Replacement Tire Iron Set
Discussion in '2nd Gen. Tacomas (2005-2015)' started by usadaytrader, Sep 19, 2022.
  1. Sep 19, 2022 at 10:12 AM
    usadaytrader
    usadaytrader [OP] Well-Known Member
    I am missing one of the extensions for the tire iron kit for my 2005 tacoma. The old set is a bit rusty and the dealer wants over $30 for one extension, so I am looking for a newer aftermarket set.
    Seems like all the aftermarket ones look like junk. With twisting metal etc. Anybody have any good luck with a quality made aftermarket set, or should I just cough up the dough at the dealer?
  2. Sep 19, 2022 at 10:16 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    IMO, what you should really do is throw the rest of it away and get a decent (not even great) floor/trolley type jack and a 2 foot piece of 2x(6/8/10/whatever) to sit it on and a 4 way tire tool and keep it in there. If it makes you feel better, put some 1x2s around the edge of the 2 x whatever to stop the jack from rolling, even though it wont after it's engaged with the truck......unless the whole truck rolls.
  3. Sep 19, 2022 at 12:37 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I haven't found a good, affordable solution either. But, I would recommend looking for a full replacement from a 3rd gen. The extensions on the 3rd gen are much nicer - they snap together with little spring loaded pins (like an ez up, or handle of a pool net) rather than the thumb screws which have about a half thread and strip immediately.
    Unfortunately, I haven't found an affordable source for the 3rd gen kit. I assumed there would be tons of people willing to sell take offs from their new trucks but that doesn't appear to be the case.
  4. Sep 19, 2022 at 1:03 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The spring pin things must have happened in the 2.5 gen (2012+) as mine has that style. So you guys can probably search ebay for the roadside tool kit for a 2012 and later if you want that style.
    wi_taco likes this.
  5. Sep 19, 2022 at 1:24 PM
    clenkeit
    Colin
    Lakewood, CA
    Good to know, thank you!
