Replaced Headlight bulb but still not working.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hussein J, Jun 25, 2022.
  1. Jun 25, 2022 at 7:26 PM
    Hussein J
    Hussein J [OP] Member
    Hussein
    Hey guys
    I replaced the headlight bulb for Tacoma 2018. I bought new one and installed it on the driver headlight but still not working. Then I installed the new bulb on the passenger headlight it worked. I traced the driver headlight harness no cut they looked original to me. But I noticed something that the connector on driver side is different than the one on the passenger side. What else to investigate, can the fuse be the problem or something else? Thanks.
  2. Jun 25, 2022 at 8:12 PM
    pocket_geek
    pocket_geek Member
    Curtis
    Caldwell, ID
    2021 White Tacoma Offroad
    3" Lift, 33's, Fuck Cancer sticker.
    Could be a fuse, I've had the same symptoms with a blown headlight fuse. Headlight fuses are in the fuse box under the hood on the drivers side by the battery.
    Hussein J[OP] likes this.
  3. Jun 25, 2022 at 11:59 PM
    Hussein J
    Hussein
    The problem is fixed. The fuse is bad. Thanks
  4. Jun 26, 2022 at 1:54 AM
    Cthudak
    Cthudak Well-Known Member
    2017 Tacoma sr access cab 4x4 5 speed
    Weather tech mud flaps
    Nice fix. Looks like your connector on the drivers side is missing the green plastic insulation insert. This may be why the fuse blew?
