Replacement for regular cab single bench seat with two buckets and centerrest
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SMMSMM57, Feb 27, 2018.
  1. Feb 27, 2018 at 4:45 PM
    SMMSMM57
    SMMSMM57 [OP] New Member
    I have the most basic model 2010 which has a single bench seat for both passengers. I am wondering if I can get two independent bucket seats that can move back and forth by themselves. The single bench moves as one. I would also like to get an armrest. Thanks
  2. Feb 27, 2018 at 7:02 PM
    MG06tacoma
    MG06tacoma Well-Known Member
    PA
    06 4x4 Base
    Yes you can, there are several threads to read upon here at TW that will give you all the info needed to perform the bench to buckets swap. It is not easy but is possible. I have a base 2006 single cab that came with the bench seat, it now has bucket seats that came out of a 2014 access cab.
  3. Feb 27, 2018 at 7:06 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    I have a 2007 reg cab I put buckets out of a 2010.The center console I couldn't find so I bought from a dealer cost me three times more than the seats.Installing seats was pretty easy, just had to remove air bag sensor out of bench and placed in the new passenger side bucket seat.Seatbelt latches ,I used a Dremel to make them fit in the new receptacles.
  4. Mar 1, 2018 at 7:22 AM
    slayer fan
    slayer fan Well-Known Member
    tommy
    ky
    2013 tacoma 4x4 regular cab
    2" lift.
    tacoburrito likes this.
  5. Mar 1, 2018 at 7:07 PM
    MG06tacoma
    PA
    06 4x4 Base
    Looks great... We used the same thread as guide..
