Removing Windshield Wash Resovoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Apozen, Oct 7, 2015.
  1. Oct 7, 2015 at 2:18 PM
    Apozen
    Apozen [OP] Member
    Alabama
    07 PreRunner TRD Sport
    Good afternoon,
    I'm trying to remove the resovoir so I can install some HIDs. I removed the two brackets, but i still can't remove it. The bottom pump is still intact. How do I remove it so I can get access to my headlight? Thanks
  2. Oct 7, 2015 at 2:41 PM
    Apozen
    Apozen [OP] Member
    Alabama
    I just don't know how to remove this:
  3. Oct 7, 2015 at 2:59 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Pull the wires from both sides where it is clipped into the wheel well. That'll give you enough room to pull the resivour straight up (there will be some resistance, as there is a rubber plug on the bottom). You will then have enough slack to disconnect the wire from the harness, and with the slack from the washer line, move the take you where ever you need to in the engine bay.
    Removed my tank last week.
    tinker_troy likes this.
  4. Feb 21, 2024 at 8:06 AM
    xitsjacob
    xitsjacob 98 2.4 Taco
    HTX
    does it cause any circuit issues
