Replacement Serpentine Belt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TS4x4, Sep 27, 2023.
  1. Sep 27, 2023 at 5:19 AM
    TS4x4
    TS4x4 [OP] Well-Known Member
    2018 TRD Offroad
    Hey all, as the title says its time for me to replace my serp belt. I'm at about 85k, and Toyota recommends replacing it at/before 100k. I wheel pretty frequently so I figure its best to do it sooner rather than later.
    Just trying to confirm that this will fit?
    https://www.amazon.com/Goodyear-1070835-Serpentine-7-Rib-Length/dp/B08SNP9HP3?crid=2GL9XB54M8D8U&keywords=2018+toyota+tacoma+serpentine+belt&qid=1695816931&replacementKeywords=serpentine+belt&sprefix=2018+toyota+tacoma+serp%2Caps%2C82&sr=8-1&vehicle=2018-76-1037------------&vehicleName=2018+Toyota+Tacoma#customerReviews
    Thanks in advance
  2. Sep 27, 2023 at 5:31 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Is says it fits 3rd Gen Tacos, so what is your concern?
    Stevie17 likes this.
  3. Sep 27, 2023 at 5:32 AM
    TS4x4
    2018 TRD Offroad
    Amazon being amazon lol. I was looking at some 33in AT tires on there the other day and it said they were only 35lbs which was definitely wrong. Just want to be sure before I commit to the job.
    lacab100 and Stevie17 like this.
  4. Sep 27, 2023 at 6:01 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It lists interchange with 7PK2121, while Rock Auto lists the appropriate belt for the 3.5 as 7PK2120. The Goodyear belt is about 0.15 inch longer than the Bando belt (Bando being the typical OEM supplier for Toyota).
    Stevie17 and TS4x4[QUOTED][OP] like this.
  5. Sep 27, 2023 at 6:04 AM
    TS4x4
    2018 TRD Offroad
    Thanks, this is what I wanted to double check. You think it will be okay if I just adjust the tensioner pulley?
  6. Sep 27, 2023 at 6:06 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The tensioner pulley is spring-loaded; nothing you can adjust. I don't know if 0.15" extra length would bottom out the tensioner (and cause slippage with the power steering pump, etc.).
    You see TW's Amazon affiliate link at the bottom of this page? The Bando belt is cheaper and likely better quality.
  7. Sep 27, 2023 at 6:12 AM
    TS4x4
    2018 TRD Offroad
    Interesting because it's saying that one doesn't fit:
  8. Sep 27, 2023 at 6:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  9. Sep 27, 2023 at 6:16 AM
    TS4x4
    2018 TRD Offroad
  10. Sep 27, 2023 at 7:04 AM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Trust me just buy one from Toyota from sparks parts or another dealer with best deal. My OEM serpentine belt lasted me 140k before it started squeeling then i put on an aftermarket premium belt im pretty sure from Gates or Bando and it started squeeking horribly after 15k.. already replaced it with an OEM and no issues since
    MannyS and Stevie17 like this.
  11. Sep 27, 2023 at 7:06 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Stevie17, CLVol1255 and LeakyAC like this.
  12. Sep 27, 2023 at 7:36 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
  13. Sep 27, 2023 at 8:52 AM
    TS4x4
    2018 TRD Offroad
    I ended up ordering the goodyear one. It's the same length once you convert the Bando one to inches. 2120mm = 83.46in. Only off by 0.04in or 1mm. I think it will be fine
    TA2016 likes this.
  14. Sep 27, 2023 at 9:15 AM
    TA2016
    Oregon
    If you get the old belt off without cutting it, keep it in the truck in case the new one breaks on the road. Here is a video you may find helpful. The guy leave the video running in real time so you see how long it takes.
    https://www.youtube.com/watch?v=sv5fAcT0JAY
    TS4x4[QUOTED][OP] likes this.
  15. Sep 27, 2023 at 10:40 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    It’s an easy install took me an hour the first time and about 40 minutes the 2nd time. Maybe the goodyear will work out for you and last longer than the Dayco one I bought to replace my OEM the first time
    TS4x4[OP] likes this.
  16. Sep 27, 2023 at 4:35 PM
    V64X4 Tacoma
    V64X4 Tacoma New Member
    2022 Barcelona Red Tacoma SR5 V6 4X4
    Stock for now
    Continental belts are about the best you can get in my experience... Dayco is a second choice..
  17. Sep 27, 2023 at 4:38 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    I’m just perplexed why do some people prefer inferior aftermarket parts just to save a few bucks .
    LeakyAC likes this.
  18. Sep 27, 2023 at 4:45 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Did mine… used oem from Toyota. Not something I want to risk a failure on with a cheap belt.
    same logic applies to timing belts on my Ducati. No aftermarket belts, period.
    bulalo likes this.
  19. Sep 27, 2023 at 6:08 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Dayco I used just bc i didn’t wanna wait for the oem to arrive and installed the dayco the day of it beginning to squeak lasted 20k miles for me. Had oem as backup and installed oem and all has been great for the last 7k miles. First oem lasted 140k before squeaking
  20. Sep 28, 2023 at 7:34 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Yall got good luck with your OEM belts. Myself and many other had squealing belts at 30-40k miles. Replaced mine with another OEM at like 38k and still going strong (71k now).
