Replace leaf springs or add a leaf?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dave12, Jun 26, 2020.
  1. Jun 26, 2020 at 12:37 PM
    dave12
    dave12 [OP] New Member
    02 Tacoma PreRunner
    I am looking to get rid of the blocks I have in my Tacoma and put in a completely new left spring setup. I am not sure if it worth replacing all the leaf springs? Or just adding a 1.5in add a leaf. let me know what yall recommend and what brands I should be looking at.
    TXpro4X4 likes this.
  2. Jun 26, 2020 at 12:38 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    dave12[OP] and TXpro4X4 like this.
  3. Jun 26, 2020 at 12:41 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to the forum!
    Is the leaf pack shot?
    Is it not rebounding?
    Ask yourself these questions
    What do you think?
    Just from what you said above I would replace with new and no blocks. Both sides
    Good luck
    jammer and dave12[QUOTED][OP] like this.
  4. Jun 26, 2020 at 12:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Leaf springs come as a pack; so fortunately against your thinking, individual leaf springs are not pulled out for replacing.
    Knowing that you're removing the rear block, I take it you wish to retain your lift?
    If your leaf pack is tired out, I'd recommend some OME Dakar's on a budget.
    If you want something more suited for flexibility and off road, Deaver and Alcan make great leaf packs.
    You can get one customized to your liking as well by the above 2 companies but for a bit more money.
  5. Jun 26, 2020 at 12:46 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    +1 on the Dakar recommendation. I have the medium pack. An additional comment, I did not want the full 2.5" to 3" Dakars provide. So, I pulled the upper overload (which is .6" thick) to bring the lift down to my 2" target. Works great. Doesn't affect normal usage at all. My truck has a shell so I never have that much weight to bear in the back and it doesn't ever ride on the overloads.
    dave12[OP] likes this.
  6. Jun 26, 2020 at 1:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even easier for 1st gens; only 1 leaf pack option available.
    But the removal of a leaf still applies for those that want a bit less lift and don't need as much weight handling.
  7. Jun 26, 2020 at 4:24 PM
    02blancotaco
    02blancotaco Well-Known Member
    Colby
    02 Toyota Tacoma 4x4 Trd
    I have the icon 1.5 inch progressive add a leaf pack and really like the ride, with nothing in the bed its a little harsh but when I have some weight such as my canopy the ride it super smooth, but I think almost any add a lead or leaf pack will be a little harsh with a empty truck.
  8. Jun 26, 2020 at 4:57 PM
    Krogers128
    Krogers128 Well-Known Member
    Kyle
    WA
    1995.5 Paradise Blue Tacoma SR5 V6
    OME complete kit. 881 coils. Dakar Leafs. JBA UCA. 265/75-16 Goodyear Ultraterrain.
    Also in the market for new leaf pack. Mine are flat and frown with just 200-250lbs in the back, pretty weak. Got to assume they’re original from 95. I’m leaning the Dakar route with new nitro chargers front and back. Are you able to pull a leaf on the CS019R? I don’t want a crazy lift, maybe 1.5-2” and pair it with 880/881 coils up front. I ride empty like 90% of the time I drive.. camping, hauling landscape crap and dirt biking being the exception. (Sorry, long rant, didn’t want to start new thread)
    Hamer95USA likes this.
  9. Jun 26, 2020 at 5:43 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'd say that if you're still running on the original springs, it's for sure worth it to just replace the entire leaf pack. It's a safe bet tehy are worn out.
    For a 1.5" lift, the Deaver J59s are a very popular and very high quality spring. They aren't necessarily made for heavy lifting (off road oriented performance), so if you have heavy junk in your trunk, I'd say an add-a-leaf is best. Or better yet, new leaf pack, plus the add-a-leaf for the extra weight. Just doing an add-a-leaf on an old worn out leaf pack is kind of a band-aid fix...
    There are a few other brands, like the OME Dakars, but those are more like a 2.5"-3" lift... I suppose you could remove a leaf like others have said, but I kinda hesitate to screw around with a leaf pack like that.
    I think others have mentioned that there is also the option of a 3-leaf pack, ICON, and a few others make those, too. Those are an intermediate choice between a single add-a-leaf and a whole new leaf pack.
    The "best" and of course most expensive, is a full custom set of Alcans. They're pricey, but you're guaranteed to get exactly what you want.
  10. Jun 26, 2020 at 9:50 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I got tired of the stock leaf springs & front coils, the way the rear sagged when it was loaded plus I carry emergency gear/tools, and have a shell & an ARB deluxe bumper. I went with an OME complete suspension kit:
    883 front coils
    Nitro charger gas shocks
    Dakar leaf springs
    AAL
    Stainless steel brake lines/greasable shackles/exhaust bracket kit
    SPC UCA
    I got 3” lift, no more sagging on heavy loads, and am happy with the way the truck rides & handles the road. You can get the Dakar leaf springs without the AAL, the 880 or 881 front coils, and still get about 2” lift. Here’s a couple of pictures of my truck:
    Krogers128[QUOTED] and Kolter45 like this.
  11. Jun 29, 2020 at 8:57 PM
    Krogers128
    Kyle
    WA
    Thanks for the info. I just ordered a full OME kit from Wheelers, hope it doesn't take to long to get here!
