Replacement stainless hardware - OEM Roof Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Speeds4Ever, May 5, 2022.
  1. May 5, 2022 at 8:44 AM
    4Speeds4Ever
    4Speeds4Ever [OP] New Member
    Drew
    2019 Tacoma TRD OffRoad
    Howdy all - long time lurker, formally created an account to join in the fun.
    I did perform a search - no salvation for answers to my issue. I ordered an OEM roof rack for my '19 TRD Off-Road to carry canoes and kayaks on local family adventures. I installed it reasonably successfully with no leaks (yet), however a lot of the OEM allen bolts stripped like they were made of freaking room temperature butter and I wanted to just yank it all and replace with 316 stainless hardware and RTV up all the holes to make sure it'll stay dry and trouble-free in the long term.
    My question to the throngs: does anyone have the specs on the bolt sizes and thread pitches for the OEM roof rack, or am i stuck pulling it apart and bringing all the parts to the local Fastenal?
    TIA for any help.
    -Drew
    averagejp likes this.
  2. May 5, 2022 at 9:11 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    If the supplied fasteners were that weak I would stay away from them completely. I surmise better fasteners from an outfit such as Fastenal should be a fairly inexpensive solution.
  3. May 5, 2022 at 9:28 AM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    I totally feel you. I had heard that those bolts were pretty soft so I went really slow and gently and still managed to strip a few. If you can get a hold of the install instructions (which are terrible, by the way) it lists all of the hardware and the sizes. I took that to a local specialty screw shop and they pulled them together with no problem. None of the big box stores will have those bolts, from what I found.
    See if this helps ...
  4. May 5, 2022 at 10:13 AM
    4Speeds4Ever
    Drew
    YOU, SIR....ARE THE MAN!! that paperwork went bye-bye long ago. Many thanks!
    averagejp[QUOTED] likes this.
  5. May 5, 2022 at 11:08 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    From what I remember Lowes had them in stainless, in the special fastener drawers, when I replaced mine.
  6. May 5, 2022 at 1:34 PM
    averagejp
    Work in progress
    No problem. To be fair, I found that on another forum post and did a screen shot. But I did keep my install instructions if you need them.
  7. May 5, 2022 at 1:36 PM
    averagejp
    Work in progress
    Right ... I wanted them in black ... but they didn't have the button heads, if I recall. I got them from this crazy place that carries every screw in the world, apparently. It was bonkers. I walked up to the window, gave them the list and they came back with all of the screws and it cost like $4. I felt so fortunate I gave the guy a $5 to get a cup of coffee. :)
    Link:
    https://www.metricmcc.com/
    2016Tacoman[QUOTED] likes this.
