Replace camper shell weather seal with....?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Jul 24, 2021.
  1. Jul 24, 2021 at 10:05 AM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I have to remove my camper shell to fix the stupid leaking 3rd brake light.
    After watching a few videos, it sounds like I "might" need to replace the weather seal. I have an ARE cap and it's been on the truck for around 3 years. Should I plan to just replace it or does this stuff tend to last?
    If I replace it, is there any reason to do something like garage door weather seal or anything else that's better? I do have a small leak near the cab that seems to be from some sort of notch that was plugged with sealant. I'll try and clean that up as well.
    Thanks.
  2. Jul 24, 2021 at 2:55 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    It depends on how the seal looks like when you remove the shell.If you have it off might as well do a new seal.
  3. Jul 24, 2021 at 3:52 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Use a bulb seal rather than a foam seal.
    Steves104x4 likes this.
  4. Jul 24, 2021 at 4:53 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
  5. Jul 24, 2021 at 5:15 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    FYI, some places RTV the cap. Take a good look.
  6. Jul 24, 2021 at 5:53 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Esi is premium brand. Foam tape from installer/cap dealer is cheap and should be replaced. Foam tape also gets compressed easily and can cause cap to rub paint. Esi bulb seal will raise the cap off the rails higher than tape but prevents paint rub. I have posted about my setup 2 yrs back if you feel like searching
  7. Jul 24, 2021 at 7:01 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Will it still lift off normally or does it need to be cut? Hopefully my shop didn't do that.
  8. Jul 24, 2021 at 7:10 PM
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    I agree you should plan on replacing the seal. That ESI product looks very similar to what the installers used on my GFC.
    I’m new to the forum and I’ve seen a few posts about the brake light leaking. I just got my camper; how common is this leak?
  9. Jul 25, 2021 at 2:08 AM
    baldbeardedtaco
    FL
    Tsb for brake light, last I heard was up to and topped at 2018.
    gwiz[QUOTED] likes this.
  10. Jul 25, 2021 at 1:22 PM
    oneinthestink
    oneinthestink How I like it…
    Treasure Valley
    GX 460
    I don't mean to hijack the thread; I've never personally known anyone to use a camper shell, and I've not looked into one for myself ever - is a camper shell not something you can remove and install at will? I had never really considered that they would even be sealed.
  11. Jul 26, 2021 at 8:45 AM
    baldbeardedtaco
    FL
    Yes removed at will and use of seal as in foam tape or bulbs not seal as in rtv etc. (some do fill in gaps with it but it’s doesn’t seal the cap permanently to the truck)
    oneinthestink likes this.
  12. Jul 26, 2021 at 8:46 AM
    kddouglas
    kddouglas Well-Known Member
    Georgetown, TX
    2020 TRD OR 4x4
    4Runner SEMA wheels. TRD Factory lift kit.
    Butyl tape
  13. Jul 26, 2021 at 12:51 PM
    Woodrow F Call
    Colorful Colorado
    Cut and removed.
  14. Jul 26, 2021 at 7:12 PM
    baldbeardedtaco
    FL
    I don’t understand how a reputable shop would/could rtv a cap directly to the rails (unless client requested I suppose).
