replacing a windshield wiper switch on an '03 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyoManX, Feb 6, 2017.
  1. Feb 6, 2017 at 2:34 AM
    ToyoManX
    ToyoManX [OP] Member
    Darrin
    Hi everyone,
    A quick question to those who has got experience in replacing a windshield wiper switch in an '03 Tacoma. I broke mine and believe will have to replace it with an aftermarket one. So I was wondering, is it really just plug-and-play (that's what I've seen in the online video instructions for the other Toyotas)? Or this all requires special tools and skills? Because the vehicle is no longer new, and I would rather save some cash by getting a less expensive replacement piece and by doing the install job by myself...
    Any comments are appreciated!
  2. Feb 6, 2017 at 5:19 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    It is not very hard at all. Just take the two covers off the steeeing wheel. Two screws if you turn the wheel in either direction and two screws on the covers themselves. Once off there are two screws that hold the switch in its place. Once they are out it just pulls out. Then put in the new one and reverse the procedure. I have an extra one as I bought one but that was not my problem but I live in Canada.
    ToyoManX[OP] likes this.
  3. Feb 6, 2017 at 4:08 PM
    D-50Dave
    D-50Dave Member
    David
    Branford, CT
    '98 2WD std-cab
    I did an upgraded to intermittent wipers on my base model '98. It really is that easy. One phillips screwdriver and 15 minutes is all you need. Dave
  4. Feb 7, 2017 at 12:51 AM
    ToyoManX
    Darrin
    Great, thanks for your replies, folks. Then I'll go ahead and order a new switch to get the ball rolling. I decided to get an aftermarket one to save on the part (https://www.carid.com/windshield-wiper-switches/). Hope I will manage to get it in if you say it's not a big deal...
  5. Mar 5, 2017 at 2:35 PM
    GillyMac
    GillyMac Well-Known Member
    Albert
    2004 White Tacoma Xtracab V6
    Hey ToyoMan, did you manage to get the part in, and how does it work? My wiper switch is also in need of replacement and I'd be very interested to know if you had luck with the aftermarket part.
    Thanks!
  6. Mar 5, 2017 at 3:17 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I replaced my switch (worked fine, but didn't have intermittent) with one from a picknpull that had the intermittent feature. Worked perfect. IMHO, old used OEM is much better than new aftermarket.
  7. Apr 12, 2017 at 12:41 AM
    ToyoManX
    Darrin
    Hey GillyMac, you know, it worked out just fine! Except of the material quality (it has got slightly different finish than the OE one I had), I did not notice any differeneces. So nothing special about it, just works the way it has to work. Wish you luck in your repair, man!
  8. Apr 12, 2017 at 10:18 AM
    GillyMac
    Albert
