Replace valve stem seals?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Just_John, Apr 6, 2018.
  1. Apr 6, 2018 at 1:32 PM
    Just_John
    Just_John [OP] Active Member
    2003 Tacoma TRD
    Hope I can get some advice.
    After taking my boat to the water, I started to see smoke after starting my 2003 Tacoma. It quickly goes away, but started lasting longer. It still goes away, but takes about a block down the road before it stops now.
    I believe this started right after I backed up too far, and my tail pipe was underwater. Could this have messed up my valve seals? I read a post by someone that stated they back up until their tail pipe is underwater all the time; so, maybe that is not my problem. I still have excellent power, and I am not losing coolant. I appreciate any advice.
  2. Apr 6, 2018 at 1:41 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Tail pipe under water shouldn't cause any issues. Usually white smoke could mean 2 things. If it's white smoke(steam) it's most likely coolant so check to see if it's low and needs topping off. It could be a head gasket leak issue. If it's a faint blue smoke, which can appear white, it's oil burning which means you will most likely need a rebuild.
  3. Apr 6, 2018 at 1:52 PM
    Just_John
    2003 Tacoma TRD
    I'd say it is more faint blue. I'm not losing coolant, but I am burning oil. I have to add about a quart every 4-6 weeks. So, I thought my head gasket is probably fine. I thought since the smoke went away so quick, it was probably from the stems, oil leaking down into the chamber and then, when I start it, it has to burn off what is in the chamber, but then it heats up, stems expand, and no more oil gets in. Does that sound right? I was planning on just replacing the cyl heads, cyl bolts, gaskets/seals, all belts (including timing), water pump, and thermostat. I only have about 120,000 miles on it.
  4. Apr 6, 2018 at 1:56 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    If you're burning oil then it sounds dead on. You can drive it as is for many more years as long as you keep an eye on the oil level.
    JudoJohn likes this.
  5. Apr 6, 2018 at 2:01 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Smoke on start up ..... Guides and valve stem seals
    Smoke acceleration or Deceleration ....... Piston rings
  6. Apr 6, 2018 at 2:05 PM
    Just_John
    2003 Tacoma TRD
    It is just upon start up. If it is not from the tailpipe in the water, any idea as to what could make the stem seals go bad at 120,000 miles? Could it be from hauling the boat? It is just a 17ft tri-hull. It's under the tow rating.
  7. Apr 6, 2018 at 2:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    4-6 weeks, but how many miles is that?
  8. Apr 6, 2018 at 2:10 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    High mileage is the main culprit but they can get brittle and deteriorate from the vehicle sitting for extended periods of time (I.E Vehicle storage )
    JudoJohn and cruxofthebisquit like this.
  9. Apr 6, 2018 at 2:12 PM
    Just_John
    2003 Tacoma TRD
    Hard to say...back in forth to work about 38 miles??...so...700-1000 miles?? (guessing)
  10. Apr 6, 2018 at 3:13 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Are you using a high mileage synthetic oil ?? , these types of oils recondition the seals & gaskets in your engine thus slowing down oil leaks
  11. Apr 6, 2018 at 3:20 PM
    Just_John
    2003 Tacoma TRD
    Yes, I use high mileage oil. I also bought an additive but it didn't seem to help at all.
  12. Apr 8, 2018 at 6:44 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2017 TRD Off Road DCLB
    V-LED low and high beam headlights. OVTuned
    Sounds like classic valve seals. Although low miles for such oil consumption...pulling the heads off to replace them might be easier then removing the cams, filling each combustion chamber with air, and replacing the seals.
  13. Apr 8, 2018 at 6:48 PM
    jekerskel
    Zach
    Bellingham WA
    Highly unlikely it has bad guides though.
  14. Apr 12, 2018 at 4:22 PM
    Just_John
    2003 Tacoma TRD
    I thank everyone for their reply. The thing that makes me the most nervous is changing the timing belt!! But...I am not afraid to try.
    Running Board Man likes this.
  15. Apr 12, 2018 at 4:33 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's 100% not from the tail pipe in the water. If your engine was running, stuff is coming OUT of the tail pipe, not going IN. But even if you sucked up water in the intake, that wouldn't really ruin the value guides and cause an oil leak (the smoke on startup).
    You just have classic leaky valve guides/seals. While that's fairly unusual for a Tacoma with 120k miles on it, anything can happen even with all the proper maintenance.
    Do you know the service history of the truck? Has the oil been changed regularly? If not, that could certainly contribute to leaky vales guides/seals.
  16. Apr 12, 2018 at 4:40 PM
    Just_John
    2003 Tacoma TRD
    I'm not sure of the maintenance history. I bought it from a dealership. I believe it was 6 years old when I bought it and had one owner. I still love my truck, but I need to get it fixed.
  17. Apr 12, 2018 at 5:00 PM
    jbrandt
    Justin
    I would definitely get it fixed too. Just curious because this isn't something that usually happens even on 300k mile Tacos.
    As for the timing belt, I did mine about a year ago. Do some serious reading on this site for tutorials and where to buy the parts (there's a guy on ebay that sells *everything* you need. I can't remember who, but search for it, you'll find it. Took me basically a long weekend. Started on Friday night after work, and had it running on Sunday.
    It would be a perfect time to tear into the heads since you're taking the belt off anyway. If you have another vehicle to drive, that would be ideal, since it will likely take you a while.
  18. Apr 13, 2018 at 8:49 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    age. Back when they were plain rubber, it was common after just a few years.
  19. Mar 22, 2019 at 8:07 PM
    Just_John
    2003 Tacoma TRD
    I did a compression test on my engine today. Here are the results...
    Cyl #1 155
    #2 160
    #3 0 (yes-zero)
    #4 150
    #5 165
    #6 160
    When I did the leak down test on #3, I could hear air coming back out of the spark plug hole. I had it threaded and sealed. I could also hear air coming out of the plug hole for cyl #1. Nowhere else, not out of the intake, exhaust, or crankcase.
    When I did the leak down on #1, I could hear air coming out of the crankcase. Of note, there was also about 1/2 qt of oil in the air intake!!
    Anyone ever remove the pistons out of the top of the block without removing the engine? It actually runs pretty good. It just now started idling a little rough, but runs well other than that. I was hoping to just throw on some new cyl heads and gaskets, but it looks like the rings need replacing, too. I do not really want to remove the engine. I was just wondering how feasible it is to push the pistons out of the top and then put in new pistons and bearings.
  20. Mar 22, 2019 at 8:19 PM
    Just_John
    2003 Tacoma TRD
    Yeah, I was hoping for a head gasket and cyl head replacements...but...that's the way it goes!!
