Replacement Engines Sourced From Japan
Discussion in '1st Gen. Tacomas (1995-2004)' started by Herm4376, Sep 14, 2015.
  1. Sep 14, 2015 at 9:39 AM
    Herm4376
    Herm4376 [OP] Member
  2. Sep 14, 2015 at 5:09 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Mike use the search bar and search JDM. A lot of members here have discussed the use of jdm motors. I've read that emission components, throttle body and the oil filter location is different from the U.S. motors but the parts can be swapped over from the old engine. I never personally used one nor do i have any expeirence with a jdm engine. I purchased my 3.4 off of eBay but mine was out of a Arizona salvage yard from a totaled tacoma. Be careful with those motors from Japan because of water damage from that tsunami.
  3. Sep 14, 2015 at 8:08 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    why not rebuild, or just find a used motor locally? i see them all the time around here for $3-600. Are you gonna do the swap yourself?
  4. Sep 15, 2015 at 4:03 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
  5. Sep 15, 2015 at 8:00 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I think the jdm engines are just as good as any salvage yard engine but you have to understand the mileages on jdm engines are a lie.
    this is for two reasons, unlike here, the japan engines spend 90% of there time idling in traffic and stop and go so they don't get high mileage on them but are getting engine wear just the same so lets say a 50k mile jdm engine there is the same equivalent of a 150k mile engine here so don't get pulled into thinking these engines are "like new".
    another thing is the way the engine was treated is a large unknown issue and it could have not been well maintained with regular oil changes or possibly driven aggressively and abused so even thought they aren't dirty, have low miles, and "appear" new, they are the equivalent of going buy a 100k used engine at the salvage yard in that you just don't ever know for sure what you are getting.
    that said, I would have no reservations in using a salvage yard engine or a jdm engine over rebuilding one simply for the cost and time savings involved.
    most who don't like the jdm engines just have sour grapes over thinking it was a true "like new" motor because of the claimed mileage it had only to find out later the mileages are not all that accurate since after the engine leaves the car, there is no proof of how many miles that engine "really" has.
    CS_AR and DustStorm4x4 like this.
  6. Sep 15, 2015 at 11:18 AM
    Indy
    Indy Master of all I survey.
    Hours idling is worse than hours moving, that's for sure. And if I KNEW I had to replace my engine at 50k miles, I probably wouldn't change the oil and would beat the tar out of it. No point in trying for longevity when by law, you can't have it.
    There are some sensors that the overseas engines don't have, or different parts. I looked into them a few years ago, ended up passing just because it was simpler to source one locally then to get a jdm, track down what parts had to be changed or added etc.
    CS_AR likes this.
  7. Sep 15, 2015 at 5:29 PM
    Herm4376
    Dave thanks for the feedback. Did you do the swap yourself? If so, did you run into any problems? Thanks.
  8. Sep 15, 2015 at 5:31 PM
    Herm4376
    Rebuilding is not an option. One of the connecting rod caps came out the side of the block. I'd like to do it myself, I just need to determine if I can find the time to do it.
  9. Sep 15, 2015 at 5:58 PM
    Herm4376
    Karl, thanks for the feedback. I agree with all your points which makes the decision between JDM and domestic salvage difficult. To me it is a gamble either way with the real wildcard being how the engine was maintained and if it was abused. I'm very anal retentive about preventative maintenance, but despite that had a connecting rod failure with no warning signs. See my original post where I added a picture.
    CS_AR likes this.
  10. Sep 15, 2015 at 6:41 PM
    68dave
    Dave
    Yea i did the swap myself. No issues. I found a 69k mile engine out of a totaled 2003 prerunner for $1400 shipped from Az. to my door here in Md. I did replace all the maintance items, tb, wp, clutch, tune up, valve cover & oil pan gaskets ect... while the engine was on the engine stand then dropped it in. It was a easy swap.
    CS_AR likes this.
  11. Sep 15, 2015 at 7:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The problem I've found (at least with nissans) with these imported motors is some of the internal & external parts like timing belt pulleys for one, are different than those used on the very cars imported from japan, my moms sentra had one of those engines & when I went to change timing belt I found that the only place that had the correct one had to be imported from japan because of the rounded toothed crank pulley they use there as opposed to the square toothed gear used for cars imported into the U.S..... really odd
    CS_AR likes this.
  12. Sep 15, 2015 at 7:37 PM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    CS_AR likes this.
  13. Sep 15, 2015 at 7:38 PM
    vlodpg
    Connecticut
    Why would they change engines at 50k?
  14. Sep 15, 2015 at 8:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Too many cars/trucks/people in a small area (japan) It's emissions related & it used to be a requirement at around 35k to R&R the engines in japan
    CS_AR likes this.
  15. Sep 15, 2015 at 8:46 PM
    vlodpg
    Connecticut
    That's insane!
    CS_AR and Rachelsdaddy like this.
  16. Sep 16, 2015 at 9:22 AM
    DSMJRV
    justin
    Corona, CA
    ya that's incredibly wasteful, why even buy a vehicle if that's the case?
    not to self: never move to japan
  17. Sep 16, 2015 at 9:31 AM
    vlodpg
    Connecticut
    Interesting to find out about engines from Japan, I see on eBay there are Hilux diesel engines available. Who will be the 1st to drop one into a Tacoma?
  18. Sep 16, 2015 at 9:35 AM
    keakar
    karl
    louisiana
    im not a fan of diesel engines and the cost of diesel is way too high to be practical in my book
    to be honest, if I ever had the balls to do an engine swap I would look into a v8 engine like the 1UZ-FE engine swap or maybe a small LS crate engine because, to me, these trucks would do much better, run smoother, have more power, and get much better mpg with small v8's in them but you would have to regear the rear ends to handle the power conversion.
    this is an interesting engine swap read: http://www.speedhunters.com/2014/07/v8-swapping-choose-your-weapon/
    if not going v8 then I see no point in not dropping in an exact replacement
  19. Sep 16, 2015 at 10:37 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I'd always heard those engines are beat to shit from Japan, they know they have to pull them at low miles so they never bother to change the oil or do proper maintenece
    CS_AR likes this.
  20. Sep 16, 2015 at 11:14 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I think you were misinformed, like I said earlier , Too many vehicles/people in use in too small of a geographical area, in addition to Japan being so industrial with manufacturing, & really, I don't see how they would be any worse(japanese) than the way we maintain (or lack of) vehicles here... It's all about the emissions/pollution standards they have there..
