Replaced dash speakers in non-JBL stereo, 4th gen
Discussion in '4th Gen. Tacomas (2024+)' started by TacoMagic, Oct 12, 2024.
  1. Oct 12, 2024 at 3:31 PM
    TacoMagic
    TacoMagic [OP] Member
    Joshua
    2021 TRD OffRoad 4x4
    Installed some new dash speakers today. Factory stereo, SR5, non-JBL.
    Replacement is on the left, factory on the right in that first photo.
    Seemed like quite a few people have used these in automotive applications so I figured I’d give them a try. I used ********* speaker harness adapters.
    Started with the passenger side, popped off speaker cover and used a 10mm wrench to get the screws out.
    Replacement FaitalPRO dropped right in and lined right up with the holes. Secured the screws down and popped the cover back on and tried some A B listening while adjusting the balance on the stereo. Definite improvement.
    Now, on to the driver side. The gauge cluster hump provided some problems, as the new speaker with four points of attachment couldn’t lay flat. Either cut the tab off the speaker, or Dremel down the area it would occupy.
    I chose to use a Dremel with a sanding drum to make some room. Finally got it to fit. Screwed down the other two mounting tabs and we’re in business. Speaker grill popped back on with no problem.
    They are being powered with the recently added Beat Sonic plug and play amp. Highs were a tad harsh, so I knocked the treble and mid bass in the fader/balance.
    Overall, prettt happy. Cutting out the dash took the most amount of time. Just be careful with a spinnysander tool around your delicate pieces. Use two hands. Wait for the bit to stop before moving it.
    https://www.parts-express.com/Faita...Professional-Woofer-4-Ohm-294-1120?quantity=1
  2. Oct 12, 2024 at 5:38 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I personally would have just cut the 1 mounting tab off the speaker, using a thin cut-off disk...
    All good though, you got it done..
    dneal and TurboDA6 like this.
  3. Oct 12, 2024 at 6:05 PM
    TacoMagic
    Joshua
    I needed to consider possibly having to send the speakers back if I didnt like them.
    I didn’t take the job of cutting into my dash lightly. I was very careful, and since it didn’t really effect any kind of structural integrity I went with the sanding bit. :|
    Steves104x4 likes this.
  4. Oct 13, 2024 at 11:01 AM
    DankSR5Taco
    DankSR5Taco Active Member
    2024 Black Tacoma SR5 DCSB 4X4
    Good job, glad it sounds better.
    Just curious, but from the looks of it, couldn't you have just slid that one speaker corner tab under the dash plastic piece while installing, instead of dremeling out a slot for it? I know you wouldn't be able to screw that corner tab down, but I'm wondering if it would have made any big difference.
  5. Oct 13, 2024 at 11:18 AM
    TacoMagic
    Joshua
    I tried getting that to work, but when screwed down, the speaker frame would push up on the dash and wouldn’t allow the grill cover to seat flush.
  6. Dec 19, 2024 at 1:17 PM
    24TRDtacotruck
    24TRDtacotruck Well-Known Member
    24 Tacoma TRD Sport Bronze Oxide
    Doing the same in my Taco. I hate that manufacturers can't at least give you polypropylene coned speakers. I went with Rockford Fosgate for my speakers and I'm going to see how they sound without an amp but I have one if need be. I'll just have to yank it out of my Camaro, LOL.
    I did the speaker surgery instead of cutting on my Taco though. I also took the R/F logos off of my speaker grilles and re attached them to my Tacos speaker covers for that important "Bling Factor", hahaha.
    R242, Steves104x4 and max911 like this.
  7. Dec 19, 2024 at 10:52 PM
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    Can you put a link the therockford forgate. How do they sound?
  8. Dec 20, 2024 at 5:57 AM
    24TRDtacotruck
    Crutchfield is where I got my corner speakers. Actually everything thats going into the truck is from crutchfield, but the rest of the R/F speakers and amp are coming out of my Camaro since I am selling it.
    Anyway, here's the link to the speakers I am using. Since the dash corner speakers are used as tweeters and run inline with the 6x9's in the front door I went with single cone speakers.
    https://www.crutchfield.com/p_575R14X2/Rockford-Fosgate-R14X2.html?tp=105
    R242 and xxTacocaTxx like this.
