Replacement Front Seats
Discussion in '1st Gen. Tacomas (1995-2004)' started by mattvivsound, Aug 1, 2019.
  1. Aug 1, 2019 at 11:59 AM
    mattvivsound
    mattvivsound [OP] Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    I have a '01 Tacoma with bucket seats & full center console. I am looking to replace the front seats with something better/more supportive. I know that if its not a Taco seat, it won't be a direct bolt in and some welding is required.
    What seats have you installed and like/not-liked?
    I was thinking of a set of Honda Prelude seats.
    GQ7227 likes this.
  2. Aug 1, 2019 at 12:55 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Why would you buy used seats if you’re replacing your used ones. Order some Corbeu sport seats with their brackets and enjoy.
    1997tacomav6, jackn7, mjp2 and 3 others like this.
  3. Aug 1, 2019 at 1:44 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the bucket seats are not supportive?
    bench seats are probably worse for a longer drive
  4. Aug 1, 2019 at 5:06 PM
    mattvivsound
    Southern MD
    I can pick up a pair of seats from the junkyard for $20-40 each.
  5. Aug 1, 2019 at 5:08 PM
    mattvivsound
    Southern MD
    My truck has a 260k miles... and it's a little beat up. I think the back has a bend in the frame.
    GQ7227[QUOTED] likes this.
  6. Aug 1, 2019 at 5:10 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    WRX seats are a popular choice. Ones from a regular Impreza are also pretty comfy.
    YMMV, I bought some WRX seats but they have a very thick base so my head was in the ceiling because I'm tall. I would consider Integra or Civic seats since they're common, have a thinner base, and should be cheap.
    I put 3rd gen 4runner seats in and they're pretty comfy but I had to do some cutting and welding to fit them
    Davis85WV and GQ7227 like this.
  7. Aug 1, 2019 at 5:55 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  8. Aug 4, 2019 at 10:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
  9. Aug 4, 2019 at 11:00 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    It would be interesting to see how universal brackets from corbeu or someplace else would work in our trucks. The back of the stock seats bolt sideways into the tranny tunnel, not the floor like those brackets do.
    GQ7227 likes this.
  10. Aug 4, 2019 at 11:06 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    GQ7227 likes this.
  11. Aug 4, 2019 at 11:41 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    Corbeau has Tacoma specific brackets... when I look up the ones for my truck, they say:
    The Corbeau Toyota Tacoma seat brackets are manufactured to be a direct bolt in to the 1995-2004 Toyota Tacoma that came from the factory with bucket seats or a 60/40 split seat. Direct bolt in means your bracket will bolt to the existing bolt holes in your floor board with little to no modifications. Corbeau Toyota seat brackets are powder coated in a black wrinkle finish and include Double Locking Sliders.
    Still... it would be nice to get a post on here from someone who has them...
    -Mike
    jackn7, mjp2 and GQ7227 like this.
  12. Aug 5, 2019 at 4:53 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    jackn7 likes this.
  13. Aug 5, 2019 at 8:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i believe that @1997tacomav6 put some of those into his
  14. Aug 6, 2019 at 6:24 AM
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    There is a guy on here from Hawaii (can't remember his name sorry) and he put the Corbeau's in his i believe 98. They look great and really are a direct bolt in. And I believe they were these seats
    https://corbeau.com/lg1.html
  15. Aug 6, 2019 at 6:28 AM
    Wulf
    rock raisin
    Pretty sure that's a CYA disclaimer on their behalf in case something doesn't work out.
    If you have a reg cab with a bench you may have to drill the 4 inner holes but I don't know for sure.
  16. Aug 6, 2019 at 6:28 AM
    Shiki Shabazz
    Tulsa, OK
    You don't drill anything. They are direct bolt in, see my previous post.
  17. Aug 6, 2019 at 6:31 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I've run Corbeau seats in 2 completely different vehicles and their vehicle-specific brackets bolt right up.
    The reclining CR1 seats were amazingly comfortable. Their RRX seats look like the closest match currently available.
    Pricey, but they'll last you forever and your back will thank you for it.
    BartMaster1234 and GQ7227 like this.
  18. Aug 6, 2019 at 6:32 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That seat bracket is no more than flat plate welded together and bent with holes drilled out. Easily made at home. You could buy a welder and steel and make your own with any imaginable seat from the Junk Yard for less than half the price of a Corbeau setup.
    Seagull233 and Wulf like this.
  19. Aug 6, 2019 at 6:32 AM
    Wulf
    rock raisin
    The regular cab single bench doesn't use all 8 holes that the 60/40 and bucket seats do. The remaining ones may or may not be pre drilled but they will be marked.
    Going from 60/40 bench to buckets won't require any drilling
  20. Aug 6, 2019 at 6:45 AM
    Shiki Shabazz
    Tulsa, OK
    But then you assume OP has welding skills, and the ability to put sliders on. just my 2 cents.
