Replace steering rack? or rack guide?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mkorsholm18, Oct 22, 2018.
  1. Oct 22, 2018 at 7:00 PM
    Mkorsholm18
    Mkorsholm18 [OP] Active Member
    Martin
    Metro Atlanta
    03 Dcab TRD
    3in toytec lift 285/75/16 BFG KO2 16" Procomp alloys Full 4xinnovations skids
    I have a question for those of you that are experienced with our 1st gen steering racks. Check out the attached video.
    https://youtu.be/KYbDUfSO7SU
    I just replaced my inner and outer tie-rods so I know those aren’t the problem. Rack bushings are also new.
    Can this be fixed with a steering rack guide? I would think not, since it seems like the inside diameter of the housing is WAY larger than the diameter of the rack, and a new guide would only shove the rack forward and continue to wear out the housing. Any insight/experience/educated guesses would be very helpful!
  2. Oct 22, 2018 at 7:46 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    As cheap as the rack guide is try it first. I have always preached that the new style guide should come with all suspension lift kits as they only exacerbate the poor design.
    prerunnerSD likes this.
  3. Oct 22, 2018 at 7:49 PM
    shmabs
    shmabs Well-Known Member
    I'll chime in that the new style guide has worked well for me on three occasions and is a cheap(er) option than a new rack. It's been a bit since I did the last one, but properly seating the new guide is important too.
  4. Oct 22, 2018 at 8:01 PM
    Mkorsholm18
    Martin
    Metro Atlanta
    03 Dcab TRD
    Thanks for the input
    Do you recall the amount of play was similar?
  5. Oct 22, 2018 at 8:07 PM
    shmabs
    Yours has a significant amount more play than I have experienced, but a good portion of that may be remedied by the new guide. The visible wear on your rack is slightly concerning to me.
  6. Oct 25, 2018 at 5:14 PM
    Mkorsholm18
    Martin
    Metro Atlanta
    03 Dcab TRD
    Bump, looking for a few more opinions on this
  7. Oct 25, 2018 at 6:37 PM
    Glamisman
    Glamisman Well-Known Member
    which route you take depends on so many factors that are unknown. If you put the new style guide in and the inner seals are hard and it starts to leak fluid in 6 months you are going be mad at wasted money, if you get away with it, the rack is still 15 years old. At some point you are just going to have to decide. You are in Indiana and its gonna snow and get nasty. Is this going to be a heated garage job or a unheated driveway job?
  8. Oct 26, 2018 at 7:11 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
  9. Oct 26, 2018 at 8:01 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I had significant (by my standards) play in a rack. It does not affect drive-ability and geometry but makes annoying sound when driving over bumps. I did replace the guide with the new style and all went away. No leaks, no noise no problems. And mine is 23 years old truck. This is what I found when I took out the old style roller:
    https://www.youtube.com/watch?v=XosdC0cujeE
    cruiserguy and Mkorsholm18[OP] like this.
  10. Oct 28, 2018 at 9:22 PM
    Mkorsholm18
    Martin
    Metro Atlanta
    03 Dcab TRD
    Thank you all for the input.
    What I’m wondering is, if it has had this amount of play for a while and the rack and pinion gears aren’t meshing correctly, would they get worn out to the point where they aren’t fully engaged even with a new guide?
    ~$80 for a new guide assembly or the $200 Detroit Axle steering rack assembly. Leaning towards a new rack, however my truck has spent most of its life in the rust belt so I’m afraid those lines are completely seized.
  11. Oct 29, 2018 at 6:07 AM
    Glamisman
    I hope this isnt your only transportation. If those fluid lines are siezed this could be a real issue. I have no other advice other than purchase the hydraulic lines at a local auto parts store explaining that you "might" need them with the understanding that you can return them if needed. If they have to special order them this might be a problem.
    Running Board Man likes this.
  12. Oct 29, 2018 at 2:08 PM
    RysiuM
    Rysiu
    The gear is perpendicular to roller so up/down movement does not affect gear mesh. If your rack is not leaking it means by replacing the guide it will be only better. If you have original factory rack and if it does not have any hydraulic problem it will be probably better (with the new guide) than any "refurbished" or "Chinese" rack. Those hydraulic lines are not cheap by the way. If you don't need to touch it, don't.
  13. Oct 29, 2018 at 2:27 PM
    Timmah!
    TIM
    There's a reason why that replacement rack is only $200 and a replacement OEM rack is over $500. The old adage, "You get what you pay for" holds true with these aftermarket racks. Some have had good luck with aftermarket racks while others have regretted it. I personally wouldn't install an aftermarket rack in one of my rigs.
    Mkorsholm18[OP] likes this.
  14. Oct 29, 2018 at 2:38 PM
    Timmah!
    TIM
    I guess you have to figure out what your time is worth with these "Lifetime" warranties auto parts stores give you. If you don't mind repeating the same labor over and over again, I guess it's a good deal. If you want a one and done situation, OEM is the way to go. This is especially important for people who are paying a shop to do this for them. If they had to pay for the labor for each swap, who cares if they are getting another free rack every time the old one breaks. The labor rates are going to kill them and they would have been better off buying the OEM one in the first place.
  15. Oct 29, 2018 at 3:37 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Mine was doing exactly what your's is. I replaced the guide and it is significantly better. I got parts from Olathe Toyota online.
  16. Oct 30, 2018 at 7:01 PM
    Mkorsholm18
    Martin
    Metro Atlanta
    03 Dcab TRD
    Thanks guys I appreciate it.
    I'm going the rack guide route. It's way cheaper and I'm sure it'll greatly improve the situation, at least until I can afford an OEM rack. Definitely only want to do that job once.
    I'll post the results once I get it installed
    RysiuM and Timmah! like this.
  17. Nov 6, 2018 at 2:43 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Interested in hearing how the new guide works out for you. Need to check mine myself, but Firestone claimed it has play.
  18. Nov 7, 2018 at 8:30 PM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    Would anyone happen to know if the process is the same for the 5 lug trucks?
  19. Nov 18, 2018 at 12:37 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    My input seal was leaking. I checked prices for the rack, and ended up ordering a seal kit online and overhauled the entire rack myself. Worked out fine for me, but I wouldn’t recommend overhauling to just anyone.
    Anyway the rack bushing is spring loaded and adjustable. If it’s not worn out completely you could try to tighten it up. You’ll go through adjusting it when you replace it anyway, won’t cost a dime to try.
    Mkorsholm18[OP] and RysiuM like this.
  20. Nov 30, 2018 at 9:02 PM
    Mkorsholm18
    Martin
    Metro Atlanta
    03 Dcab TRD
    UPDATE! I finally got some free time over the long Thanksgiving weekend and I was able to install the new steering rack guide.
    After watching @Timmah! videos once or twice (very helpful btw keep those up!), it took about 20 mins to remove the old roller style guide and install the new one.
    I didn't take a video of the steering rack after the new guide was installed since there was literally nothing to show. There is no longer any sort of play or slop in the steering rack. This little piece worked wonders. After an alignment the truck is driving straight as an arrow and requires much less input to the steering wheel to keep it driving straight on the highway. Very glad I chose to replace the guide instead of the whole rack.
    Thanks for the input everyone
    Taco-Obsessed, prerunnerSD and RysiuM like this.
