Replaced my PCV Valve on the 2014 V6. Threads of valve exposed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomawithArima, Jun 16, 2022.
  1. Jun 16, 2022 at 8:06 AM
    TacomawithArima
    TacomawithArima [OP] Active Member
    East Bay California
    2014 Tacoma TRD OR Baja Black
    I just changed my PCV Valveon my 14 v6. Has 57,000 miles on it. The valve is pretty blocked by hoses. I had to use a deep 19mm socket and a 3 inch wobble extension to access the valve.
    My old PCV valve still worked but was covered in gunk and didnt rattle and cleanly as the new OEM pcv I put in.
    What surprised me in doing this is learning youre not suppose to thread the PCV valve in all the way. Half the threads are exposed to open air. Yes I double checked to make sure I wasnt cross threading. I think this because the factory PCV was installed this way with this much threads exposed and because a youtube video told me. Also if you follow the 20ft lb torque spec recommendation, itll tell you to stop before all the threads are in. Your thoughts?
    Gunk in the crank case, normal?
  2. Jun 16, 2022 at 8:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's pipe thread it's meant to be taper fit, if you overtighten it you will crack the valve cover.
    As for gunk buildup a small amount is normal, if it's excessive usually it's from not changing your oil often enough, using poor quality oil, or making alot of short trips.
    TnShooter, burrito782 and Jimmyh like this.
  3. Jun 16, 2022 at 1:30 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Dm93[QUOTED] and TnShooter like this.
  4. Jun 16, 2022 at 3:13 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Take the oil cap off and look inside. 57K seems premature for it to fail. Where you burning oil? That’s one of the possibilities that the valve has failed. The valve train shouldn’t have any sludge. If it does you’ve neglected that engine.
    Dm93 likes this.
