Replacement of Radiator support
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jer’s Taco, Nov 7, 2018.
  1. Nov 7, 2018 at 5:07 PM
    Jer’s Taco
    Jer’s Taco [OP] Member
    Jeremy
    2002 Silver Tacoma TRD
    Newbie here... Just had some damage done to my front end and wanted to see if anyone has had experience with changing out the radiator support? One of the issues I noticed was the a/c lines running through the old one so I’m guessing the lines will have to be removed and then replaced and then a vacuum on the ac system once reinstalled. Any advice or asssistnace is much appreciated.
    2002 Tacoma TRD 210,500 miles
    ChrisSmith41399 likes this.
  2. Nov 7, 2018 at 8:42 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    C06693B3-E1C9-430B-A3AF-E6082E796F18.jpg You’re taking on a lot. In regards to the ac lines, go to a shop and get the system evacuated. When you put the lines back together replace all the o rings. I recharged mine with the cans from the auto parts store, 6 years later it still works, but I think a shop would have been better.
    You have a welder? Trying to get everything lined up perfectly can be difficult, and I highly recommend getting a quality replacement core support.
    It’s a ton of work, and putting it back structurally correct is pretty vital. I painted it with rattle can sealing primer and paint to try to match the green, but it still rusts through, it really should be painted with epoxy primer.
    ETAV8R likes this.
  3. Nov 8, 2018 at 6:10 AM
    Jer’s Taco
    Jeremy
    Laxtoy, thank you for the reply. I kind of figured it would be a large project. I was trying to bend back what I could, but it was just to beat up. I am planning on borrowing my buddies welder to do the job. I was hoping there was a trick with the ac lines, but as you explained there doesn’t look like a way around them with out disconnecting them. This is just the beginning though, as I have the hood and a bunch of other parts that need replaced. I just don’t want to let this truck go though cause it still runs like dream with 210,000. Once again thanks for the information and hoping the parts will be in by this weekend to start.
  4. Nov 8, 2018 at 7:08 AM
    Jer’s Taco
    Jeremy
    Laxtoy, one more question. When you installed the new one were you able to spot weld it or did you have to tact weld it?
  5. Nov 8, 2018 at 7:47 AM
    Glamisman
    Glamisman Well-Known Member
    I would install it with some pop rivits first then align everything, fenders, hood etc. Do you plan on a mig tack weld or brazing or ?
  6. Nov 8, 2018 at 8:34 AM
    Jer’s Taco
    Jeremy
    Thanks Glamisman, I’m looking at doing a mug tack weld. I know this is going to be a project, but just can’t let this trick go. The rivots sounds like a good idea. Thanks for the info!
  7. Nov 8, 2018 at 8:42 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What a shame! I hope you can get it back to where you want it. :fingerscrossed:
  8. Nov 8, 2018 at 2:56 PM
    Glamisman
    or nuts and bolts so that you can wiggle things around. If the gaps are even and the cross measurments from the firewall to the core support are even I would call it good. Did the insurance total this or you doing this on the side?
  9. Nov 8, 2018 at 2:59 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I replaced the CS on my 04. There are 40 spot welds that need drilled out. Installing you will be plug welding with a mig welder.
    AR15xAR10 likes this.
  10. Nov 8, 2018 at 3:15 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    That needs more than just a rad support, inner wheelhouse and possibly upper rail. Take it to a body shop and put it on the frame machine, have them pull it and square it first. Then you can see what else you will need to change. It's a ton of spot welds, get a spot weld drill bit. If you have never welded on sheet metal, practice first. Use solid wire .025 or. 030. Sheet metal screws work great as to hold the panels in place, then weld them shut after you check fit and gaps. Good luck
    koditten likes this.
  11. Nov 8, 2018 at 5:20 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    OP, @pairodice , @Glamisman and others have given some solid advice. I just finished straightening the one in the pic below. While my frame had almost no deviation, it was still tough getting things close. So, I agree with your direction to replace if $$$ and skill permits. Could be the angle of the pic, but it loos like your frame is bent pretty bad.
    If you take it to a shop before you remove anything, they can understand impact angles and more easily, and effectively, straighten any frame damage. Minimum get very good pics. I used heat, chain and ratchet boomer, tractor, welded chain hooks in several places as pull points,... I got everything close, but definitely not like a professional. It wasn't cockiness, I just wanted to do it on the cheap.
    Also, you are correct AC must be drained. Mine had all escaped, but from previous experience I know some shops will drain them, then when you are ready, you return the vehicle and they only charge labor. Basically, you "get back" whatever volume of refrigerant you deposited.
    CenCalWheeler and koditten like this.
  12. Nov 8, 2018 at 5:40 PM
    Wsidr1
    Indiana
    @Jer's Taco
    By the way, with hood, fender, grille, bumper, radiator, AC condensor, lower valence... but re-using the rad support and CS I am at about $750-800. That's using Rock Auto, Amazon, and others, not dealer supplied parts. No paint as of now.
    I have about 22 hours labor in it.
  13. Nov 8, 2018 at 5:45 PM
    koditten
    Kirk
    Central Michigan
    Holy shit
    Holy shit! That looks familiar!
  14. Nov 9, 2018 at 8:18 PM
    Wsidr1
    Indiana
    @koditten
    No kidding. Not sure how far along you are, but I am getting close to being paint ready. My body panels are pretty well aligned. Hood still needs a little leveling. My main fail is the LH headlight is somewhat recessed due to not getting everything back forward as much as it should be. But, looks pretty good for amateur work.
    This truck may get some suspension, tire/wheel, and bumper upgrades because the frame and under body are in great shape. Most of it's life was in SE Tenn. I bought it wrecked, so I only have about $2200 (plus labor) in it as you see it there: V-6 auto, 4x4, 255,000, manual L/Os, clean title. I feel I can put some more money in it and still be okay.
    Jer’s Taco[OP] likes this.
  15. Nov 10, 2018 at 3:43 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I find the best tool for removing spot welds is a spot weld cutter .
    Years ago I needed to cut numerous ones every day.
    I went with Snap On but by now other brands should be just as good.
  16. Nov 14, 2018 at 7:26 PM
    Jer’s Taco
    Jeremy
    Thank you all for kind words of wisdom. At least I’m not the only one in this boat. I feel like I’m making progress, but still have to work on Getting the bumper, hood, and grill. I was able to use a winch hooked to back of my other truck and square things up. I ended up using bolts, rivots, and my buddy is going to hit some welds in it too. What a job though and it’s been raining here non stop. :rain:
    koditten and Sterling_vH111 like this.
  17. Sep 10, 2020 at 3:36 PM
    Kainsta110
    Kainsta110 Active Member
    96 5-lug 2wd
    none yet
    This is my next project. front passenger damage from deer to humans lol (really need to get a brush guard). No damage to the frame on mine just need someone who can weld after i drill out the spot welds.
  18. Sep 11, 2020 at 2:19 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    After you protect the front of the truck the Evil Deer start running into the side of the Truck.
    Well Known Fact.
    Kainsta110[QUOTED] and koditten like this.
