Repairs after ball joint failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ternary, Aug 30, 2019.
  1. Aug 30, 2019 at 3:08 PM
    Ternary
    Ternary [OP] New Member
    So today my front left tire came completely separated from my '03 Prerunner on my drive to work. It looks like the ball joint on the lower control arm failed when I hit a bump on a dirt road. Luckily the majority of the truck seems completely unharmed, since as far as I can tell the control arm prevented anything but it from hitting the ground.
    I'd like to fix this myself, but I'm no grizzled veteran of front end work. It seems pretty doable, I just am not sure exactly what should be replaced. I'd obviously need a new ball joint and brake line, but I figure I may need to replace the lower control arm. What I'm not sure of is if things like the upper control arm, outer tie rod, or anything on the wheel side of the ball joint will need to be replaced.
    Does anyone have any advice for me as to what I should look at/replace? Thanks
    Here you can see the ball sheared off of the lower control arm
  2. Aug 30, 2019 at 4:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :popcorn:
    Alignment after all is said and done.
  3. Aug 30, 2019 at 5:05 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    here's a list of parts that could be damaged, and I'm sure I'll forget some:
    loewr control arm
    spindle
    bearings
    tie rod inner and outer
    steering rack
    Basically anything that touches the front suspension could be damaged.
    You'll likely be able to notice paint chipping or stretch marks on the paint on pieces that are damaged. Take everything off and give it a REAL good look. A new lower control arm might not hurt. Once you get it re-assembled, get it aligned. If it aligns properly, you're all good in the hood
    Then go buy both balljoints. replace them both! and from now on keep a close eye on them and inspect them regularly. Replace them if they appear worn or damaged (like the rubber boot is leaking). Buy the best quality BJs you can afford. OEM is likely the best, but I've been running 555's from lowrange offroad. Moogs are OK, but that's the bargain basement. Don't go cheaper than that (i.e. autoparts store brand).
    Here's a little rant I wrote up about ball joints:
    https://www.tacomaworld.com/threads...-2004-4x4-doublecab-trd.622208/#post-21222495
  4. Aug 30, 2019 at 5:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Ball joints, brake line, alignment. You will be fine.
    Look for the number "555" on the new ball joints. Those are the good ones.
    The other stuff listed could be damaged, but is not the usual case.
    You can do this repair, we got faith and we are here to help when you run into snags...
  5. Aug 31, 2019 at 4:23 PM
    Ternary
    Well that doesn't sound too bad as long as there doesn't end up being extra damage. Unfortunately I won't have the time to work on it this weekend, but I'll toss some new ball joints on it and see how it goes
  6. Aug 31, 2019 at 4:28 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Can we see some frontend pics? How many miles on the truck? This is a big issue for 3rd gen 4runners, early replacement is a given.
  7. Aug 31, 2019 at 5:37 PM
    Ternary
    I don't have many pictures as the truck is still at my work, but here are two of the left suspension assembly
  8. Aug 31, 2019 at 5:59 PM
    koditten
    Kirk
    Central Michigan
    looks like the only thing needed is the upper ball joint, lower ball joint, tie rod end and a brake line.
    Of course you will need to bleed the brakes and get an alignment.
  9. Aug 31, 2019 at 6:14 PM
    Lastplace
    Southeast VA
    If that's a sway bar link in the top pick, its seen better days
  10. Aug 31, 2019 at 6:17 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Soooooo, how fast were you travelling?
    Seems like this always happens at slow speeds.
  11. Aug 31, 2019 at 10:21 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    yeah it does... LCA looks like it might be a little tweaked also
    :notsure:
