Replacement Clutch Recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Petrol, Nov 30, 2014.
  1. Nov 30, 2014 at 7:58 AM
    Petrol
    Petrol [OP] Well-Known Member
    Central Va.
    Tacoma
    The clutch in my 03 Tacoma is getting near the end of its life. Not slipping yet but engaging just about at the top of the pedal travel. Just starting to think about parts at this point and I still have some time.
    I used a Luk Clutch in another vehicle and was very happy with the quality.
    Anyone have actual experience with Luk clutch kits in 4 cylinder, 4WD Tacoma's ?
    Any other brands worth considering?
    I'm running stock wheels, don't rock crawl, no towing, some off road use but I don't abuse it.
    And one more question: What type of rear main seal is used in the 2.7L 4 cylinder? Is it a one piece press in type or one of the two piece seals that you have to drop the oil pan and bearing cap to get out? Mine isn't leaking yet and if it's the two piece type I'm probably going to leave it in there.
  2. Nov 30, 2014 at 8:05 AM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
  3. Nov 30, 2014 at 8:29 AM
    Petrol
    Central Va.
    Tacoma
    Looks a bit expensive?
  4. Nov 30, 2014 at 8:46 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I've always had good luck with part store clutches, even on 300+hp v8s so I don't see the need to pay $300-400 for a fancy clutch to hold less than 150hp. Luks been around for a while, I'm sure it'll be fine. If you haven't, check out rockauto.com. They usually have a good selection, and Aisin is usually on the list which I believe is OEM. I've heard you can adjust these clutch pedals, that might give you a bit more travel for the time being.
  5. Nov 30, 2014 at 9:09 AM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    Yeah they are a little more than the average parts store replacement. I have used the parts store ones before and as the saying goes you get what you pay for.
  6. Nov 30, 2014 at 10:48 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    LCE is a great kit.
    marlin makes a nice kit
    TG makes a good kit.
    All come with OEM bearings and Asin parts...IE..OEM
    just beefier versions.
    Which ever you want. all three are good.
  7. Nov 30, 2014 at 11:47 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I've got an Exedy clutch that I put in my truck about 5k ago. No bearing chirp, slip or overly heavy pedal. I use it hard when wheeling and all is well.
  8. Nov 30, 2014 at 2:28 PM
    Petrol
    Central Va.
    Tacoma
    10-4 and thanks all of the responses. I'm interested if anyone has a report based on long term use. I don't want to spend a lot of money for a name, I just want a good solid clutch.
  9. Nov 30, 2014 at 2:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i have the TG ceramic clutch. IDK if it would be ideal for a straight up DD. But for a rig it is great. I have abused the hell out of it and it works awesome. Very grabby though and drives much different then a standard clutch as its ceramic and a 6 puck design.
  10. Nov 30, 2014 at 2:54 PM
    Petrol
    Central Va.
    Tacoma
    I don't believe I want ceramic. My limited past experience with ceramic was that they were fine for racing applications but difficult to use on the street. Not enough slippage during engagement when needed. (slow starts in traffic, starts on hills, etc. )
    We used to run truck clutches and they worked great but were hard on the linkage.
    What I need is a good, solid clutch that will give long service.
    I don't need painted pressure plates, fancy boxes or lots of advertising.
  11. Nov 30, 2014 at 3:33 PM
    vern650
    brandon
    hyrum, ut
    id just pic one. rockauto has the aisin for about $170 and that is probably the same one your taco came with from the factory. the luk is around $140, and they go down to around $130 for the exedy. having put alot more power through $120 clutches with no issues i dont see the point in putting a hi end racing type clutch in a weak little toyota DD.
  12. Nov 30, 2014 at 3:57 PM
    Petrol
    Central Va.
    Tacoma
    I agree, have you used one?
  13. Dec 1, 2014 at 12:05 AM
    vern650
    brandon
    hyrum, ut
    used one what exactly?
  14. Dec 1, 2014 at 3:36 AM
    Petrol
    Central Va.
    Tacoma
    A Luk Clutch
  15. Dec 1, 2014 at 4:30 AM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    Interested also. When I bought my taco 3 years ago the po mentioned it might need a new clutch. Ive just now been experiencing some pretty good slippage, pretty sure its the clutch. Ive heard numerous ways to test it to confirm it is the clutch and not the engine or axle but can anyone throw out a few tests for our rigs specifically?
  16. Dec 1, 2014 at 5:09 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    You had good luck it seems and previous experience with a Luk clutch,,grab another one and load it up.
    You also had good luck? with the OEM clutch, as quite a few of us have.
    So you have 2 choices that you know personally about that work well.
    You don't need extra clamping force on the pressure plate, as indicated, so that rules out any extra heavy duty stuff.
  17. Dec 1, 2014 at 9:44 AM
    vern650
    brandon
    hyrum, ut
    not on a taco, but on other trucks yes. Some of the fullsize trucks used luk from the factory also.
  18. Dec 1, 2014 at 12:25 PM
    wild03
    wild03 Well-Known Member
    Florida
    98 Tacoma DLX 2.4L
    tach
  19. Dec 1, 2014 at 5:52 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I just bought the AMS kit (16077SE) from Rock Auto. The clutch and pressure plate are Aisin. The throw out bearing is Nachi.
    I can't speak to the longevity or anything else, yet. It's still a data point, I suppose.
  20. Dec 7, 2014 at 2:56 PM
    Petrol
    Central Va.
    Tacoma
    Did you know that if you adjust the clutch but don't make a corresponding adjustment to the switch at the top of the pedal, your cruise control will stop working?
