replacing 06 tacoma wheel bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauaitaco69, Feb 2, 2011.
  1. Feb 2, 2011 at 11:27 PM
    kauaitaco69
    kauaitaco69 [OP] Active Member
    hawaii
    06 lifted white tacoma
    k&n intake, 40 delta flow exhaust, 6 in. lift, 20" centerline eclipse wheels with 33x13.5 iroks, pioneer deck, alpine type s components, one 12" alpine type R and 1000 watt alpine v-power amp.
    hey guys I really need some help. i have a 06 tacoma and my front wheel bearings just went out. i was wondering if anyone has any instructions on how to replace front wheel bearings, or any pictures, or a break down. any type of pictures or instructions would help
    Thanks
  2. Feb 3, 2011 at 4:19 AM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    On 4wd the bearings are pressed onto the hub. You have to remove the caliper and rotor. Then you'll need to loosen the nut on the cv axle then disconnect the abs sensor. After that there are four bolts that you need to loosen on the spindle and then you will have to get the hub/bearing assembly off the spindle hammering should work. After all that it gets a little complicated. The bearing and hub are pressed together, oh yea don't forget to take the age sensor out of the spindle before you remove the hub. You are gonna need a press to get the job done from here. I found this part to be kind of difficult I had a hard time trying to figure out how to get the two separated because it's in a tight spot. I know that some people have cut the bearing off of the hub but you have to be careful not to cut thru the actual hub. Once you figure out how to get the bearing pressed off the hub there is a seal that goes between the hub and the bearing that you need to install before you press the new bearing on the hub, and don't forget to put the bolts in the holes before you press the bearing all the way on or you'll be in trouble. In total I replace two seals when I did mine the one in between the bearing and the hub and then there is one that is on the other side of the spindle that I replaced. Install is just the reverse of disassembly. I got the replacement bearing from oreilly and I got the seals from the dealer, but I tool the seals to oreilly and cross referenced the numbers so now I can get seals from the parts store instead of the dealer. I don't really have any pics but it's pretty self explanatory once you get in there. I hope this helps you out, if you have a 2wd then I hope you know how to change the bearings on a 4wd and your still in the same boat. Good luck. If you have any more questions let me know.
  3. Feb 3, 2011 at 8:54 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If you have a press and remove the entire spindle from the truck it's pretty easy. The spindle can be used to hold it in place while you press the hub out. Last one I changed a few months back took me an hour and fifteen minutes start to finish. If you don't have a press and you just remove the hub/bearing as an assembly whoever takes it apart is going to have a hell of a time getting the hub out. Might as well just buy a new hub and 4 bolts and assemble it without reusing anything. That's how the local dealer here does them all.
  4. Feb 3, 2011 at 8:56 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    You could buy a brand new hub from rockauto i think for pretty cheap. I have to replace my bearings and I am just going to go with a new hub instead of pressing and messing with that.
  5. Feb 3, 2011 at 9:38 AM
    pinchetaco
    Winston Salem, NC
    I think the only place you can get the actual hub is from the dealer and it's like 200 dollars plus like 50 for the seals you can get the bearing for 100 from oreilly
  6. Feb 3, 2011 at 9:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    TIMKEN Part # BM500007 [​IMG] {#BM500009} Tapered Bearing; Rectangle Flange Shape
    4WD; Front
    $68 at rockauto.com. Use the member discount and receive 5% off (check their vendor section).
    This will need pressed on and off. Be sure to save the oring and dust boot off the old one.
  7. Feb 3, 2011 at 9:46 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Check this issue of Tacoma Magazine for a full How-To on front wheel bearing replacement.
    Tacoma Magazine
    Includes part number for wheel bearing at your local O'Reilly
  8. Feb 3, 2011 at 8:41 PM
    kauaitaco69
    hawaii
    hey thanks guys for all the help
  9. Feb 5, 2011 at 6:59 AM
    85GT 79FJ40
    Ken
    New Hampshire
    That article is pretty good but it doesn't address the cause for these actually failing. The seal on the back of the spindle tears and lets water into the bearing. Most people change their bearings without taking the spindle off and I suspect that's why some people who wheel their trucks are right back in there before long. Also if you take the entire spindle off you can use it to hold the bearing/hub assembly in a press which makes taking the hub out really quick and painless with no grinding and no chance of damaging the hub.
    Key-Rei likes this.
  10. Feb 5, 2011 at 7:21 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    So if you replace the hub, it's just a bolt-up situation?
  11. Feb 5, 2011 at 7:26 AM
    85GT 79FJ40
    Ken
    New Hampshire
    If you bought a bearing and a new hub, seal, and 4 bolts from Toyota you could press it together (or have them do it for you) and it would be a completely bolt-in deal. But that's probably $250 worth of parts for one side. I haven't seen anyone selling them assembled yet though. Also like I mentioned if that inner seal is torn you are going to be right back in there pretty quick unless you remove the spindle and change it.
  12. Feb 5, 2011 at 7:30 AM
    90YotaPU
    Union County, NJ
    Gotcha, none of mine have gone bad. Just been seeing a lot of conversation about it lately and was getting curious.
  13. Feb 20, 2011 at 7:13 PM
    hambone887
    hambone887 New Member
    Eric
    colorado springs
    05 DC 4WD
    i have a question i have took the bearing and spindle to two shops and both of them day they cannot get them off they say the press slip i tried using a 3 jaw gear puller and it broke the puller any ideas here
  14. Feb 21, 2011 at 1:10 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
  15. Feb 21, 2011 at 3:06 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    toyota cut mine off when they replaced my passenger wheel bearing
  16. Feb 21, 2011 at 4:30 AM
    pinchetaco
    Winston Salem, NC
  17. Nov 2, 2014 at 9:59 AM
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    Hey guys, I am old and slow and confused!!!
    I am needing to replace the LF wheel bearing on my 08 4wd, I got the outer bearing out by cutting out two of the bolts and was then able to place two half inch steel bars across my press and pushing the hub out. BUT what about the other (inner ) bearing ? I dont see any way to hold the inner race and press the hub out???
    HELP
    Thanks,
    alpinebob
  18. Nov 2, 2014 at 10:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    You will need a bearing splitter to pull the inner race off the wheel hub. I have had a few that gave me trouble and ended up cutting into it some before it would release. It is a hit-miss sometimes on those. I suggest against using direct heat from a torch, but you can try putting the whole thing into an oven at 350-400 degrees for 20 minutes and trying again. If you give up, I sell the entire unit, ready to install, for $170. But I think you can do it, it just will take a little time.
  19. Apr 23, 2022 at 8:55 PM
    PaCific-TaCo
    PaCific-TaCo Member
    2006 TRD Sport
    bringing back an old thread, I just pressed the hub back into a new bearing today and now it's stuck.
    I pressed the bearing back a little bit it spins freely with no strange noises but there's too much play.
    I really can't figure out what I did wrong here there's not much to this?
  20. Apr 24, 2022 at 10:14 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have no idea. Is there any reason you didn’t just do the whole assembly?
    Buy the time you press the old out/ in and off/on. Buying the whole assembly senses easier to me?
    Hopefully someone that’s disassembled the hub can help. But I’d say very few here have done it. I know one member here builds them. Maybe he can help?
    Raylo likes this.
