Replacement Radiator Options???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ace115, Dec 30, 2017.
  1. Dec 30, 2017 at 6:11 PM
    Ace115
    Ace115 [OP] Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Hey guys, so I have the stock radiator with the pinch seems. Just started leaking significantly this past week. What are some good replacement options other than OEM? Pics too please.... TIA
    Jimmyrace likes this.
  2. Dec 30, 2017 at 6:23 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I got a denso from rockauto for like 120$ shipped and it's been going strong for 9 months.
  3. Jan 6, 2018 at 10:28 PM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Anyone else have a suggestion for something other than the OEM radiator design?
  4. Jan 6, 2018 at 10:35 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Amazon, E bay they have them and I've used both with no issues. Fit was perfect.
    I don't get too worked up on aftermarket radiators. I consider rad's a consumable part. You can change the rad cheaper than getting a fluid flush. Cheap insurance.
  5. Jan 7, 2018 at 3:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can fabricate one can install just about anything .
    I am Old Fashion I like the Copper brass ones I use the same Radiator in Toyota`s from the eighties to 2000
    Running Board Man likes this.
  6. Jan 7, 2018 at 4:12 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Jan 7, 2018 at 5:54 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I went with an OEM one. They aren't made in Japan anymore. They are made in Taiwan. But, a person on T4R.org said he had seen firsthand the quality of the Denso, Koyo and OEM and he said the construction of the OEM definitely looked superior to the other two. So, that inspired me to pay the extra money for the OEM one. It cost around $200 from Camelback Toyota but I figured the extra $100 is money well-spent if it means I'm getting a better constructed radiator. I replaced my radiator just for general maintenance because it was old and I wanted a little extra insurance to avoid a leak or a trans cooler failure (pink milkshake).
  8. Jan 7, 2018 at 6:07 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Denso aluminum radiator. 250 plus shipping. But that was for a 93 with a 3.slow. just had to drill mounting holes.
  9. Jan 7, 2018 at 6:07 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
  10. Jan 7, 2018 at 7:11 AM
    tony2018
    tony2018 Well-Known Member
    I went with the mishimoto because of lifetime warranty. I had to make sure I kept the receipt. Bought it off of Amazon but something was fishy. That chat is for another day.
  11. Jan 7, 2018 at 7:21 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Take that receipt n register it with mishimoto there warranty is great once you register. Used it in a wrx rally i used to run, went through alot of radiators.
  12. Jan 9, 2018 at 9:48 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Are there any options that don’t hang as low as the factory unit? Looking to avoid sticking a tree branch through it if at all possible.
  13. Jan 9, 2018 at 9:49 AM
    tony2018
    You have the lower cover that protects the radiator.
  14. Jan 9, 2018 at 9:50 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I’ve pulled that off prepping for a custom front bumper (tube style).
  15. Jan 9, 2018 at 9:51 AM
    tony2018
    Well look into stainless skid plates if the factory skid plate match your style.
  16. Jan 9, 2018 at 9:57 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    It's longer because it shares responsibility with cooling your transmission.
  17. Jan 9, 2018 at 10:02 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I gotcha. So best to just protect it then? Any pics of the mishimoto rad installed?
  18. Jan 9, 2018 at 10:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you get a parts store one without the auto cooler you might get more clearance down below. I haven't installed it since my engine replacement is taking a back seat to work right now. Before I yanked the motor I checked to see if everything lines up with the bolt holes and it does perfectly. If you're just concerned about how low things hang though, go with a manual trans only radiator if you have a stick.
  19. Jan 9, 2018 at 10:47 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Radiator from a 94 or older pickup is shorter, but mounts differently. Mismo makes am aluminum radiator, just need to weld on the mounts you need. And would need a tranny cooler most if there radiator are made for manual trannies.
    One note on these they are not cheap. It is a race series radiator. So overkill for a dd.
  20. Jan 9, 2018 at 5:03 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
