Replacement rear window of leer topper
Discussion in '1st Gen. Tacomas (1995-2004)' started by Arbguy91, Apr 18, 2022.
  1. Apr 18, 2022 at 7:15 PM
    Arbguy91
    Arbguy91 [OP] Member
    Ian
    02 Tacoma double cab
    I have an 02 Tacoma double cab with a leer topper. The hinge on the top of the window has broken. After talking to a couple topper dealerships, it sounds like I works either need to buy a new topper or a whole back window replacement, both options are too expensive. Any suggestions on how to find another back window assembly or other options? Thanks!
  2. Apr 19, 2022 at 6:39 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Yeah, it's pricey. My Leer 100r ended up with a final bill of close to 600 dollars. Thankfully I had only my 50 dollar deductable to pay as the good ol' insurance came through and covered it. Took like 4-6 weeks for that damn frame/glass to arrive as well. It was April of 2021 so that might have had something to do with it. Supply chains... pfft.
    Your best bet if you aren't going to shell out for a replacement frame/window from a dealer is to scour craigslist or Facebook marketplace for an identical model cap that perhaps has the back door glass busted out. Might luck out and find just the door available.
    That's about your best option. You can't really fab up a replacement hinge since it's part of the frame. Also won't find a supplier who has just the frame in stock... It's a special order thing these days.
    The one thing about caps, extremely limited part availability from non-manufacturer sources. Why I always say never, ever purchase a cap with busted out glass. More than likely, it's NOT a 'deal'.
    Good luck.
    Storm2u and Arbguy91[QUOTED][OP] like this.
  3. Apr 19, 2022 at 7:24 AM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    Arbguy91[OP] likes this.
  4. Apr 19, 2022 at 10:08 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    @Arbguy91
    I had a Leer hinge come loose. It must have stressed the other side when the window was swinging in the wind because about a year later the other side broke.
    As it was 20 years old I did not think to look for a replacement and just made an aluminum replacement.
    Later on a whim I saw this. Oh well at least they are stronger now. Remarkably there was no other damage to the tailgate etc, still can't believe it.
    https://www.google.com/search?q=lee...HaGJIBCjAuMTMuNC0yLjGYAQCgAQE&sclient=gws-wiz
    Replacement carved from a handy piece of 4" alu angle.
    Pics will do the explaining. The "cap side" of the hinge broke clean in two.
    Area51Runner likes this.
  5. Apr 19, 2022 at 10:18 AM
    Area51Runner
    Unless he has the old school hinge shaped like an S running the entire length of the frame which was what I had...errr have.
    :anonymous:
    The frameless windows are much easier :thumbsup:
  6. Apr 23, 2022 at 6:21 AM
    Arbguy91
    Ian
    Thanks for the suggestions!
