Replace the a/c push button
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomboy75, Jan 16, 2013.
  1. Jan 16, 2013 at 11:45 PM
    tomboy75
    tomboy75 [OP] Member
    tommy
    tn
    98 Tacoma
    I let my brother borrow my truck and when I get it back the push button is broke and falls out. So, I try to Macgyver it together with super glue and screw the whole damn button up. My question is, has anyone replaced theirs? I found them on ebay and I am just looking for some advice on this.
    MainerDave19995VZ likes this.
  2. Jan 17, 2013 at 5:40 AM
    SteveT
    SteveT Well-Known Member
    Clarksville TN
    4x4/TRD
    first advice would be to not let your brother drive your truck anymore :D haven't had a chance to take a good look at the button itself but sometimes you can get it on ebay though that can be hit or miss. you can always check one of the part dealers that have OEM parts. might get lucky and not get charged an arm and a leg
  3. Jan 17, 2013 at 5:53 AM
    Madjik_Man
    Colorado Front Range
    I'm not exactly sure what you're talking about but the a/c switch button in the dash is a very simple mechanism. You simply just pull it out and slide it back in.
  4. Jan 17, 2013 at 8:02 AM
    tomboy75
    tommy
    tn
    98 Tacoma
    This is exactly what I'm talking about. How simple are we talking?
  5. Jan 17, 2013 at 11:01 AM
    Madjik_Man
    As simple as pulling the old one out and sliding the new one in.
    Literally.
  6. Jan 17, 2013 at 11:05 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    ^^ this. if you're struggling with it, you're doing something wrong.
    that's what she said.
  7. Jan 17, 2013 at 11:10 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    You didn't break yours pulling it out? :p
    I feel the need to pick on you when I see your posts about removing things from your truck. Sorry!
  8. Jan 17, 2013 at 11:23 AM
    Madjik_Man
    :mad:
    I broke two clips in the entire process of removing and reinstalling my interior.
    The little clip that holds the passenger side door rod to the handle and one on the upper trim panel below the rear window.
  9. Jan 17, 2013 at 11:25 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    I broke my button replacing a dash bulb and now it's just a green light on all the time the cover is missing
  10. Jan 17, 2013 at 3:00 PM
    tomboy75
    tommy
    tn
    98 Tacoma
    It was as easy as stated above. I never had tried to just pull the old one out. I thought the whole a/c control panel had to come out. I just took the AC bezel off and the old button came out. I then went to a salvage yard where they have a couple of wrecks and picked up two buttons for $10.
  11. Jan 17, 2013 at 3:01 PM
    tomboy75
    tommy
    tn
    98 Tacoma
    Thanks for the comments and advice. It helped after looking at the bulb replacement threads. Thanks again.
  12. Jul 2, 2024 at 2:57 PM
    Tomengn
    Tomengn New Member
    Steven
    2000 Tacoma Pre-Runner
    I did the exact same thing, I tried to fix it with super glue and got it stuck in the on position. So I bought a new one, takes only 1 minute to install. But now the new one won't turn the A/C on. Any advice on how to troubleshoot the problem???
