Repeating O2 sensor codes :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N8ball, Jan 22, 2017.
  1. Jan 22, 2017 at 8:23 PM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    Total Chaos long travel kit
    Hello all! I bought a 2008 taco used and now need to get it smogged. The check engine light for bank 1 sensor 2 and bank 2 sensor 2 keeps coming back on! I had my toyota mechanic replace both sensors with OEM and even got a new purge valve. Even after verifying voltage and heating, the light comes on AGAIN for same codes:(. He said i have to take it to dealer for either a faulty computer or the catalytic converter. Has this ever happened to anyone before?
  2. Jan 22, 2017 at 8:25 PM
    Bishop84
    Bishop84 Well-Known Member
    The purge valve is unrelated to the exhaust emissions, can you share which specific codes are triggering?
  3. Jan 22, 2017 at 8:30 PM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    P0138 is one (bank 1 sensor 2) and the same code for bank 2 sensor 2 (dont have the specific code right now, sorry) will have them tomorrow. Before the purge valve was replaced these were all the codes, down to just the o2 sensor codes now Resized_Screenshot_20161026-105228.jpg
  4. Jan 22, 2017 at 8:38 PM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    Do a proper diagnosis before you start replacing parts.
  5. Jan 22, 2017 at 8:45 PM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    I had one mechanic look at it who replaced the (charcoal canister?) and the O2 sensors. This was to prevent a hefty dealer charge for minor repairs. It was worth a shot.
    It's at a different toyota shop now, they have done a proper diagnostics and said the dealer has to take a look now because the o2 code came BACK on. Thanks for that tip, by the way.
  6. Jan 23, 2017 at 8:09 AM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    P0138 and p0157 are the codes that keep poping up.
  7. Jan 23, 2017 at 11:49 AM
    Bishop84
    So Toyota's have a thing about high voltage to the downstream O2 sensors, often it's caused by erroneous readings from the upstream A/F sensors.
    It's more of an issue with the 3.5 2GR's but it can happen on any engine.
    That said, one code is high voltage (which we usually suspect the A/F) and one code is opposite bank low voltage (we suspect the o2 sensor itself)
    The sensors are faulting because they are working, just not in the perimeters set by the ECU. Also if the cat was failing you would have P0420 and P0430 associated to your o2 codes. If they were plugged you'd have a misfire and lack of power.
    I would need a freeze frame for any further advise, I'd need to know voltages of all the sensors and the fuel trim on each bank.
    You're gonna need them to look at it.
  8. Jan 23, 2017 at 11:54 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    ^This is an excellent "pre-diagnosis"--the man knows his stuff...
  9. Jan 23, 2017 at 12:24 PM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    Yes sir excellent indeed, thank you. So here is the info from "the toy shop"
    B1S2 - 0.80v (changing slowly)
    B2S2 - 0.08v (changing rapidly)
    Long term fuel trim numbers were in the 17-20% range. Fixed an air leak at the air mass meter which reduced the fuel trim by 3%.
  10. Feb 9, 2017 at 6:20 PM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    The dealer replaced both A/F sensors. Its been 100 miles and no check engine light.
    balljoint likes this.
  11. Feb 10, 2017 at 11:41 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Where are the af sensors located at?
  12. Feb 11, 2017 at 1:12 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ex manifolds
  13. Feb 11, 2017 at 1:23 AM
    lilgerber
    Aaron
    Fresno, CA
    How much did they run? I thought those were the o2 sensors? I have the URD o2 simulator, but im still throwing the same codes. Im in the middle of replacing my charcoal filter and adding a "2003 + 4-Runner " fuel neck to extend my gas line for my fiberglasd bedsides. I believe I have a fuel/ air leak .
  14. Feb 11, 2017 at 1:26 AM
    inwood customs
    Dave
    lilgerber[QUOTED] likes this.
  15. Feb 11, 2017 at 1:29 AM
    inwood customs
    Dave
  16. Feb 13, 2017 at 9:43 AM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    This was an excellent comment, thank you. The dealer has determined that my A/F sensors were throwing out weird readings, so they replaced them... after 150 more miles, the O2 sensor codes came back on again! Any other suggestions? The dealer is saying I might need another ECU.
  17. Feb 16, 2017 at 5:00 PM
    Pezzer01
    Pezzer01 New Member
    Ron
    2006 Tacoma TRD Off Road
    I'm having the same codes, even after replacing both downstream o2 sensors. The 2 relays under the hood were fine. This check engine light is driving me mad.
    Anyone know how to fix this problem?
  18. Feb 17, 2017 at 7:06 AM
    N8ball
    N8ball [OP] Member
    2008 Tacoma TRD
    So, after i replaced both downstream sensors the first time, the same codes came on (read above in the thread for code #). Then i replaced both A/F sensors. THEN once the ECU was finally getting the right readings, the 0420 code came on for one of my catalytic converters. Had to chase it all the way down to the cat. Good luck. My truck has 137k miles on it so i guess it's just that time...
  19. Feb 22, 2017 at 6:52 PM
    Pezzer01
    Pezzer01 New Member
    Ron
    Wait but why isn't the cat code showing up then after I replaced both sensors? My truck has 108,000 miles.
    Isnt the A/F sensor the same thing as the downstream sensors?
  20. Feb 28, 2017 at 9:54 PM
    grydsrt
    grydsrt Mall Crawler
    Heart of, Texas
    '05 Double Cab, Long Bed, 4x4, Camper Shell, 205k Original Owner
    URD TACI, URD MAF Sensor Calibrator, URD Dual Rear O2 Simulator, AFE MACH Force XP Cat-Back, Thorley Y-Pipe, JBA LONG TUBE Headers, URD O2 extension harness. In line tranny filter, URD in-tank pump/fuel filter. Hopkins Smart Hitch Camera and Sensor System. 3M Clear tint on windshield. SnugTop Camper Shell.
    Try replacing your intake manifold or header studs with new and use lock washers or lock nuts. You need "external torx" sockets to do so however the parts are cheap.
    I replaced my header gaskets at the same time because the gap caused by the header nuts working loose destroyed the existing gaskets.
    Runs like a champ now AND no more CEL's ...
