Replace Aftermarket Paper Speakers But Keep Stock Head Unit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dlang13, May 31, 2020.
  1. May 31, 2020 at 10:28 PM
    dlang13
    dlang13 [OP] Member
    2019 Tacoma TRD Off-Road
    Looking to upgrade the poor sounding, paper thin stock speakers.
    I am NOT wanting to replace the head unit, add an amp or install a sub.
    Looking for a good quality sounding speaker that will throw out some bass but i don't want to under power the speaker with the OEM head unit.
    What have you installed?
    Any info is appreciated!
  2. May 31, 2020 at 10:31 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Most aftermarket speakers arent going to give much bass. They’re designed to produce midbass and be paired with a sub to produce the low frequencies. That doesn’t mean there aren’t speakers that don’t produce bass, but your best bet is to replace the speakers, add an amp and a sub if you want quality sound.
  3. Jun 1, 2020 at 4:56 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    I plan on doing exactly the same thing, keep oem stock hu and just replace the speakers. Some say that the factory hu only puts out 10w but you know what that may not sound like much but it will be enough. I myself lean on Focal speakers (entry level) and from what I read do sound great with low powered amps...i need to get my adapters, Toyota has some funky 3 bolt mounting system...keep us updated!
  4. Jun 1, 2020 at 5:21 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Just get a decent set of speakers. They will sounds much better than the factory setup. I would look on crutch field and find a efficient component set of 6x9 and tweeters. The 6x9s will have better lows than a 6.5 setup. This isn’t to say you’ll get more bass, but this is as close as you’ll get without a legit setup. If you want legitimate bass then you need a sub as even 6x9s will struggle with anything under 100Hz. Bass or no bass though, a decent set of component speakers will sounds better than the factory paper bs speakers.
    if you see your self getting a sub down the road, upgrade to a 6.5” component setup now and add the sub later
  5. Jun 1, 2020 at 5:28 AM
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    It can be done and is how many start. It helps to get efficient speakers with the stock head unit. You can sort by sensitivity (efficiency) on crutchfield. Both JL and Kicker offer 6x9 component speakers with sensitivities greater than 91. I went with the Kicker kit and it worked well although I'm sure JL would be just as good.
  6. Jun 1, 2020 at 5:30 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    Sorry but you'll be disappointed. You can't drive aftermarket speakers with the headunit and get any appreciable bass output. Won't happen.
    If you pick a great speaker that's extremely efficient you MIGHT get a decent improvement in sound quality over the stock speakers, but it won't be much if any louder.
    The only way to keep the OEM headunit and add bass is to add an amp and sub.
  7. Jun 1, 2020 at 6:19 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    So, this is something that a lot of us did at some point to improve sound quality in 3rd gens Premium Audio Upgrade for less than $250
    I am pretty happy with it, it's way better than stock, but... if you're looking for have your and deeper bass, and for your system to be louder, then you might have to look into installing an amp Kicker hideaway- final upgrade to the $250(+) 3rd gen premium upgrade (+Kicker Key 180.4 amp). I didn't do it yet. I've grown to enjoy / tolerate the system the way it is right now. And with all other projects that I have going on, installing an amp is very low on the upgrade list.
    One more thing, while replacing speakers, you might want to invest just a little bit more time and money and install some sound deadening in the doors. It won't improve things greatly.
    Good luck :thumbsup:
    DWD484 likes this.
  8. Jun 1, 2020 at 6:32 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    I went the route above with some experimenting as i didnt find that thread till later.
    OP-
    First- the subaru tweeters are the first thing you should do. As for some it cleans it up enough. I have this and it cleared it up alot.
    Second- the stock 6x9 give decent bass for what they are. and if you have ever held the stock speakers you will understand what i mean.
    Third- I had kicker 6x9 DS up front, and 6 3/4" CS out back, and it was clear. Very clear and sounded great. But little no no bass. You need a sub to bring it up or something like the kicker key (also had). The key will really wake them up and it sounds really good.
