
    BudMan
    Bret
    06 TRD Sport DC 4x4
    stuff
    Yeah sorry @DoorDing, those don't work with the uniball. When I swapped over my BJ arms I tried to fit the cap. Not even close.
  20. Dec 19, 2015 at 10:28 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    Thanks for the offer, I could be interested. Ill let you know once I talk to camburg again on monday.
