Replace oxygen sensor with OEM or Bosch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by EdFlecko, Mar 10, 2014.
  1. Mar 10, 2014 at 9:00 AM
    EdFlecko
    EdFlecko [OP] Well-Known Member
    Ed
    Sacramento, California
    I see that Bosch makes some, what *seem* like, very precision oxygen sensors (i.e., "Premium", "Wideband", etc. - http://www.boschautoparts.com/OxygenSensors/Pages/OxygenSensors.aspx). Reading their verbiage, one *might* think that they're higher quality than OEM stuff so therefore maybe the trick might run a tiny bit better, experience a tine difference in performance, etc., etc.???
    I encountered http://www.oxygensensorworld.com/se...model=Tacoma&year=2004&submodel=Base&engine=4 Cyl.2.4L which offers a plethora of brands so I called and asked their opinion and they said, for a Toyota, stick with either the Denso (OEM brand) or Bosch - either is a good brand. They said don't expect to notice any performance difference with one or the other.
    Comments?
    Ed
  2. Mar 10, 2014 at 12:34 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Most Toyota's I've had did not run correctly with Bosch brand parts. So now I only use Toyota Brand, Denso or NGK. Have not had one fail on my yet but everyone has a different opinion.
  3. Mar 10, 2014 at 12:43 PM
    KerlyQ
    KerlyQ Well-Known Member
    Jared
    BC Canada
    First and last truck Ill own.
    Magnaflow exhaust. Custom leather Katskinz. Fujita CIA. Custom canopy. Armourthane sprayed bed. Grey wire mod. Black American eagle wheels. Dick Cepeks FCII's. Black Emblems all around. TRD oil cap. Ignition Light Ring Mod. Blue LED dash and controls.
    I tried the Bosch and It didnt last. I have learned to quit cutting corners and just buy OEM because in the long run you just end up spending the same amount replacing the non OEM parts several times over.
  4. Mar 11, 2014 at 3:36 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    X2, Toyota seems to enjoy Toyota designed parts. Either NGK or Denso, anything else seems to fail or the truck runs crappy.
  5. Mar 11, 2014 at 9:59 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I was going to buy the ones from urd that are DENSO and i think are oem but i found the exact same one on Amazon for 55$ instead of the 100$ from urd.
  6. Mar 31, 2014 at 10:10 AM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I highly advise you to stick to OEM. Things like that need to be OEM with these trucks. I had to learn that the hard way.
  7. Mar 31, 2014 at 4:50 PM
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Yes unfortunately only OEM works best. Sometimes even good working OEM junk yard parts like starters and alternators work better than parts store (junk) parts.