    Basically the "under 250 upgrade" look there. It will keep you from spending unnecessary money and get you only the parts you need.
    in short- subaru tweeters, kicker CS or KS (if you want to spend the money) front and rear, and the key. Simple install, sounds awesome.
  9. Jun 1, 2020 at 6:32 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Just add a kicker key or alpine powerpack along with the speakers. I know you said you don't want to install an amp but these amps don't require power from the battery and no cutting of factory wiring. They're powered by the stereo wiring and go inline to the speakers.
    IMO that's the only way you're going to get any meaningful bass without a sub or head unit swap.
    Here's harness I had to make (took about 30 mins) and after that the amp just plugs right into the factory wiring harness.
  10. Jun 1, 2020 at 6:41 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Is the key something you would really recommend (short of adding a sub) ? I mean, I kinda am considering it, but like mentioned above, I have all bunch of different things taking priority.
    To ask in a little bit different way, would adding Key Amp make as much of a difference to this setup, as much as replacing tweeters does to a stock speakers? :rolleyes:
  11. Jun 1, 2020 at 7:05 AM
    jjs2608
    jjs2608 Member
    Jacob
    2019 Tacoma OR DCSB
    I bought these. Very very happy with them, the bass is far better than stock and did not diminish like most aftermarket speakers will do.
    I paid 189 through a seller offering prime shipping.
    https://www.amazon.com/Infinity-KAP...ds=infinity+kappa+90csx&qid=1591020068&sr=8-1
    I needed the metra 6x9 adapter for the tacoma to mount these speakers, which came to 12 dollars/pair from best buy.
    There are also several adapters out there for the tweeter connector and woofer connector that are absolutely worth the cost. (maybe an extra thirty total for front door and tweeters)
    Tweeter:
    https://www.amazon.com/gp/product/B07RMZ4CR6/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Woofer harness is the standard metra one.
    There is a radio adapter lead as well that I bought for 30 that basically gives you an extra section of factory wire that you can splice into without hurting the truck harness.
    https://www.amazon.com/gp/product/B07Y2DJFXC/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
    Also, check out carid, they offer the AudioControl ACM4.300 for 205 (msrp 350). Its a much better amp than the kicker key if you can forego the DSP. You will NOT need a LOC, this amp features speaker level in. I typically use this brand in high end home installs, they are very very nice quality.
    https://www.carid.com/audio-control/acm-series-4-channel-micro-amplifier-mpn-acm-4-300.html
  12. Jun 2, 2020 at 6:14 AM
    TacoLoco17
    TacoLoco17 Well-Known Member
    Craig
    Conshy, PA
    17 TRD OR DCSB Super White
    TRD Sport Hood swap TRD Exhaust TRD Intake TRD Skid plate TRD Pro Faux grille w/ Raptor lights MORIMOTO XB LED Headlights Rigid D series Fog lights Rigid E series 20” lightbar Spot/Flood MESO Ultimate Turn signal MESO Stage 1 Tailights 3x Remote Start Hypertech In-line Speedo Calibrator OV Tune Bilstien 6112/5160 Set at 5/6 OME Dakar Medium Leaf Pack Pioneer Avic 8400 NEX Headunit Infinity Reference 6x9s Front 6.5"rear Kicker Subaru Tweeters JL Audio Stealthbox w/ JL Audio RD500/1 amp ARE CX series cap Toyota OEM Trifold Hard Tonneau Body Armor HiLine Front Bumper Smittybilt X20 Gen 2 10K Winch SCS Ray 10 17x8.5 Gunmetal Rims 275/70 Falken Wildpeak AT3W tires
    i installed subaru tweeter and infinity reference 6x9s in front and 6.5” in rear doors. the stock headunit seems to drop the bass levels the louder the volume probably to prevent distortion on the stock crap speakers. although it did sound better i wasn’t satisfied and ended up installing a Pioneer 8400NEX and a JL Stealthbox.
