Replaced both brake calipers now soft pedal even after bleeding.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewfoundlandTaco, Feb 7, 2016.
  1. Feb 7, 2016 at 11:29 AM
    NewfoundlandTaco
    NewfoundlandTaco [OP] Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    I had a caliper go bad yesterday and I put my foot on the brake and the pedal went to the floor, fluid all over the driveway. So today I replaced the caliper and pads, when replacing the pads on the other side that caliper was seized, go figure. Now after bleeding both fronts the pedal is still really bad. The fluid in the reservoir got way down past min after losing fluid yesterday. Is it possible I need to bleed the rears now too? Or is there something I'm missing, possibly ABS related?
  2. Feb 7, 2016 at 12:06 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    it would be best to bleed the fronts then the rears and then the fronts again. you might need to adjust the rear brakes to help get the high pedal
    Wrench1225 likes this.
  3. Feb 7, 2016 at 12:08 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Just keep bleeding the system to be sure ALL the air is out. Sometimes it takes a while.
    12TRDTacoma likes this.
  4. Feb 7, 2016 at 1:23 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Every time I bleed the brakes on the Cobra it takes way longer than it should. Its a hassle for me to get the air out it takes determination and patience. I installed speed bleeders and that helped a lot. Brake fluid needs changed annually in my opinion if at all possible so using speed bleeders or some other technical solution helps a lot. I do not know about Tacomas, but on the Cobra if you get air in the ABS module a scan tool is required to correct that and it is typically time to take it to the stealership if that occurs.
  5. Feb 7, 2016 at 1:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Pretty sure you still have air in the system.
    Get a pressure or vacuum bleeder it makes it way easier. Always start at the brake furthest away from the master cylinder and bleed towards the master cylinder.
    There are many options: https://www.youtube.com/watch?v=wDSyZNDOjnY
  6. Feb 7, 2016 at 1:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah honestly when you let the system go dry or go past a minimum level you end up retaining a ton of air in the system which unless you have a vaccuum bleeder will take a while to get all the bubbles out of the system.
  7. Feb 7, 2016 at 2:44 PM
    Macs06
    Macs06 New Member
    Ohio
    SR5
    GROM box, Front windows tinted, Plasti Dip Hood Scoop
    It might be possible that you'll need to bleed the master cylinder to get rid of the air if the fluid got really low. I would start there then do each wheel according to the proper bleeding order.
    Lester Lugnut likes this.
  8. Feb 7, 2016 at 2:47 PM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    You probably got air in the master cylinder. Keep on bleeding.
  9. Feb 7, 2016 at 3:01 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sure its not your booster? where was the fluid coming from? typically fluid on the ground is a cracked line. Not saying a caliper cant leak but typically the pistons dont release..but if everything else looks good make sure your fluid level is good and keep bleeding the brakes
  10. Feb 7, 2016 at 5:42 PM
    Wrench1225
    Wrench1225 Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    Start at the wheel furthest from master then work your way to master. But before you do that pull the wheels and double check your work.
    The other thing but not likely check the thickness of rotor's.
  11. Feb 7, 2016 at 8:41 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If air did find its way to the master cylinder, I think you may end up having to bench bleed it.
    If you have an integrated master cyl/ABS unit, you'll likely need techstream software(Toyota) to get things sorted out. I'm saying this because the fluid may have gotten too low.
  12. Feb 8, 2016 at 3:55 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    That's a new one on me. If this is true it's one of the many reasons I disconnect battery before I do any work on the brakes requiring a bleedING later.
  13. Feb 8, 2016 at 6:14 AM
    NewfoundlandTaco
    If there is air in the master cylinder bleeding from the calipers won't remove it, will it?
  14. Feb 8, 2016 at 11:18 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Correct if the air is in the master got to bleed master
  15. Feb 8, 2016 at 11:43 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    same problem for me on my last 2 Tacos (05 & 14 Sports). rebuilt engines before, installed my lift and SC but no luck bleeding the brakes on Taco's. Just subsided to the fact and took it to my mechanic both times.
  16. Feb 16, 2016 at 5:44 AM
    NewfoundlandTaco
    Update, bought some 1/4" clear tubing and bled just the front brakes again, couple of significant air bubbles on each side came out. Pedal is perfect again. Thanks for the help people.
  17. Feb 16, 2016 at 5:17 PM
    jeepmor
    jeepmor Well-Known Member
    Stumptown
    I recall tinkering with my brakes for some reason and reading that you want to bleed them with the ignition off so the ABS is not active. This worked well for me. Glad to see your issue was resolved. I don't remember what I was
