Replace front brake dust shield, 4WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by joea99, Jun 11, 2021.
  1. Jun 11, 2021 at 10:23 AM
    joea99
    joea99 [OP] Well-Known Member
    2002 3.4 TRD 4WD auto
    Anyone know how to replace front brake dust shield without removing the hub?
    I was going to replace them while doing the front brakes, but, genius that I am, did not realize the hole in the shields is much smaller than the outer diameter of the hub. I should have known that after replace the rear backing plates when doing the rear bearings couple years ago.
    Without removing the hub, one choice seem to be, cutting a small piece out of the new ones on the front edge where it is narrowest and trying to flex it over the hub. I guess I could try that on the old ones to see if they come off that way, but as they are weak and thin from rust, it might not be a good test.
    The other choice seems to be leaving the old ones on until it is time to change the CV axles or wheel bearing.
    A lot of shops around here say they just cut them off and be done or let them rot off.
  2. Jun 11, 2021 at 10:37 AM
    joea99
    I found this where one guy just cut the new ones in half: https://www.tacomaworld.com/threads/replacing-rotted-dust-shields.301192/
    Anyone?
  3. Jun 11, 2021 at 11:03 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
  4. Jun 11, 2021 at 12:09 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I'm wondering if removing them entirely will help aid in better cooling.
  5. Jun 11, 2021 at 12:35 PM
    joea99
    I went that way. Problem now is that one of the 4 bolts on the right side snapped without a hint after all the others were very reluctant. Figures. I am not confident one bolt on that half will hold. Right now I am struggling to try and get the remaining bolt out. It is almost flush with the spindle face. I have have small oxy-acetylene "jewelers" setup that I can get right on the bolt. Waiting for it to cool down now.
    No room to get a drill on it. Looks like I could remove a wheel lug and drill through that hole pretty much straight in. Now gotta look up how to get those out. Done it before, with broken ones, but don't recall how I did it.
  6. Jun 11, 2021 at 1:10 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Taco critter likes this.
