Replace broken fog light lens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rolias15, Jul 15, 2016.
  1. Jul 15, 2016 at 9:07 AM
    rolias15
    rolias15 [OP] Member
    Brooks, Alberta
    toyota tacoma access cab
    box soft roll top cover, electric trailer brake controller, locking tail gate. Removed box soft top roll cover and replaced with a truck box canopy, installed rear air shocks to aid in towing.
    If your fog light lens is broken and has to be replaced the dealership can do it for you but check out getting a replacement from ebay or some other source first to compare prices. I decided to do it myself after getting a quote from the dealership. I ordered my replacement fog light from ebay and got a complete fog light kit with wiring, switches, both lights and insert receptacles, etc. for about $56 American including shipping I now have a spare passenger side fog light and other stuff I didn't use as my truck came with fog lights. First of all I removed the driver's side tire and removed the lower two screws that hold the plastic fender liner as well as two other plastic retainer pins that can be removed with a flat screwdriver. It takes a bit of fiddling but the fender liner can be pulled back and hooked on the suspension to give you room to get at the back of the fog light. You have to remove two phillips screws and the fog light will come out. Remove the wiring plug in and plug it into the new light and place the light in the receptacle and replace the screws. Check that it works and put everything back together.
    JimIowa likes this.
  2. Mar 25, 2019 at 4:24 PM
    TacoMeat13
    TacoMeat13 Member
    Dave
    Ottumwa,IA
    2013 reg. cab 4wd
    Thanks for post. Made replacing one of mine easier! :thumbsup:
    JimIowa likes this.
  3. Mar 25, 2019 at 5:26 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    FWIW, I ordered a used OEM foglight off ebay and what showed up was incorrect and had a plastic lens (prob from a Sienna or something). The seller refunded me the $$ and didn't require me to ship the part back.... so I started cutting. Plastic lens fit the Tacoma fog light perfectly. It took a lot of picking glass shards and cleaning adhesive but I got it done. One day Ill break the other glass one and replace it with plastic, or vise versa.
  4. Mar 25, 2019 at 5:55 PM
    TacoMeat13
    TacoMeat13 Member
    Dave
    Ottumwa,IA
    2013 reg. cab 4wd
    Ok. I just bought a pair of replacement fog lights from ebay for $18.88 w free shipping. ( Had glass lenses and new light bulbs) Worked out great with the pics on how to access thru fender well. 2 bolts, 2 screws, 1 plastic push pin, then 2 screws holding light in. Reverse, and done. :)
