Replacing Brake Drums But Not Shoes
Discussion in '1st Gen. Tacomas (1995-2004)' started by joelh, Jun 5, 2023.
  1. Jun 5, 2023 at 3:29 PM
    joelh
    joelh [OP] Frequent DIYer
    2002 Toyota Tacoma 2.4L 4WD
    I just got one brake drum off my '02 Tacoma that was a PITA, and the other side is still seized on. Working on the second this weekend. Both drums have jacked bolt holes so I can't use the bolt method on either. Thinking to just replace these drums now so that I can use the bolt holes again if they ever seize onto the hub again (but I won't let that happen).
    Question:
    Is there any issue I should consider when replacing the drums only but not the shoes? The shoes still look pretty good, and I was thinking about using them for another 20k+ miles with some new drums. Then maybe replace the shoes in 2-3 years.
    I can think only of one consideration, and that is the rear brake hardware could probably benefit from being replaced sooner than later (even if the shoes are still good). So there is an argument I guess to do the hardware and shoes along with the drums.
    1997TacomaSR5 likes this.
  2. Jun 5, 2023 at 3:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You did back the adjuster off before attempting to remove the drum?
    Those threads in the drum are not meant to handle much force they will strip real fast .
    i don`t think I every used them.
    If I pull the drums new shoes and hardware are a given.
    Then perhaps you only drive less then a few thousand miles in a year.
    Do what works best for you it is your truck .
  3. Jun 5, 2023 at 3:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Common issue for years. Use a small drill, bore small holes as close as you can to the axle in the drum get out your propane torch and hope for the best. If and when you get them off pound the anti seize to the drums and axle. What is a "jacked" bolt hole"? The drums are threaded but very thin they won't stand just the bolt with out some help. Rear brakes on a Toyota last a long time.
  4. Jun 5, 2023 at 3:51 PM
    joelh
    Guess that's one of those you have to ask cause you never know who you are talking to. Yep, backed off the adjusters 100%. When I started to remove them, they probably hadn't been removed for over 100k. That won't happen again. I agree, those threads are iffy - mine were bad from the get go and just not helpful. Too much water and time.
    Sure, I know I can just decide, and it's only a matter of buying the new shoe kit now or later. I was just wondering if there was actually some mechanical reason to replace the shoes at the same time. If I think about it for too long, it probably just means I need to replace the shoes and hardware for peace of mind.
    Bivouac[QUOTED] likes this.
  5. Jun 5, 2023 at 3:53 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I would recommend you do everything. Drum brakes are cheap and you don't want to replace just the drums and create wear from those shoes just to replace them with different shoes which can create noise. Make sure you adjust the shoes inward before you attempt to pull them off as there is a rust/ wear ridge the shoes will catch on if not adjusted inwards.
  6. Jun 5, 2023 at 4:01 PM
    hitch2.0
    hitch2.0 Member
    2012 Grey Tacoma V6 Double Cab
    I recently bought a generic drum brake hardware kit for $10 at AutoZone, but any of the part stores should have them. It will come with all-new hardware and springs for both sides and you'll probably have some left over. I'd consider grabbing one if $10 doesn't hurt ya right now. Plus, fresh springs make things a lot easier when you're reinstalling all of the drum components.
  7. Jun 5, 2023 at 4:03 PM
    joelh
    It's never happened to me before because I take mine off more often and use anti-seize, but now that I am tasked with maintaining this truck I have to get these drums off. I tried the torch already but ran out of propane. Will refuel and try more. "Jacked" bolt hole just means it was bad to begin with... the threads were corroded and unusable. Couldn't even begin to thread a bolt.
    Since I got the drum off one side already, I can see the shoes are still fairly thick and this truck is at 237k with probably originals. And I measured the drum I removed... still good. So it's not a safety concern, more of a "get the drum the hell off the hub" concern. When the day comes that I know for sure I am replacing the shoes, I'll be stuck with this then, so may as well do it now.
  8. Jun 5, 2023 at 4:09 PM
    joelh
    Probably should. Just started feeling lazy and cheap I guess, because I did so much vehicle maintenance already the last 2 months. I have 2 trucks and a 4Runner and been going to town on them with maintenance and upgrades.
    On the first drum, after ensuring the adjusters were fully retracted inward - it still wouldn't come off. When the first drum finally came off after a lot of hard work, it didn't seem like there was a ridge or lip. So maybe the second one does have a lip/ridge or maybe it is just REALLY seized on. I wish the adjuster would go in just a little bit more!
  9. Jun 5, 2023 at 5:00 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Put old wearable parts on new parts? THE HORROR!
    :p
    I just did rear drums and shoes a few months ago, spring for the shoes, they're not that expensive. They may look good, but get them next to a brand new set. I couldn't bring myself to put old shoes on brand new or refurbished drums.
    joelh[OP] likes this.
  10. Jun 5, 2023 at 11:06 PM
    Bivouac
    I resorted to cutting drums off a few times in my day.
    I think more tired and burnt out .
    When it gets old it is no longer fun .
  11. Jun 5, 2023 at 11:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally, you want to the shoes and drum to wear together as one.
    Sure, you can replace just the drum. If you have an issue, it will be with the new shoes when you install them later. You might have wear issues and/or noise as the new shoes wear to an already worn drum.
    You might have no issues at all. The choice is yours.
    joelh[OP] and Bivouac like this.
  12. Jun 6, 2023 at 1:36 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Use a 3-4 lb metal headed mini sledge hammer and beat on it and it will come off - a dead blow plastic hammer is useless in this fight.
    1997TacomaSR5 and wayupnort like this.
  13. Jun 6, 2023 at 7:06 AM
    joelh
    At this point I am probably going to beat the hell out of the drum or cut it, and will have to replace the drum and do the shoes with it! :)
  14. Jun 6, 2023 at 7:25 AM
    joelh
    Already been using PB Blaster and a 4 lb. sledge to hit around the hub contact points and also coming in from the sides of the drum. But when I get back to this on the weekend I think I am going to step up the force of the pounding a bit knowing that I will just be replacing everything. Only concern at that point is tip-toeing around the studs with the sledge.
  15. Jun 6, 2023 at 7:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If I were you I would consider Genuine Toyota Parts when buying brake shoes. I've had too much heartbreak using brake shoes outta OReilly and the other non-OEM parts stores.
  16. Jun 6, 2023 at 7:40 AM
    joelh
    I think I'm okay buying buying brake drums that aren't Toyota Parts, but I am more likely to buy Genuine Toyota brake shoes. Generally I don't like using the chain auto part stores, and if I do use aftermarket parts I typically scrutinize them well and order online. I'm a bit more open to some of the parts stores than others, like Napa has always done me better than O'Reilly.
    Cucvfan and Bivouac like this.
  17. Jun 6, 2023 at 3:31 PM
    rocknbil
    Bill
    I think the PB Blaster and wait is going to work for you, let it soak, squirt it again every now and then. I had a fun time with my tie rod ends replacing LCA's and ball joints:
    In other news, I hear a mix of ATF and acetone beats out almost any commercial penetrating oil. I was just too tired to try it LOL
  18. Jun 7, 2023 at 10:09 AM
    hitch2.0
    hitch2.0 Member
    Once you have the wheel off, just put the lug nuts back on each stud to protect the threads incase you accidently catch one of them with the sledge. Then hit that mofo hard. Might take 10-20 minutes, but it will come off.
  19. Jun 7, 2023 at 11:18 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Pb soak for a day...
    Then torch and one of these bad boys.....unfortunately I dont even have one....yet...
  20. Jun 7, 2023 at 11:21 AM
    O'Silver_Taco
    MD
