Replacing AC Compressor or recharging AC on 3rd Gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tbrady, Jun 30, 2021.
  1. Jun 30, 2021 at 11:46 AM
    tbrady
    tbrady [OP] Member
    Hi All,
    Dealer just quoted me $1974 to replace the AC compressor in our 2016 TRD Sport. That seems outrageous expensive to me. I tried getting a Toyota specialty shop to do the repair but they said they can't do it because it requires the new 1234yf refrigerant. I've done a compressor swap and recharge before but that was on a vehicle 10 years old that still uses the R134.
    Has anyone tried replacing the compressor and/or recharging their AC on a 3rd gen Tacoma?
    thanks
    tim
  2. Jun 30, 2021 at 12:26 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Have the other shop swap the compressor then have Toyota recharge it.
    hiPSI and shakerhood like this.
  3. Jun 30, 2021 at 12:30 PM
    JZinNM
    JZinNM Well-Known Member
    Southlake, TX
    2016 TRDOR DCLB
    Is 1234yf that hard to find? I surfed some up pretty quick on line.
  4. Jun 30, 2021 at 12:37 PM
    JZinNM
    Southlake, TX
    2016 TRDOR DCLB
  5. Jun 30, 2021 at 12:39 PM
    tbrady
    tbrady [OP] Member
    No, it's not that hard to find and I don't quite understand why the shop couldn't do it. I also asked them about replacing the compressor and having Toyota charge it but there was something about damaging the compressor if I drive it w/o having it charged. I'm really not sure... This Toyota shop is very highly related so I assume there is some kind of complexity that I'm not aware of.
  6. Jun 30, 2021 at 12:41 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The ECU knows the pressure in the lines, won't activate the clutch to spin the compressor and cause damage. Find another shop.
    jmneill, hiPSI, OpelGT and 1 other person like this.
  7. Jun 30, 2021 at 1:51 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    if the system is not empty the after market shop will need something to recover it into. there r134a machine will not take it and if they try to it will contaminate the machine and it will lock down and then it will need to be cleaned. if the system is full you are saving over 150$ in Freon that will just be sucked out and reinstalled. most body shops should have a 1234YF machine. they may be able to install it for you
    bbartol likes this.
  8. Jun 30, 2021 at 1:57 PM
    tbrady
    tbrady [OP] Member
    Thanks guys! I'm seriously thinking about just doing this myself. I got the service manual and I don't see anything that looks overly complicated to change that compressor. I did see though that the service manual states in multiple locations not to run the engine without refrigerant as the oil alone is not enough for lubrication. I hooked up techstream and it's showing B1422 (Compressor lock).
    Can anyone think of a reason that I should steer clear of this that I'm not aware of?
  9. Jun 30, 2021 at 1:59 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The only thing that I would say, is visually look at it on the truck. Could be a pain to get to bolts etc.
  10. Jun 30, 2021 at 2:00 PM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Not sure if this is relevant but compressor seal failed on my gen 2 Taco about 4 years ago and all the refrigerant leaked out. Since there was no pressure in system, compressor will not engage so there was no problem operating truck. Ran it empty for two years and replaced with aftermarket compressor and had refrigeration shop vac. and recharge it.
  11. Jun 30, 2021 at 2:08 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    If you don't have a recovery machine that capable of pulling a vacuum, charging the correct weight of refrigerant and oil you're wasting your time.
    The new refrigerants are really fickle about the charge being correct. I realize this will be an unpopular opinion, but just ask your self what your time is worth given the high probability of failure.
    I'm normally not for regulation, but I think the EPA should ban the sales of all refrigerants to the general public. There's too much fuckey with shade tree mechanics and this stuff
    hiPSI likes this.
  12. Jun 30, 2021 at 2:21 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If it was me, I'd still change the part myself, then go somewhere for a recharge. They are finicky about charge and I've never been successful doin it.
  13. Jul 2, 2021 at 11:12 AM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2017 TRD Off Road DCLB
    V-LED low and high beam headlights. OVTuned
    R1234yf is very hard to recharge. The machine that does it goes through a very long process to ensure it is charged correctly. Zero moisture can get in and it has to be pulled to a deep vacuum before charged. I believe such systems are equipped with pressure sensors to ensure it has been done correctly. Someday maybe we will go to R600a or even better R290!
  14. Jul 2, 2021 at 11:28 AM
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    You can charge an r1234yf system with r134 if you vacuum and flush the system well before hand. The oil is compatible with r134a as are all the parts. The expansion valve won’t be quite right but you won’t be able to tell much difference.
    Downside is the full amount to charge will have to be done by trial and error.
    this isn’t too bad. I’ve been charging custom systems on classics for years. There are some good articles on how to read the gauges. Once the ac is cold enough for you it’s close enough really.
  15. Jul 2, 2021 at 11:34 AM
    Itchyfeet
    r1234yf is way too expensive to play trail and error
  16. Jul 2, 2021 at 11:49 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Read what he said again Itch...r134 is cheap.
    Is the MINI forum really that boring?
    auskip07, hiPSI and 9th like this.
  17. Jul 2, 2021 at 1:40 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I thought mini coopers were pretty cool. But this was in the 70s when I was in Europe, and they were Coopers... We used to joke about crushing them with tanks, and 5 ton utility trucks.
    G8R_Taco[QUOTED] likes this.
  18. Jul 2, 2021 at 1:45 PM
    Itchyfeet
  19. Jul 2, 2021 at 1:55 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
  20. Jul 2, 2021 at 1:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yeah. I just pur a new ac compressor on my buddy's wife's CRV as he is now in hospice. What a pain in the ass. Another buddy had access to machines and gauges and we all banded together and did it for free.
    vivid02, Skydvrr and G8R_Taco like this.