  9. Dec 20, 2024 at 6:18 AM
    slater
    San Diego
    Dont shoot the messenger but someone needs to do their dd....
    Not the best option....
    If you going to keep the stock amp config, factory speakers are 3ohm & the RF's are 4 ohm.
    Also im 300% certain the factory dash speakers are 3.5" & that RF & the OP's speaker is 4", will most likely not fit correctly along with wrong load, won't be very loud..
    a 4" speaker in with the wrong ohms isn't going to do anything special for you vs a 3.5" 3 ohm...
    Not a good / optimum option...
    These below have been posted in Bobs thread, multiple people have used them, they work & are the better option for this situation,
    You're welcome...
    This speaker is also available on AMZ.
    https://www.crutchfield.com/p_109CL34F/JBL-Club-34F.html
    My4thTacoma and xxTacocaTxx like this.
  10. Dec 20, 2024 at 6:33 AM
    slater
    San Diego
    xxTacocaTxx likes this.
  11. Dec 20, 2024 at 7:33 AM
    24TRDtacotruck
    I'm not trying to be "loud", I am improving the sound quality. The R/F does fit. The resistance is not an issue with a LOC and small amp.
  12. Dec 20, 2024 at 7:50 AM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    At least with other Toyota JBL systems, I found that the dash midrange was overpowered, so switching to a less sensitive aftermarket speaker in the dash accomplished two things:
    1) quieted the midrange and achieved better tonal balance; 2) gave better audio quality than the stock paper cone and tiny magnet voice coil.
    TurboDA6 likes this.
  13. Dec 20, 2024 at 8:27 AM
    slater
    San Diego
    Doesn’t look like a fit without some hacking…
    Stock speaker is 3.5”….
    It’s clearly not a fit per your pic…
    R242 likes this.
  14. Dec 20, 2024 at 8:38 AM
    24TRDtacotruck
    I'm not going to argue about this with you, but I will say this: you are dead wrong about the fit. I didn't have to cut a damn thing and the grille fit over it just fine. I have no idea why you feel the need to call me out when you are wrong. I backed my claim up with a picture and all you are providing is argument for the sake of arguing. I'm done with this conversation.
    '24firstaco likes this.
  15. Dec 20, 2024 at 12:16 PM
    Wahhabm
    Monther
    these speaker in you link are jbl. Will they work with the standard non JBL system?
  16. Dec 20, 2024 at 1:02 PM
    slater
    San Diego
    I cant confirm if the ohms are the same jbl vs non jbl, but it will fit....
  17. Dec 21, 2024 at 7:35 PM
    Wahhabm
    Monther
    I just removed the dash speaker. It is very cheaply made and I can't tell how many ohms and what a good replacement speaker is? I See it has a special plug also with 4 pins. If you know what is a good replacement let me know. Thanks.
  18. Dec 21, 2024 at 7:45 PM
    slater
    San Diego
    I would talk to some knowledgeable professionals in the field before pulling the trigger on some speakers.
    Not very familiar with the non jbl amp.
    Call crutchfield tomorrow...
    You need a plan...
    Are you adding an amp or not?
    If you think your not & then buy speakers now, decide your not happy with the results, the speakers you chose may not. be wroth of an amp...
    You can go to cructhfields website enter all your vehicle info & browse..
  19. Dec 21, 2024 at 7:47 PM
    Wahhabm
    Monther
    I added the beatsonic amplifier when I first got the taco and the sound improved alot. But boy those dash speakers are so cheap.
  20. Dec 21, 2024 at 7:55 PM
    slater
    San Diego
    I would get the JBL's I mentioned, dont go crazy & spend alot of money.
    Also find that post where they guy links them, as you also need the speaker connector adaptors so wiring is easy.
    Important to get the polarity correct...
    I would also call or email beat sonic before going crazy, dot you I'd, cross your T's.
    No idea if the BS is up to the task of replacing / upgrading your speakers.
    Its a tiny amp, designed to power-up those tiny minispeakers.
    Not saying its not doable, just saying ask Eric & see what he says..
